Java/Flex Project with RDS Support
Jan 20, 2011 2:45 AM
Hi there,
I have been banging my head for a long time now. I am creating a Java/Flex project in eclipse(FB Plugin) with the need to be able to develop the services simultaneously with the UI code. However I am not able to connect to the DS using the wizard.. it says connection refused all the time. I have been googling a lot and seems to be a problem.. has anybody found a solution.. yet.. please help...
    Jan 20, 2011 11:06 AM   in reply to avijitx123
    We could use some information like:
    BlazeDS version
    Turnkey/Tomcat or other appserver.
    DBMS type and version.
    Can you connect and see the samples datasource?
    I would confirm you can connect to your DBMS using some JDBC query tool using the same driver, JDBC URL, etc.  If you can connect in the query tool, confirm your driver jar is correctly located in the tomcat/lib directory (or proper dir for your appserver if not tomcat). Also make sure you are using the correct driver for your dbms version and java version. For instance, Oracle has different drivers for the 1.5 and 1.6 JREs.
