The installer doesn't like Windows 7 64-bit. Does anyone have any hints for getting it to install?
I'm sorry but you're trying to fit a round peg in square hole.
PAGEMAKER 6.0 and earlier are no longer supported at all.
PAGEMAKER 6.5x IS NOT SUPPORTED ON WINDOWS XP
This is what Adobe says:
PageMaker 6.5x, however, may not meet your expectations in Windows XP, since it was released prior to Windows XP and was not developed for this operating system. Adobe Technical Support provides assistance with using PageMaker 6.5x features in Windows XP and with troubleshooting issues that also occur in Windows 2000, NT with Service Pack 5 or 6, ME, 98, or 95.
(As Microsoft now only offer paid support and free critical security updates for Windows 98 until 30th June '06, I suspect support from Adobe for PM6.5x and PM7.x on this platform may also diminish.)
Click here to read Adobe's Support Policy for PageMaker 6.5 and 7.x in Windows XP, from where the above quote was extracted.
So no hope for Windows7. Upgrade to InDesign while there are discounts for PM Licence holders.
Iechyd da! John
20:27 09/11/2009 GMT
Not at all likely. Either keep your old machine or take advantage of Adobe's very generous upgrade offer to InDesign: http://amzn.to/ebRlwu
Bob
Bald Eagle 44 wrote:
Will PM 7.0 work with Windows 7 64-bit?
No. You can try, but I expect the installer will not work properly.
Either move on to InDesign 5 (see it as PageMaker 12 from Adobe) or keep PM7 on your WinXP(?) setup.
I suppose you could use Virtual Windows but you said you don't want to learn anything new.
Yes Claudio, I read the post immediately above my inquiry and used "Search" to find what I was looking for, and also spent about an hour looking for answers elsewhere. The results all referenced PM6.5, not PM7.0. Call it grasping for straws, but I was hoping that there was some subtle difference that would provide a solution without having to blow two hundred bucks for an upgrade for a program that I only use for personal projects. As a retiree living on a fixed income I am forced to sit in a cold, dark room, eating cat food to survive, warmed only by the glow of the computer monitor, waiting for death to come and take me.
Thanks for your help, yap.
Eagle, the update/upgrade from 6.5 to 7 was
almost a joke.
In any case, none of the two versions work in any of the
recent OSs.
If you are not willing to mover on to InDesign, you can always keep an old machine running a suitably old OS and run PM in it.
The warmth you get from a monitor does not seem to depend on OS versions, and cat food will taste just the same...
Despite Adobe's warning, PM v6.5 works just fine on XP. It won't install in Win7 as such, but
if you have Win7 Professional or Ultimate, you can install XP Mode and PM v6.5 (and presumably v7.0)
will run in that. You can download XP Mode at http://www.microsoft.com/windows/virtual-pc/download.aspx
If you have a Home edition of Win7, you'll have to decide whether you prefer to upgrade Win7 or upgrade from PM to another desktop publishing app.
BTW, I'm neither retired nor at a church, though I run PM 6.5. My reason is that I use it primarily to maintain the documentation manual for software that we sell; I'm a software developer, not a graphic designer, and don't want to spend the time and money to learn a completely new app. PM (which I've had since v3) meets my needs, and I don't want to be forced off it.
I am also retired and volunteering for an environmental group. I have Pagemaker 6.5 installed and running under XP Pro. I believe I got there just by copying the whole folder from the Windows 98 computer. Seems as long as you have the resource files in the same folder it runs fine. I'll let you know if the same technique works in Windows 7 if I ever upgrade.
I have used PageMaker since it was release in 1988 and have run my publishing business using it. Imagine my surprise when I upgraded from XP Pro (SP3) to Windows 7 Pro and PageMaker would not install.
All the experts said it wasn't possible . . . HAH!
I read Bob Levine's comment (see previous comment) and I knew what I had to do.
I dug out an old system backup and found the PageMaker program directory where it had been successfully installed (i.e. C:\PageMaker).
Then I created a PageMaker directory in Windows 7 and copied the entire PageMaker directory over from the backup.
Once that was done, I opened a Windows Explorer window and navigated to an existing PageMaker document on my Windows 7 system.
Once I found a PageMaker file, I right clicked on it and selected "Open".
Next, choose "Select a program from a list of installed programs" (See below).
When the Ok button is selected, another window will open. Choose the "Browse" button and navigate to the PageMaker directory and select the PageMaker program.
Voila! You are back in business.
You will need to do the same process for the PageMaker template files "FileName.T65".
Good luck. Please post here if you have had the same success that I have had.
PageMaker 6.5 can be installed on Windows 7, but it is next to impossible
and will never work right again.
Go get yourself a copy of PageMaker 7.0. It is PM6.5 made to run on Windows
7.0.
I have no sympathy for Adobe killing a great product, so get PM7 wherever
you can find it (can you say Pirate Bay?).
No need to post the same message twice, most of us can understand the first time.
I always understood that PM 7 had only minor differences with 6.5, and I am reasonably sure that it came out by the time of Win 2000, and certainly long before Win 7.
WordStar was also a great product at its time. Do you still use it?
Thanks for the feedback everyone - I appreciate them all. I like PageMaker and found it easy to use for what I wanted it for. Downloaded Scriber - so far can't find where the text button is
Tech support even told me that PM 7 would not work right on Windows 7 so...time for something new
Thanks again
Old Typographer wrote:
Not True.
I am running PM7.0 using Windows 7.0 Pro (64 bit).
True. No program can be designed to be compatible with future OSs years before they are released. The fact that some people seem to manage to install PM and run it with negligible or no glitches cannot change this.
It would be interesting if one of such lucky persons shares with the rest of us what generally valid procedure they use to obtain thin amazing fact.
Or better yet, don't.
Because it won't matter. First of all there's no way to guarantee it will work for anyone else and it's a dead end program that has been surpassed by everything else including free applications such as Scribus.
Trying to use PM on Win 7 or Win 8 is going to be nothing but an exercise in futility. While a hobbiest may find it worthwhile you'd have to be insane to use it in a professional environment.
Bob
Bob, my point is that there would be many people, especially in developing countries, that would be most grateful if they were shown a reliable, repeatable way of installing and running faultessly PM in the newer OSs. We all know that there will always be some participants who keep on claiming that it can be done because they have done so, but I have yet to see a single one of them explaining how to achive this reliably and repeatably. And I also have yet to see one stating firmly and clearly that everything in PM works faultessly for him/her, without even a single minor glitch.
And my point is that it's not going to happen. Those "lucky" enough to get it to work are simply installing it. There are just too many variables to come up with a procedure to get this to work reliably.
Perhaps a ritual sacrifice was involved but it doesn't matter. There are better alternatives including those that cost nothing.
Why this keeps coming up is way beyond my comprehension. Just download Scribus for free or stick with an old machine.
Bob
Bob, it seems that, as I grow older, my irony is getting so subtle that only I can see it. My criticism wasn't directed to you, but to those who claim that PM works without a hitch for them... except that they later have questions like my dictionaries aren't working properly, I am having trouble when exporting to PDF, I cannot ...
I'm pleased that software from the last century runs on the latest 64-bit operating system, but please don't expect that to mean it will be same for everyone else.
If you want to run PM as was intended, use a PC with Win2K as the OS.
Otherwise, move on to InDesign (there aren't any discounts for PM licence holders any more) or use a different current product.
