Don't know if this is correct place or not for this problem. Lately when I try to install a new extension the ext. manager says "cannot install -- you need "Flash 9 or higher", which I already have. This past week I've spent quite a bit of money on extensions that I now cannot install. Any ideas appreciated.
In the past, a message similar to what you are seeing could be avoided by opening the application in question, in this case Flash, and opening Extension Manager, then install the extension.
If that doesn't work, then you may have to reinstall Extension Manager, you can find the installers here: http://www.adobe.com/exchange/em_download/
HTH,
Danilo Celic
I don't have flash as in the program to create flash, only DWCS5. It was my understanding that I do not need to have flash to install and use these extensions. This message appears to say that I need to upgrade my flash PLAYER, which I have done, and even confirmed by going on to the Adobe site and seeing that I have the latest version installed. I DID try reinstalling my DW extension manager, but still no success.
An extension could be for one product only, like Dreamweaver, or it can be for multiple products, such as Flash and Dreamweaver. I don't recall seeing any extensions like the later. Could you provide a link to the extension(s) that your trying to install the give you this message?
If you are installing an extension in Extension Manager and it gives you a message that you need to have Flash 9 or above, then theoretically that means that the extension you are installing has at least some Flash "parts" to it that are supposed to be installed into the Flash application (not the player).
You may want to try to install an extension that is for sure Dreamweaver only. Try this one that one of the Dreamweaver engineers created: http://www.adobe.com/cfusion/exchange/index.cfm?event=extensionDetail& loc=en_us&extid=1739525 I do not have the Flash application installed on the system that I'm writting this one and it installed fine into my Dreamweaver CS5 via the Extension Manager.
Beyond that, since it appears that you bought the extensions, you should contact the extension developers to see if they have any suggestions, as they may have run acorss a similar issue before.
I tried installing "one that one of the Dreamweaver engineers created: http://www.adobe.com/cfusion/exchange/index.cfm?event=extensionDetail& loc=en_us&extid=1739525" into DW CS5 and got the error message "This extension cannot be installed, it requires Dreamweaver version 8 or greater".
Been chasing this for some time reading both Adobe and developer forums to no avail.
