jaide
AW Web Player file loading problem
Jan 15, 2011 11:53 AM
I have had a problem of publishing my large AW piece to the web as it hangs on the loading files screen of the player. So I rigged a simple test web published piece (two files which jumps back and forth on button click) which initially worked fine on my development machine and also on my website.
I then modified it to testout the PostURL function and now have a file loading problem which seems unrelated to the PostURL function (since I also uploaded a version with that function commented out). The piece hangs in a window with the loading files thermometer stuck and after a minute or two, it times out with an error:
"Error downloading content file. Internal error: Time out. http://www.mywebsite.com/ddyc/Testweb/XTRAS/INETURL.X32". My piece is published to theTestweb folder which also contains the XTRAS folder.
I have checked and reloaded the INETURL.X32 module and still have the problem. Not sure why this second version is failing and also seems to have the same problem as the large production piece. Seems like the player doesn't think the INETURL.X32 file is there when it is.
Any thoughts?
    Jan 15, 2011 12:35 PM   in reply to jaide
    When this happens the first test I do is to enter the filename directly in the browser window. If you get the "file save as" dialog box then the server is sending the file. If the file doesn't come down there are a couple of possibilities to check out. If the server is case sensitive then make sure you have the right case sensitivity in the file name. Another possibility is that the server MIME type isn't set up. If one file works on that same server then the MIME type is most likely set up correctly. However IIS has a way that you can create MIME types that don't apply the whole server using a web.config file.
    If neither of these things explain the problem then I turn to a protocol 'sniffer' tool like Charles (www.charlesproxy.com) or Wiresharkm (www.wireshark.org/) which will track the internet traffic and you can view the requests for the file downloads and the responses from the server.
    HTH,
    Mike
    Jan 16, 2011 8:47 AM   in reply to jaide
    Yeap, gotta add the .x32 mime types.
    See here for a decent guide on prep'ing for Authorware Web Delivery:
    http://www.capemedia.net/whitepapers/Authorware_Web-Delivery-Process_v 1.4.pdf
    HTH
    Erik
    Jan 16, 2011 9:06 AM   in reply to jaide
    It depends on what server you're using. With some servers the MIME type is required for any extension of any file you want to download. It's a good practice.
    Mike
