Search for a record by number
Jan 14, 2011 8:30 AM
I've created two search fields.
Search field 1 - Search by entering a city name (or a partial city name) - this works fine. (I am using the 'colname3' variable for this).
Search field 2 - I want the user to search by number with an exact match, e.g. they enter '123456' to return record '123456' from the database.
I can't seem to get this to work properly, at the moment I'm using the 'colname3' variable below which returns partial results e.g. '123' returns result '123456'.
How can I modify this so the user has to enter the exact number to return the required result?
This is the variable I'm using:
Type: text
Default value: -1
Runtime value: $_GET['jobnumberfield']
This is the SQL statement:
SELECT *
FROM joinversion3
WHERE job_no LIKE %colname3%
    Jan 14, 2011 11:50 AM   in reply to Wookie
    For exact match use = argument instead of LIKE argument. Setup conditional statement where if LIKE form is submitted then run LIKE query elseif exact match form is submitted run exact match query.
    SELECT *
    FROM joinversion3
    WHERE job_no = $colname3
