Dynamic image displays depending on yes / no value
Jan 11, 2011 4:39 AM
I've set up an ENUM column in my MySql database with a value of either 'y' (yes) or 'n' (no)
I have managed to display this record in a php webpage and even modified it to display a dynamic check box which is ticked if the value is 'y'
<input <?php if (!(strcmp($row_rsallJobs['sign_good_condition'],"y"))) {echo "checked=\"checked\"";} ?> type="checkbox" name="good_con" id="good_con" />
What I really want to do is display images depending on the value. For example 'yes.jpg' if the value is 'y' and 'no.jpg' if the value is 'n'.
How can I do this? Could I modify the code above?
    Jan 11, 2011 5:10 AM   in reply to Wookie
    Use a simple conditional statement:
    <img <?php if ($row_rsallJobs['sign_good_condition'] == "y") {
      echo 'src="yes.jpg" alt="yes"';
    } else {
      echo 'src="no.jpg" alt="no"';
    } ?> height="20" width="20" />
    Jan 11, 2011 5:58 AM   in reply to Wookie
    Thanks. Glad to hear you're enjoying the book.
    Jan 17, 2011 11:58 AM   in reply to Wookie
    How could I expand this to 3 possible values? i.e.  - yes / no / maybe
    if/elseif/else
    if (value == "yes") {
    //show yes value
    } elseif (value == "no") {
    // show no value
    } else {
    // show value that doesn't = yes or no
    Jan 18, 2011 7:10 AM   in reply to Wookie
    value$row_DetailRS1['photos_taken'] is not a variable, hence the error message.
    <?php if ($row_DetailRS1['photos_taken'] == "f") {
    print "full";
    } elseif ($row_DetailRS1['photos_taken'] == "p") {
    print "partial";
    } else {
    print "none";
    Sep 22, 2011 4:44 AM   in reply to Wookie
    ..sorry need some help.
    I can´t get it workin.....
    <img <?php $status="n";
    if ($status == "y") {
      echo 'src="stecker_on.png" alt="yes"';
    } else {
      echo 'src="stecker_off.png" alt="no"';
    } ?> height="71" width="101" />
    The image ist not showing... ideas ?
    All I get ist some text showing:
    MANY THANKS !!!!
