Closing FLEX current application using AS
Jan 26, 2011 6:59 AM
I use the following code to close the current application using Action Script and JavaScript:
var urlString:String = "javascript:window.opener = self; self.close();";
var request:URLRequest = new URLRequest(urlString);
navigateToURL(request, "_self");
Then I got the message: SecurityError: Error #2121: Security sandbox violation: navigateToURL
Is there a way to solve the problem or should I use another way to close the current application from AS.
    Jan 26, 2011 8:07 AM   in reply to capitainequebec
    Try using ExternalInterface to call JS method in the wrapper html.
    -Gaurav
    http://www.gauravj.com/blog
    Mar 8, 2011 8:18 AM   in reply to capitainequebec
    Have this in your Flex program:
    private function closeProgram():void
          ExternalInterface.call("window.close");
    call it when you need it.
    Mar 8, 2011 8:38 AM   in reply to capitainequebec
    add
    import flash.external.*;
    to your program.
    Mar 8, 2011 8:49 AM   in reply to capitainequebec
    How are you actually running your program?
    Mar 8, 2011 9:06 AM   in reply to capitainequebec
    Not sure if it's working when you are running it from the Builder. Also did you mention it was for AIR? I use my code for a compiled Flex app running in Browser.
    Mar 8, 2011 10:35 AM   in reply to capitainequebec
    The code I am providing is used only for a flex web application. I do not use it, nor recommend it for an AIR application.
    Mar 8, 2011 12:12 PM   in reply to capitainequebec
    See NativeApplication.exit()
