this is my first project in CF and I usually use VSS in my projects so anyone have a link or how to install VSS on CFEclipse ?
Thank you so much
I don't have experience with VSS and eclipse but google("vss
eclipse")[1] can give you a starting point.
Mack
There is plugin available for VSS integeration, You can find it here,
http://vssplugin.sourceforge.net/
Has anyone been able to get VSS working properly with CF Builder or Eclipse 3.5? I have tried several things with no sucess.
Rob
We used VSS with CFEclipse for a while before moving on to another source control system. Here are the notes from our old install docs, they may be outdated, but this is how we connected to our VSS repository a couple of years ago (I have no idea what version):
The Visual Source Safe plug-in can be found here (http://sourceforge.net/projects/vssplugin/files/vssplugin/Version%201.6.2/org.vssplugin_1.6.2.zip/download). To install this plug-in, simply extract the content of this zip file into your Eclipse installation’s plugins directory (i.e., "C:\Eclipse\plugins") ; you should now have a new folder named "org.vssplugin_1.6.2" in your plugins directory; restart Eclipse. (Note: You must also install the Visual Source Safe desktop client on your local machine for Eclipse to be able to interact with VSS)
Use the following steps to connect to a VSS repository.
I hope this helps!
Eric Cobb
ECAR Technologies, LLC
http://www.ecartech.com
http://www.cfgears.com
Eric,
Thanks for the response. It doesn't appear that the vss plugin is installing correctly in Eclipse. I tried your steps and when it got to the share project pop up, the only options I have are CVS and SVN. I am using Eclipse 3.5 and CFEclipse 1.4.2. Maybe the plugin isn't compatible with the newer versions.
That could be. I got a new computer a couple of months ago and my old
one has been wiped, so I don't know what version of Eclipse I was
using. One thing I do remember is that the plugin was not compatible
with 64-bit Eclipse, we had to use the 32-bit version. So if that and a
good old fashioned restart don't fix it, I'm not sure what to do.
Eric Cobb
My recollection is not nearly as detailed as Eric's But for what it is worth, I have used the plugin with an older version: Eclipse 3.4.x / XP / jvm 1.5+ . I think I may have also used it with 3.5. But I would not swear to that part.
-Leigh
Thank you both for your replies. Still no luck getting the plugin working. It may be time to consider a different solution especially since that plugin is no longer supported.
Rob
Sorry to hear that. I have only installed on XP and never had problems. In fact I had to re-download 3.5 for today (using yoxos-ondemand). For grins I added the VSS plugin and it seemed to install fine. VSS shows up on the Team - Share Project menu. So at least that confirms it does work with Eclipse 3.5. Maybe it is a windows 7 issue (assuming that is your o/s ..)?
I'm on XP also. Still no luck with Eclipse, but I did get it working with CF Builder. I think it may have been the jre version I was using. Went back to 1.5 and noticed it was working. Thanks all for your help.
-Rob
Yes, that is entirely possible. A lot of plugins require a minimum of 1.5+, so I tend to use 1.5 by default. But I am glad to hear you finally got it working
( By the way, if you ever need to install a fresh version of Eclipse, with a certain configuration, I have had good luck using yoxos on demand. It lets you customize your configuration. Just select the Eclipse version and pick the plugins you want added. You can even save the configuration as a template. That is what I used to re-install 3.5 yesterday, and all my plugins worked right out of the box. )
Cheers
-Leigh
