How to request Adobe to create a lens profile
May 18, 2010 8:13 AM
  Latest reply: zazzo555, Dec 31, 2012 4:00 PM
Replies 1 2 3 4 Previous Next
    Sep 28, 2010 5:35 AM   in reply to ATLBigRedDog
    Please help to create following profiles:
    Nikon Nikkor AF 35-70mm F2.8D
    Nikon Nikkor AF 70-210mm F4
    Voigtlander SL-II Aspherical 20mm F3.5 (Nikon F mount)
    Thanks a lot!
    Oct 17, 2010 5:28 AM   in reply to simonsaith
    Would it be possible to create lens profiles for:
    Camera:
    Canon EOS 1Ds
    Lenses:
    1) Canon 17-35mm / f2.8 USM
    2) Canon 28-70mm / f2.8L USM
    If creating profiles for the above lenses is not viable, can you point me to a source where I can find and/or download them?
    Thanks, in advance, for your consideration and help!
    CalmLight
    Nov 21, 2010 9:55 AM   in reply to Yammer
    Helo
    Would it be possible to get profile for Finepix S100fs?
    thanks
    Dec 8, 2010 12:11 AM   in reply to ATLBigRedDog
    How about the Canon EF 70-210mm f/4?
    Thanks in advance!
    Dec 8, 2010 2:30 PM   in reply to eikelben
    voted!!
    would be awesome if adobe make 24 pc-e with maximum shift or 10mm : D
    Dec 14, 2010 5:28 PM   in reply to ATLBigRedDog
    I humbly request a profile for Canon 70-300 "L" IS lens. I expect this lens to be popular - perhaps Adobe is already working on it... Thanks!
    Jan 5, 2011 8:22 AM   in reply to MadManChan2000
    Does this work if you use a different body, such as an Olympus PL1? Also, is there documentation for this? I trust you, but I'd like to read up on it anyway
    --Alex
    Jan 5, 2011 6:07 PM   in reply to simonsaith
    Would be great if you could add a profile for the Sony SEL-18200 (Camera: Nex5).
    Thanks in advance!
    Jens
    Jan 6, 2011 8:46 AM   in reply to ATLBigRedDog
    Lens profile for Panasonic Lumix LX5 would be appreciated. (A DNG color profile for this camera would be marvelous as well)
    Cheers,
    Cory
    Jan 10, 2011 8:44 AM   in reply to piratejabez
    Cory, lens corrections are automatically applied for the LX5. The "Adobe Standard" color profile for the LX5 is automatically included (via the installer) when you install Photoshop or Lightroom.
    Eric
    Jan 11, 2011 5:22 PM   in reply to abatterbury
    Alex, yes, the lens corrections generally work well across different bodies, as long as the size of the sensor is known (not a problem with the E-PL1 or any of the Olympus Micro Four-Thirds bodies).
    Eric
    Jan 13, 2011 8:32 AM   in reply to ATLBigRedDog
    I like to have the profile
    of the NIKON lenses:
    AFS 70-300 1:4,5 VR
    AFS 18-105 1:3,5 VR
    both to use at the camera NIKON D300.
    Thank you for your help,
    Michiel Moerdijk
    Jan 13, 2011 8:36 AM   in reply to ATLBigRedDog
    I would like to have the profiles of the NIKON lenses as used on the D300 camera:
    AFS 70-300 VR 1:4,5
    AFS 18-105 VR 1:3,5
    Please inform me also how you can totally update the databank of lenses in Lightroom 3.
    Note: Do you know that Lightroom 3 doesn''t choose the right lensprofile when the RAW-photo is converted to TIFF or JPEG. So the corrections can only automatically made in the RAW-format?
    Thanks or your help,
    Michiel Moerdijk
    Jan 13, 2011 10:24 AM   in reply to MMMfoto
    AFS 70-300 VR 1:4,5
    AFS 18-105 VR 1:3,5
    Community supplied profiles for the 18-105 can be downloaded from Adobe through the lens profile downloader. The 70-300 is already supported. It should work fine with a D300. The profiles usually only work on raw because the corrections give unpredictable results on jpegs and tiffs because you don't know anything about the toning of the jpeg (messing up the vignette correction), the color balance (which makes CA correction difficult on rendered files) sharpening, and other factors.
    Jan 13, 2011 10:49 AM   in reply to MMMfoto
    Most of the lens profiles shipped with LR 3 are intended to be used with raw only. That's why they don't auto-select when processing TIFFs/JPEGs (which may already have had corrections applied, or not). This is by design.
    Jan 13, 2011 2:01 PM   in reply to MadManChan2000
    It is true that some lens defects of Micro4/3 lenses are corrected in Lightroom (this has already been the case in Lightroom 2). However, the problem is that these lens corrections are not done in the Auto mode of the lens correction panel. For this reason you only get the default correction of the manufacturers. This means for example that distortion of the panasonic 14-140 is not fully corrected at 14-18 mm. For Canon or Nikon lenses you could increase (or reduce) the amount of distortion correction in the lens correction panel and save it as your default for automatic lens correction. However, with the Panasonic lens you have to do this any time you need it in the manual lens correction mode which is not very convenient. What's more, chromatic abberations are generally not corrected with Olympus lenses and therefore you also have to do this manually. Wouldn't it be possible to get the correction information of the Micro4/3 lenses in the same way into the Auto part of Adobe Lightroom's lens correction panel like this is done for the lenses of other manufacturers? This would have the additional advantage, that you could use the "plain" result without any corrections in Lightroom, which might for example be interesting if you want maximum  sharpness in the edges of  a wide angle shot and you don't care for distortion in this particular picture.
    Jan 13, 2011 2:25 PM   in reply to MadManChan2000
    Eric is correct. If you want to force it, here is a workaround http://forums.adobe.com/message/2856442#2856442.
    -Simon
    Jan 27, 2011 8:59 AM   in reply to dregsindrag
    I'm looking for this profile, Nikkor 18-105mm f/3.5-5.6 VR DX, but can't find it. Do you have a link that you can post?
    Jan 27, 2011 12:59 PM   in reply to dschickedantz
    It's available through Adobe's lens profile downloader. Just download the app (first link on google), install it, run it and you'll find it and many more profiles.
    Feb 26, 2011 11:25 AM   in reply to ATLBigRedDog
    I would like to see a profile done for the Sony A55 with the Sony 18-150 lens and the Sony 35 f1.8 lens.
    Thank You,
    Robert
    Feb 26, 2011 3:56 PM   in reply to ATLBigRedDog
    How old of cameras are you profiling?
    I have an HP Photosmart r967
    3x optical zoom
    f2.8-5.0
    7.5mm-22.5mm
    I cannot find anywhere what camera manufacturer/plant it was made or who made the lens for HP
    Have a great day!
    Mar 5, 2011 6:18 PM   in reply to MadManChan2000
    Eric-
    Thanks for your reply, though it leaves me a little confused.
    I know LR automatically corrects for the awful barrel distortion the sensor gets at wide-angle (like the S90), but there is no separate profile to correct for more minute dictortions, chromatic abberation, and vignetting. With my S90, I relied on the default corrections as well as the additional lens profile for optimal results.
    Also, with my other cameras I get "Camera Standard" and other manufacturer-specific color profiles (that emulate the colors produced in-camera, as in JPEGs), with the option to revert back to "Adobe Standard." I was thrilled a couple years ago when Adobe released the option to use different color profiles; the difference it makes cannot be overstated—it was like night and day. This is what I mean when I say this is lacking for the LX5; "Adobe Standard" is the only color profile available, and I can't help but wonder what color rendition I'm missing out on. So, am I misunderstanding something? Does Adobe Standard mean something different for the LX5 than every other camera I've used (including the S90)? Or is it, as I fear, just that onus is on Panasonic to release color profiles that mimic in-camera color?
    Cory
    Mar 6, 2011 8:25 AM   in reply to piratejabez
    piratejabez wrote:
    Also, with my other cameras I get "Camera Standard" and other manufacturer-specific color profiles (that emulate the colors produced in-camera, as in JPEGs), with the option to revert back to "Adobe Standard."  ...  So, am I misunderstanding something? Does Adobe Standard mean something different for the LX5 than every other camera I've used (including the S90)? Or is it, as I fear, just that onus is on Panasonic to release color profiles that mimic in-camera color?
    This is the Lens Profile Creator forum -- not an ideal place to ask about color profiles, but I'll take a shot at it for you.
    You can create those profiles yourself using the DNG Profile Editor.  Adobe does release camera-matching profiles for some of the most popular cameras, but apparently your LX5 hasn't (yet?) made the cut.
    Adobe Standard does indeed mean something different for every camera.  As I understand it, Adobe Standard is a profile generated by Adobe which will process the raw data into Adobe's standard "look".  Ideally, files produced by multiple cameras processed using Adobe Standard would have identical color and tone.  The profiles you've seen that have the word "Camera" in the name are designed to match the camera manufacturer's looks instead.  None of them is any more "correct" than any other, it's all personal (or corporate) preference.
    Mar 6, 2011 2:30 PM   in reply to Mark Sirota
    Correct, we are not currently shipping a separate external lens profile for the LX5, though there is a utility (Adobe Lens Profile Creator) that enables you to build your own.
    Apr 24, 2011 1:38 AM   in reply to ATLBigRedDog
    Any chance of some profiles for Hasselblad lenses?
    ta
    Apr 25, 2011 5:30 PM   in reply to Nigel Davies
    Which specific Hasselblad lenses are you interested in having profiles for?
    Eric
    Apr 26, 2011 1:36 AM   in reply to MadManChan2000
    HI Eric,
    I use a mix of old ( sonnar T*150mm, sonnar T*250mm & Distagon T*60mm)
    and new (HC50mm, 80mm 120mm and 150mm)
    The correction profiles are available in Phocus but I'm rather set in my  ways in using LR.
    Many thanks
    nigel
    Apr 26, 2011 6:19 AM   in reply to Nigel Davies
    Noted, thanks.
    Eric
    Apr 26, 2011 10:43 AM   in reply to Nigel Davies
    If you try the Adobe Lens Profile Downloader, in the Camera Make search field, enter a wildcard search "Has", you will see 11 Hasselblad lens profiles show up.
    -Simon
    Apr 26, 2011 11:00 AM   in reply to simonsaith
    Thanks Simon,
    I will check it out now
    All the best
    nigel
    May 23, 2011 8:42 AM   in reply to ATLBigRedDog
    I would like a profile for the tamron 28-105 3.5-4.5 usm
    on the canon 5d markll.
    May 23, 2011 8:51 AM   in reply to Nigel Davies
    Nigal I have not seen an answer to the Question how to request Adobe to create a lens profile??
    May 31, 2011 12:16 AM   in reply to ATLBigRedDog
    I am not sure if this was requested before or not, but I was surprised that the Canon 35mm f/2 has no profile in lightroom, although this is a well known and popular lens.
    I tried using the Adobe lens profiler myself, but the results were no where as good as Canon's own correction in DPP, so I looked for user created ones and I found one for the 1D camera, and I am sporting the 60D with the crop sensor.
    Please please please, can you include this lens?
    Jun 18, 2011 6:08 AM   in reply to simonsaith
    Is it possible to create a profile for the Canon
    EF 28-80 mm F 3.5-5.6?
    This was a very popular lens for the EOS A2E (35 mm film) camera. If one already exists I would sure be grateful for a link.
    Jun 18, 2011 8:07 AM   in reply to elferna
    I'm not a Canon guy so I don't know if they're the same lens, but there are six user-contributed profiles available for 28-80/3.5-5.6 lenses available through the Adobe Lens Profile Downloader.
    Five are marked USM, one is not.  That one was also made on a full-frame camera, if you're still using this lens with film.
    Jun 18, 2011 8:58 AM   in reply to Mark Sirota
    Mark, thanks a million. I am new to this lens profile feature and I do use this as USM with the EOS A2E which is an auto-focus film based camera. I launched the program  but am still trying to figure out how you went to where you saw these listed. Could you send me a link or point me in the right direction?
    Jun 18, 2011 9:05 AM   in reply to elferna
    Select Canon from the Camera Make list at top left, then type 28-80 in the Lens Model box and press Return.
    Jun 18, 2011 9:36 AM   in reply to Mark Sirota
    Got it. Thanks for your help!
    Jun 22, 2011 6:11 AM   in reply to ATLBigRedDog
    bug
    Message was edited by: courtox@orange.fr
    Jun 22, 2011 7:26 AM   in reply to ATLBigRedDog
    Dear Adobe Team,
    I saw from the beginning of this discussion  many requests for Zuiko lenses (Zuiko is the Olympus lenses name). I've  made previsously some answers as "courtox" or  "courtox1" with some  poniters to find such profiles.
    The main problem is with your  beautiful too: Adobe lens profile download, If you select Olympus you will  get no profiles at all. The only way is to replace by hand "Olympus" by  "Olympus Imaging" then you will get 42 beautiful profiles.
    Is it possible from Adobe to add this name "Olympus Imaging" in the menu and remove "Olypmpus" ?
    This  is normal, because Olympus is a large company making many products. Olympus Imaging Inc is making lenses (Zuiko) and Camear (E-System and  PEN)
    So inside the exif data it is written " Olympus Imaging Inc"
    Thank you for the work done for us
Actions
Bookmarked By (1)
