nstopak
Undefined filter - JBIGDecode
Jan 14, 2011 10:36 AM
Some of the PDF we attempt to search for barcoded data fail with an error like the one below, apparently due to the use of "JBIG2Decode" encoding.  Is this a known problem/limitation?
Noam
Failure Time----Fri Jan 14 13:30:24 EST 2011
source location ---- Reason of failure is-----Internal error.
Internal error.
com.adobe.internal.pdftoolkit.core.exceptions.PDFInvalidDocumentExcept ion: com.adobe.internal.pdftoolkit.core.exceptions.PDFCosParseException:
Undefined filter - JBIG2Decode; page number: 1
com.adobe.internal.pdftoolkit.core.exceptions.PDFInvalidDocumentExcept ion: com.adobe.internal.pdftoolkit.core.exceptions.PDFCosParseException: Undefined filter - JBIG2Decode; page number: 1
ALC-DSC-000-000: com.adobe.idp.dsc.DSCRuntimeException: Internal error.
at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.transientInvoke (WorkflowDSCInvoker.java:370)
at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.invoke(Workflow DSCInvoker.java:158)
    Jan 15, 2011 11:37 AM   in reply to nstopak
    Was the barcode authored with the PaperFormsBarcode object? If so, was it a PDF417 with compression enabled?
    Steve
    Jan 18, 2011 8:54 AM   in reply to nstopak
    While the LiveCycle Barcoded Forms decoding service is able to locate, read and decode a variety of barcodes, including those produced by non-Adobe tools, there may be fringe cases where a barcode cannot be processed. This may be a fringe case.
    JBIG is an image compression algorithm used to reduce the size of a JPEG image. If the barcode was generated as a JPEG using JBIG, the LiveCycle Barcoded Forms decoder will be unable to decode the barcode. It knows nothing about JBIG. LiveCycle Designer does enable data compression for PDF417 barcodes using the Flate algorithm. The decoder recognizes Flate and de-compresses the data.
    If you can forward the barcode image to stwalker.adobe@gmail.com I can validate.
    Steve
