InDesign CS5 Step and Repeat not functioning properly
Dec 20, 2010 9:15 AM
This has been discussed earlier but I am looking for more input.
There are two significant problems with Step and Repeat in InDesign CS5:
1. In the dialog, horizontal and vertical are in reverse order.
2. After stepping an object, the original object remains selected.
Does anyone know why Adobe changed the dialog and behavior from all previous versions of InDesign? I can understand the advantages of the new grid feature, but that could have been implemented without changing the normal step and repeat.
    Dec 20, 2010 10:56 AM   in reply to Printer_Rick
    After I step anything all objects are selected?  It changed in CS3 and then it was dependent on when you clicked the preview button and whether you made changes to the repeat count before or after selecting or deselecting it.  Sandee Cohen answers a question about it in Indesign Mag issue 20.
    As to the rest, IMHO it's just another thing that the engineers made a mistake on.  Like the buttons for vertical justification on a text frame:
    They've lost their relationship to each other so it's hard to see whether you're clicking on middle or bottom; ironically they also take up more space.
    Dec 20, 2010 11:38 AM   in reply to Printer_Rick
    No point in reporting it as a bug, since it will get dismissed as "by design" and not a bug. That doesn't mean it's a GOOD design and sholdn't change, just that filing a bug won't make it happen. File your opinion as a feature request instead (to change an exixiting feature) and it might get reviewed and implemented. Same form...
    Jan 24, 2011 11:30 AM   in reply to Printer_Rick
    3. The stupid "helpful" error message that says it can't add boxes outside of the bounds pasteboard...  It keeps the settings you last used to  step and repeat. But when you add your new count, then tab to change the old offset number, if it happens to go outside of the bounds as it calculates using the old offset number it gives you an error, and reset's your count. It shouldn't give you the error until you hit "ok" (if your objects will go out of the pasteboard). This is rediculous for it to tell you that your settings are wrong when it is judging it off the settings from last time which you are in the process of changing.
    Jan 24, 2011 11:34 AM   in reply to MKPETZ
    Uncheck the Preview box.
    Jan 24, 2011 11:37 AM   in reply to Peter Spier
    It isn't checked
    Jan 24, 2011 11:51 AM   in reply to MKPETZ
    OK, I see that's still a problem. You might have to set the number of duplicates to 1 temporarily or change the order in which you are setting the distances.
    I agree, this is a royal pain.
    Jan 24, 2011 11:55 AM   in reply to Peter Spier
    Exactly. We just end up tabbing, changing the offset values, then change the count. It doesn't make sense.
    Jan 24, 2011 11:59 AM   in reply to MKPETZ
    This might be worth filing a bug. Adobe - Feature Request/Bug Report Form
    Jan 24, 2011 12:23 PM   in reply to Peter Spier
    Bug report filed although it's difficult to compose a decent paragraph descibing the bug as my blood boils over this one. (I hate this bug as much as what's his name hates the never improved Footnotes)
    Jan 24, 2011 1:02 PM   in reply to Daniel Flavin
    You must have been reporting this as I was too. Twice as likely to get it fixed?
