freelanceDesignDeveloper
/opt/adobe/fms installation on Linux
Jan 26, 2011 12:25 PM
Hello Ladies and Gentlemen
I am doing some experiments and learning some stuff for FMS, I have installed
FMS trial version of FMS 4 on a" Linux Redhat Apache" server
but as you know the default installation  from the root of the server is:
/opt/adobe/fms
so instead of installing on http://www.webspace//opt/adobe/fms
it installs from the base server path below the webspace....
but that leaves me confused because if it outside the webspace...how then is an
administrator supposed to see the admin control panel...?
as guys/girls are experienced and experts can anyone advise where would the fms_adminConsole.htm be....
because I do not see anything under my http//www.mydomain/fms_adminConsole.htm or http://ipaddress/fms_adminConsole.htm
also I tried to connect to vod with like: rtmp://ipaddress/vod/instance ...and I see nothing...any ideas...am I doing something wrong in the installation...
when i install FMS...is there a way I should have changed the install directory so it installs inside my webspace....
before install, via SSH i untar the installation file and followed all the instruction in the .pdf installation guide.
so it creates a folder from where I did the install...I can go this unziped folder files in the browser:
http://ipaddress/uninstalled_tar_gz_folder/fms_adminConsole.htm
but I still cannot login to the fms_adminConsole.htm with the correct credentials.
Your help/s is much appreciate...thank you....
    Jan 26, 2011 10:55 PM   in reply to freelanceDesignDeveloper
    I don't know whether i got your set up properly but let me try answering you or letting you know few things.
    First of all there is no need for FMS and web server to be on same machine.
    Second thing there is no need to install FMS under your webspace if you are using same machine.
    FMS comes with default Apache installation which already has "fms_adminConsole.htm" present in its webroot - so you can use that instead if you can afford to run Apache as well your already working web server (may be on different ports)
    I would suggest uninstall your current installation, do fresh install without modifying anything during installation , keep everything default. Once you are done with installation - whatever you want to be available via web, you copy those swf's in your webspace even fms_adminConsole.htm - but i would like to let you know in proper set up you should not make port 1111 open to the world on which Admin Server is running.
    Jan 26, 2011 11:02 PM   in reply to freelanceDesignDeveloper
    I dont think if I exactly got your question correctly, but let me try to enumerate few steps that may help you:
    1. Untar the zip file and run ./installFMS script.
    2. It will install FMS inside /opt/adobe/fms folder.
    3. After installtion make sure that fmsedge and fmamaster process are running on your linux machine, you may try "ps aux | grep fms" command to see if these process are there.
    4. If fmsedge process is running that means, it is listening on 1935 port for rtmp connection on your machine (unless you have modified the fms.ini file to listen on some other port)
    5. Now, you can conenct to this server using any FP swf file (you may like to use the sample video player shipped with fms) using ipaddress e.g. rtmp://ipaddress/application/streamname (for vod example URL will look like as "rtmp://ipaddress/vod/sample")
    6. As far as admin console is concerned, you need to use URL something like http://ipaddress/swfs/fms_adminConsole.swf, but before this make sure doing http://ipaddress shows up with AdobeFlashMediaServer page.
    You may also like to see the logs folder to check for any kind of issue, you can find it inside  /opt/adobe/fms/logs and look to edge.00.log, core.00.log, master.00.log files.
    Hope these steps will help you out.
    Dec 28, 2011 7:54 AM   in reply to freelanceDesignDeveloper
    hi,
    I would like to install FMS on plesk with ssh
    can you send me perform a manipulation please?
    cordialy
    fred
