Hi
I have a process which uses generatePDFOutput2 to produce a PDF. This works fine at the moment, but I need to pick the form based on a variable value which is passed in.
I've tried every combination of including the application name or not, with and wtihtout the version number, using forward slashes or backslashes and including the .xdp extension or not, but nothing seems to work. The document I can find seems to be pretty vague on what I should put in.
Can anyone help?
For reference, the path of my form as viewd in the Applications tree is of the structure: APPNAME/APPNAME/1.0/Subfolder/Formname
When I use a literal value for the Form in generatePDFOutput2 is: URI = Subfolder/Formname.xdp, Created 6/12/10
Dan
Here's the log, but the path isn't in there:
2011-01-13 16:09:39,130 INFO
[com.adobe.idp.dsc.registry.service.impl.ServiceRegistryImpl]
ServiceRegistryImpl:stop(BTDEV/Processes/GenerateReport, 1.0)
2011-01-13 16:09:39,366 INFO
ServiceRegistryImpl:stop(BTDEV/Processes/GetOS, 1.0)
2011-01-13 16:09:39,477 INFO
ServiceRegistryImpl:stop(BTDEV/Processes/EventTriggerReport, 1.0)
2011-01-13 16:10:11,638 INFO [PreparedSqlHelper] execute statement:
CALL rpr_workflow.set_component_started(?)
2011-01-13 16:10:13,156 ERROR [com.adobe.document.XMLFormService]
ALC-XTG-012-309: [11558] XMLForm, load : 12309, XFA template Model is empty.
2011-01-13 16:10:13,162 ERROR
[com.adobe.formServer.PA.XMLFormAgentWrapper] ALC-OUT-002-017: mid,tid:
12309,11558.-205674800 sev: f text: XMLForm, load : 12309, XFA template Model is empty.
2011-01-13 16:10:13,239 ERROR
[com.adobe.livecycle.formsservice.exception.FormServerException]
ALC-OUT-002-013: XMLFormFactory, PAexecute failure:
"(com.adobe.document.xmlform.ReturnStatus@4fc9008e) XMLForm, load :
12309, XFA template Model is empty."
2011-01-13 16:10:13,241 ERROR [STDERR]
com.adobe.printSubmitter.PrintException: ALC-FRM-001-013:
12309, XFA template Model is empty." in
com.adobe.livecycle.formsservice.exception.RenderFormException, cause:
ALC-FRM-001-013: XMLFormFactory, PAexecute failure:
2011-01-13 16:10:13,242 ERROR [STDERR] at
com.adobe.printSubmitter.util.FormSubmitter.submit(FormSubmitter.java: 190)
com.adobe.printSubmitter.util.FormSubmitter.submit(FormSubmitter.java: 110)
com.adobe.printSubmitter.util.Splitter.endElementNoBatch(Splitter.java :204)
com.adobe.printSubmitter.util.Splitter.endElement(Splitter.java:179)
org.apache.xerces.parsers.AbstractSAXParser.endElement(Unknown Source)
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanEndElement(U nknown
Source)
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentD ispatcher.dispatch(Unknown
Source)
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unk nown
Source)
org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
com.adobe.printSubmitter.PrintServer.execute(PrintServer.java:538)
com.adobe.printSubmitter.PrintServer.submit(PrintServer.java:232)
com.adobe.printSubmitter.service.OutputServiceImpl.generateOutputInTxn (OutputServiceImpl.java:262)
2011-01-13 16:10:13,243 ERROR [STDERR] at
com.adobe.printSubmitter.service.OutputServiceImpl.generatePDFOutputIn Txn(OutputServiceImpl.java:395)
com.adobe.printSubmitter.service.OutputServiceImpl.access$100(OutputSe rviceImpl.java:82)
com.adobe.printSubmitter.service.OutputServiceImpl$2.doInTransaction(O utputServiceImpl.java:346)
com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionBMTAdapte rBean.doRequiresNew(EjbTransactionBMTAdapterBean.java:218)
sun.reflect.GeneratedMethodAccessor329.invoke(Unknown Source)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccess orImpl.java:25)
java.lang.reflect.Method.invoke(Method.java:597)
org.jboss.invocation.Invocation.performCall(Invocation.java:359)
org.jboss.ejb.StatelessSessionContainer$ContainerInterceptor.invoke(St atelessSessionContainer.java:237)
org.jboss.resource.connectionmanager.CachedConnectionInterceptor.invok e(CachedConnectionInterceptor.java:158)
org.jboss.ejb.plugins.CallValidationInterceptor.invoke(CallValidationI nterceptor.java:63)
org.jboss.ejb.plugins.AbstractTxInterceptor.invokeNext(AbstractTxInter ceptor.java:121)
org.jboss.ejb.plugins.AbstractTxInterceptorBMT.invokeNext(AbstractTxIn terceptorBMT.java:173)
org.jboss.ejb.plugins.TxInterceptorBMT.invoke(TxInterceptorBMT.java:77 )
org.jboss.ejb.plugins.StatelessSessionInstanceInterceptor.invoke(State lessSessionInstanceInterceptor.java:169)
org.jboss.ejb.plugins.SecurityInterceptor.invoke(SecurityInterceptor.j ava:168)
org.jboss.ejb.plugins.LogInterceptor.invoke(LogInterceptor.java:205)
org.jboss.ejb.plugins.ProxyFactoryFinderInterceptor.invoke(ProxyFactor yFinderInterceptor.java:138)
org.jboss.ejb.SessionContainer.internalInvoke(SessionContainer.java:64 8)
org.jboss.ejb.Container.invoke(Container.java:960)
org.jboss.ejb.plugins.local.BaseLocalProxyFactory.invoke(BaseLocalProx yFactory.java:430)
org.jboss.ejb.plugins.local.StatelessSessionProxy.invoke(StatelessSess ionProxy.java:103)
$Proxy157.doRequiresNew(Unknown Source)
com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute( EjbTransactionProvider.java:133)
com.adobe.idp.dsc.transaction.impl.DefaultTransactionTemplate.execute( DefaultTransactionTemplate.java:79)
com.adobe.printSubmitter.service.OutputServiceImpl.invokeGeneratePDFOu tputWithSMT(OutputServiceImpl.java:341)
com.adobe.printSubmitter.service.OutputServiceImpl.generatePDFOutput2( OutputServiceImpl.java:322)
2011-01-13 16:10:13,244 ERROR [STDERR] at
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.j ava:39)
com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(Default POJOInvokerImpl.java:118)
com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(Inv ocationInterceptor.java:140)
com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed (RequestInterceptorChainImpl.java:60)
com.adobe.idp.dsc.interceptor.impl.DocumentPassivationInterceptor.inte rcept(DocumentPassivationInterceptor.java:53)
com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.doI nTransaction(TransactionInterceptor.java:74)
com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionBMTAdapte rBean.doBMT(EjbTransactionBMTAdapterBean.java:197)
sun.reflect.GeneratedMethodAccessor326.invoke(Unknown Source)
2011-01-13 16:10:13,245 ERROR [STDERR] at $Proxy157.doBMT(Unknown
Source)
com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute( EjbTransactionProvider.java:95)
com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.inter cept(TransactionInterceptor.java:72)
com.adobe.idp.dsc.interceptor.impl.InvocationStrategyInterceptor.inter cept(InvocationStrategyInterceptor.java:55)
com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept(I nvalidStateInterceptor.java:37)
com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept( AuthorizationInterceptor.java:188)
com.adobe.idp.dsc.interceptor.impl.JMXInterceptor.intercept(JMXInterce ptor.java:48)
com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.invoke(ServiceEngineIm pl.java:121)
com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:129)
com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.routeMess age(AbstractMessageReceiver.java:93)
com.adobe.idp.dsc.provider.impl.vm.VMMessageDispatcher.doSend(VMMessag eDispatcher.java:225)
com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(Ab stractMessageDispatcher.java:66)
com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:20 8)
com.adobe.workflow.engine.PEUtil.invokeAction(PEUtil.java:861)
com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.transientInvoke( WorkflowDSCInvoker.java:347)
com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.invoke(WorkflowD SCInvoker.java:158)
2011-01-13 16:10:13,246 ERROR [STDERR] at
com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapte rBean.execute(EjbTransactionCMTAdapterBean.java:357)
com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapte rBean.doRequiresNew(EjbTransactionCMTAdapterBean.java:299)
sun.reflect.GeneratedMethodAccessor230.invoke(Unknown Source)
org.jboss.ejb.plugins.TxInterceptorCMT.runWithTransactions(TxIntercept orCMT.java:404)
org.jboss.ejb.plugins.TxInterceptorCMT.invoke(TxInterceptorCMT.java:18 1)
$Proxy156.doRequiresNew(Unknown Source)
com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute( EjbTransactionProvider.java:143)
2011-01-13 16:10:13,247 ERROR [STDERR] at
com.adobe.idp.jobmanager.execution.workadapter.AbstractExecutableJob.i nvokeRequest(AbstractExecutableJob.java:127)
com.adobe.idp.jobmanager.execution.workadapter.PersistentExecutableJob .execute(PersistentExecutableJob.java:60)
com.adobe.idp.dsc.workmanager.adapter.UnManagedAsynchronousWorkAdapter .run(UnManagedAsynchronousWorkAdapter.java:39)
org.jboss.resource.work.WorkWrapper.execute(WorkWrapper.java:204)
org.jboss.util.threadpool.BasicTaskWrapper.run(BasicTaskWrapper.java:2 75)
EDU.oswego.cs.dl.util.concurrent.PooledExecutor$Worker.run(PooledExecu tor.java:743)
java.lang.Thread.run(Thread.java:619)
2011-01-13 16:10:13,247 ERROR [STDERR] Caused by:
com.adobe.livecycle.formsservice.exception.RenderFormException:
com.adobe.formServer.FormServer.renderForm(FormServer.java:234)
com.adobe.formServer.FormServer.renderForm(FormServer.java:282)
com.adobe.formServer.docservice.FormsDocService.renderForm(FormsDocSer vice.java:556)
com.adobe.printSubmitter.util.FormSubmitter.submit(FormSubmitter.java: 169)
2011-01-13 16:10:13,247 ERROR [STDERR] ... 142 more
2011-01-13 16:10:13,248 ERROR [STDERR] Caused by:
com.adobe.livecycle.formsservice.exception.FormServerException:
2011-01-13 16:10:13,248 ERROR [STDERR] at
com.adobe.formServer.PA.XMLFormAgentWrapper.doPAExecute(XMLFormAgentWr apper.java:362)
com.adobe.formServer.PA.XMLFormAgentWrapper.execute(XMLFormAgentWrappe r.java:203)
com.adobe.formServer.Controller.doXFARender(Controller.java:738)
com.adobe.formServer.Controller.doRender(Controller.java:566)
com.adobe.formServer.Controller.render(Controller.java:139)
com.adobe.formServer.FormServer.renderForm(FormServer.java:215)
2011-01-13 16:10:13,248 ERROR [STDERR] ... 145 more
2011-01-13 16:10:13,252 ERROR [com.adobe.workflow.AWS] An exception was thrown with name com.adobe.livecycle.output.exception.OutputException
message:com.adobe.printSubmitter.PrintException: ALC-FRM-001-013:
com.adobe.livecycle.formsservice.exception.FormServerException while invoking service OutputService and operation generatePDFOutput2 and no fault routes were found to be configured.
2011-01-13 16:10:13,264 INFO [PreparedSqlHelper] execute statement:
CALL rpr_workflow.set_component_errored(?,?)
Let's just to do another test.
Go to the following url: http://localhost:8080/repository. This give you access to the repository from a web browser.
Browse to your file to make sure it's store in the path you think it's stored in.
Let me know.
Jasmin
I've navigated my way to http://exbtuat2lc1:8080/repository/Applications/BTDEV/1.0/Reports (exbtuat2lc1 is the name of the server) and KnowYourNeighbour.xdp is there.
Unfortunately that's still not working.
Here's the new log file if that helps:
2011-01-17 04:00:00,050 INFO
[com.adobe.idp.um.scheduler.AutoCreateDynamicGroupJob] AutoCreation Not Enabled
2011-01-17 10:04:07,132 INFO [PreparedSqlHelper] execute statement:
2011-01-17 10:04:19,524 INFO
2011-01-17 10:04:34,531 INFO
2011-01-17 10:04:42,336 INFO
2011-01-17 10:06:17,437 ERROR [com.adobe.document.XMLFormService]
2011-01-17 10:06:17,765 ERROR
2011-01-17 10:06:19,719 ERROR
2011-01-17 10:06:19,721 ERROR [STDERR]
2011-01-17 10:06:19,721 ERROR [STDERR] at
Source)
Source)
Source)
2011-01-17 10:06:19,722 ERROR [STDERR] at
2011-01-17 10:06:19,723 ERROR [STDERR] at
2011-01-17 10:06:19,724 ERROR [STDERR] at
2011-01-17 10:06:19,725 ERROR [STDERR] at
2011-01-17 10:06:19,725 ERROR [STDERR] at $Proxy157.doBMT(Unknown
Source)
2011-01-17 10:06:19,726 ERROR [STDERR] at
2011-01-17 10:06:19,727 ERROR [STDERR] at
2011-01-17 10:06:19,728 ERROR [STDERR] at
2011-01-17 10:06:19,728 ERROR [STDERR] Caused by:
2011-01-17 10:06:19,728 ERROR [STDERR] ... 142 more
2011-01-17 10:06:19,729 ERROR [STDERR] Caused by:
2011-01-17 10:06:19,729 ERROR [STDERR] at
2011-01-17 10:06:19,729 ERROR [STDERR] ... 145 more
2011-01-17 10:06:19,823 ERROR [com.adobe.workflow.AWS] An exception was thrown with name com.adobe.livecycle.output.exception.OutputException
2011-01-17 10:06:19,908 INFO [PreparedSqlHelper] execute statement:
Here it is.
The report we're running is Reports/KnowYourNeighbour. You can base that on SampleData/KYNSample.xml.
The process in question is Processes/EventTriggerReport. Execute12 sets the variable, templatePath and then generatePDF Ouptut tries to use that to create the PDF
Dan
Ok. I did a mistake. I don't think it worked without the Application. I think I ran the wrong version.
Now I realized the input parameter is of type "document".
I think it actually expects the XDP and not the path to the XDP. I used a ReadRessource step to load the XDP in a document variable and passed that as an input and it worked.
Jasmin
this thread has really helped alot, thanks! It has helped to finally return a document to me! However, the document that is returned does not contain any of the fragments that are attached to the form (.xdp) that I call in the process. So, I pass in "formName.xdp" and I get PDF output back but the fragments that are inserted throughout "formName.xdp" are not pulled in to build the document.
When you look at the formName.xdp document in Designer, the paths to the fragments are relative so an example path is: "...\fragments\frag1.xdp". That path should be correct according to my folder structure (that is if relative paths work). I ported this right into ES 9.0 (9.5 workbench) from 8.2 and it worked just fine as is in 8.2.
Any ideas what could be causing this?
Unfortunately you've fallen foul of a Livecycle bug that makes fragments completely useless for our system and it looks like possibly yours as well.
See this thread: http://forums.adobe.com/message/3117315#3117315
If you ever find a solution that allows you to actually use fragments I'd love to hear it.
Dan
