Locked
Web Services name clash with AS top level class
Jan 24, 2011 Jan 24, 2011
Some context:
  •     New to Flex
  •     Using Flash Builder 4
  •     Flex 4.1
I'm trying to connect to a web service and I get the following error:
An error occurred while attempting to resolve the existing model.
ERROR : ActionScript generation is not supported for entities whose names clash with this top level (no package) ActionScript classes.
Entity "Error" clashes with an AS top level class.
Any pointers on how to resolve conflicts with the WSDL object names and AS classes?
2.0K
Adobe Employee ,
This has been resolved in the upcoming version of FB.
A workaround could be to replace the Error in the wsdl with a different word and use the WSDL to generate appropriate classes.
After this you could use the convertResultHandler property (by pointing to your custom function) in the WebService class to actually convert the result to appropriate classes.
By default FB uses a result handler function convertResultHandler defined in com.adobe.serializers.utility.TypeUtility in serializers.swc
Hope this helps.
-Sunil
Jan 25, 2011 Jan 25, 2011
Is this fixed in the Burrito preview?
About convertResultHandler, I defined it as such:
<mx:WebService id="reportingServices" convertResultHandler="WebServiceTest.convertResultHandler" ...>
public static function convertResultHandler(result:*, operation:AbstractOperation):*
But response is caught by the fault handler with "faultCode:DecodingError". Is there a way to define a response handler higher up in the flow for parsing the response?  (It's a multipart/related response)
Aug 06, 2012 Aug 06, 2012
I am importing a Partner WSDL from SalesForce.com and am still getting the same error. Has this ever been fixed?
Jul 02, 2011 Jul 02, 2011
I'm also encountering the same problem with Flash Builder 4.5.
I'm connecting to a web service that also has an "Error" object defined.
Is there any way to resolve this issue?
Jul 16, 2011 Jul 16, 2011
You might want to look at your database field names and make sure you're not using names that match Actionscripts reserved name types.  There's possibly an illegal name in your database field list.
In my case, I had a field called 'classes' in my database that produced the same error. When I changed it to 'myClass' the error was resolved.
I'm not sure if this is useful.
