CFSQLTYPE CF_SQL_INTEGER
Jan 24, 2011 Jan 24, 2011
Using ColdFusion 9/Standalone, Access database
Can anyone tell me what this error means (CFSQLTYPE CF_SQL_INTEGER)? I received it while processing a simple form. Is it related to the data being processed or something to do with how the field is defined in Access?
Getting started
6.1K
Valorous Hero , Jan 24, 2011 Jan 24, 2011
<input type="hidden" name="QQS_ID" value="#GetDetail.QQS_ID#">
The error means the value provided for QQS_ID is not an integer.  It looks like you are missing <cfoutput> tags around the input field. So the field literally contains the string "#GetDetail.QQS_ID#", not the value of that variable.
WHERE QQS_ID = #url.QQS_ID#
As an aside, it is good to get into the habit of using cfqueryparam on all query parameters.
Valorous Hero ,
Could you post the code used and the full error message?
Here's the form page and update page:
**** ERROR MESSAGE ****
Invalid data #GetDetail.QQS_ID# for CFSQLTYPE CF_SQL_INTEGER.
The error occurred in C:\ColdFusion9\wwwroot\QQSTracker\QQS_Update2.cfm: line 1
1 : <CFUPDATE datasource="qqstrack" Tablename="Detail">
2 : <cflocation url="Proj_List.cfm">
Resources:
Browser  Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SearchToolbar 1.2; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; InfoPath.2; MS-RTC LM 8)
Remote Address  127.0.0.1
Referrer  http://127.0.0.1:8500/QQSTracker/QQS_Edit2.cfm?QQS_ID=22
Date/Time  24-Jan-11 11:25 AM
**** FORM PAGE ****
<cfquery name="GetDetail" datasource="qqstrack">
SELECT *
FROM detail
</cfquery>
<form action="QQS_Update2.cfm" method="post">
<table width="770" cellpadding="0" cellspacing="0">
<tr>
  <td width="100%" align="center" colspan="3"><img src="images/header_1.jpg" border="0"><br>
  <img src="images/header_2.jpg" border="0"><br><img src="images/boxtop.jpg" border="0"></td>
</tr>
<tr>
  <td width="18" id="sideleft"> </td>
  <td width="744" id="boxinside">
   <cfoutput query="GetDetail">
      <table width="100%" cellpadding="5" cellspacing="0">
    <tr>
     <cfif #ProjectName# IS "No">
     <td valign="top" id="ProjName" colspan="2"><input type="text" name="ProjectName" size="30" value="#ProjectName#"></td>
     <cfelse>
     <td valign="top" id="ProjName" colspan="2">#ProjectName#</td>
     </cfif>
    </tr>
    <tr>
     <td valign="top" width="185" id="leftpane" style="padding:10px">
     <table width="100%" cellpadding="5" cellspacing="2">
      <tr>
       <td valign="top" id="text3"><b>Start Date</b>:
       <input type="text" name="Start_date" size="8" value="#dateformat(Start_Date, "mm/dd/yyyy")#"></td>
      </tr>
      <tr>
       <td valign="top" id="text3"><b>Due Date</b>:
       <input type="text" name="Due_Date" size="8" value="#dateformat(Due_Date, "mm/dd/yyyy")#"></td>
      </tr>
      <tr>
       <td valign="top" id="text3"><b>Target Date</b>:
       <input type="text" name="Target_Date" size="8" value="#dateformat(Target_Date, "mm/dd/yyyy")#"></td>
      </tr>
      <tr>
       <td valign="top" id="text3"><b>Actual Date</b>:
       <input type="text" name="Actual_Date" size="8" value="#dateformat(Actual_Date, "mm/dd/yyyy")#"></td>
      </tr>
      <tr>
       <td valign="top" id="text2"><b>Agency</b><br>
       <input type="text" name="agency" size="20" value="#agency#"></td>
      </tr>
      <tr>
       <td valign="top" id="text2"><b>Lead<b></br>
       <input type="text" name="lead" size="20" value="#lead#"></td>
      </tr>
      <tr>
       <td valign="top" id="text2"><b>Campaign: <b>
        <select name="Campaign">
        <option value="#Campaign#" selected>#Campaign#
        <option value="Infrastructure Building">Infrastructure Building
        <option value="Demand Generation">Demand Generation
        </select></td>
      </tr>
      <tr>
       <td valign="top" id="text2"><b>Funding Source: <b>
        <select name="Funding">
        <option value="#Funding#" selected>#Funding#
        <option value="Campaigns">Campaigns
        </select></td>
      </tr>
     </table>
     </td>
     <td valign="top" width="510" style="padding:10px">
     <table width="100%" cellpadding="0" cellspacing="4">
      <tr>
       <td valign="top" id="rightpane">
       <table width="100%" cellpadding="3" cellspacing="0">
        <tr>
         <td valign="top" id="tableheader">QQS Status</td>
         <td valign="top" id="tableheader">Dev Status</td>
         <td valign="top" id="tableheader">Phase</td>
         <td valign="top" id="tableheadernohr">Target Quarter</td>
        </tr>
        <tr>
         <td valign="top" id="text">
          <select name="Status">
          <option value="#Status#" selected>#Status#
          <option value="Proposed">Proposed
          <option value="QQS sent to vendor">QQS sent to vendor
          <option value="SOW sent to vendor">SOW sent to vendor
          <option value="Submitted for approval">Submitted for approval
          <option value="Approved">Approved
          </select></td>
          <select name="Dev_Status">
          <option value="#Dev_Status#" selected>#Dev_Status#
          <option value="Planned">Planned
          <option value="In-progress">In-progress
          <option value="Completed">Completed
          </select></td>
          <select name="Phase">
          <option value="#Phase#" selected>#Phase#
          <option value="Not Started">Not Started
          <option value="Development">Development
          <option value="On-going">On-going
          </select></td>
         <td valign="top" id="textnohr">
          <select name="Target_Quarter">
          <option value="#Phase#" selected>#Target_Quarter#
          <option value="Q1">Q1
          <option value="Q2">Q2
          <option value="Q3">Q3
          <option value="Q4">Q4
          </select></td>
        </tr>
       </table>
       </td>
      </tr>
      <tr>
       <td valign="top" id="rightpane2">
        <tr>
         <td valign="top" id="tableheader">Project Cost</td>
         <td valign="top" id="tableheader">Q1 Cost</td>
         <td valign="top" id="tableheader">Actual Q1 Cost</td>
         <td valign="top" id="tableheadernohr">Actual Q1 Cost</td>
        </tr>
        <tr>
         <td valign="top" id="text"><input type="text" name="Project_Cost" size="10" value="#Project_Cost#"></td>
         <td valign="top" id="text"><input type="text" name="Q1_Costs" size="10" value="#Q1_Costs#"></td>
         <td valign="top" id="text"><input type="text" name="Actual_q1_Costs" size="10" value="#Actual_q1_Costs#"></td>
         <td valign="top" id="textnohr"><input type="text" name="Agency_Estimate" size="10" value="#Agency_Estimate#"></td>
        </tr>
       </table>
       </td>
      </tr>
</table>
     </td>
    </tr>
    <tr>
     <td valign="top" align="center" colspan="2" style="border-top: solid 1px abcabe;">
     <input type="submit" value="Update">
     </td>
    </tr>
      </table>
   </cfoutput>
  </td>
  </tr>
</table>
</form>
****** UPDATE PAGE *****
Valorous Hero ,
You're right, that was a stupid mistake. Thanks for pointing it out.
I haven't used cfqueryparam before, thanks for the suggestion!
Documentation
