Has anyone had problems with f4v export in AME?
Single pass CBR is OK but when I created a preset with 2 pass VBR (tried various different settings), the encode fails just after it starts the second pass with an error compiling movie - unknown error.
No problems with any other encodes that I know of.
Any ideas?
Paul.
Coincidentally I am having the same problem (or at least a similar problem). I've been trying to output some .f4v files in AME CS5 and, though I am able to successfully render out CBR and VBR 1 pass, it fails when I bump it up to 2 pass. Like the original post, the error occurs at the start of the second pass.
Here are the settings I am trying (as requested by a client for several animated pieces in .MOVs. I can tweak some things, but the goal is to keep the file size down without incurring terrible quality):
- Video: 640x360, Same as source fps, Progressive
- Audio: AAC, 96 kbps, 44.1 kHz, Stereo
- Bitrate: VBR, 2 Pass, Target 0.60 Mbps, Max 10.00 Mbps
- Keyframe Distance: 120 frames
The sources range in frame size and fps, but so far nothing has worked in 2 pass VBR. As soon as I change it to 1 pass or CBR, it works fine.
I've tried cleaning the media cache, but it didn't seem to help. I'm using a 2.66GHz Core i5 iMac with 4 gigs of ram. Let me know if anyone has any thoughts!
Well I have cleared the media cache, but I'm not sure if I cleared them correctly. I've read two possible ways to do this, holding command + option + shift while opening the application and to actually go to /users/preferences/adobe/ and physically delete the preference files there (I'm a bit hesitant to do that entirely, so I've backed up the files just in case that wasn't the proper way to do it). I've tried them both, clearing the cache each time, but it doesn't seem to get my VBR 2 pass working. Perhaps I need to do a complete uninstall/reinstall?
I've tried to play with the bitrate settings quite a bit. Every setting I try fails right at the start of the second pass: my original settings, 2Mbps - 6Mbps you suggested, the Low, Medium, High presets and several other variations.
I've also tried turning off various settings I'm using as well (like resize video, keyframe distance, and audio), and the only thing that seems to be affecting it is when I'm using VBR 2 pass. 1 pass works without a hitch, as does CBR... It just seems like the problem lies with trying to do a second VBR pass.
Thanks for the help so far, I wish I had more success to report back!
UPDATE:
Well, after much failing I finally got it to work... after reinstalling Media Encoder. Luckily I was able to just reinstall that portion of CS5, so it didn't take terribly long.
After that, I remade my preset and BAM! I can now do VBR 2 pass! Weird that it didn't work before, I guess something must have hiccuped during my first install. Perhaps that's what happened to the originial poster? I'd recommend trying an uninstall/reinstall of Media Encoder and seeing if that helps.
Thanks again!
I am having the same problem with the CS5 Media Encoder on 64-bit Windows 7. As soon as the second pass starts, the encode fails and leaves an exclamation point in the Encoder queue. The partially built file cannot be played. This only started happening with the recent 5.0.1 update.
How did you uninstall just the Media Encoder? I would like to try re-installing it but it seems to get installed along with a couple components of CS5, like Flash and InDesign.
Encode Specs:
F4V, no resize, fps same as source, de-interlaced, AAC, 96kbps, 44.1kHz, Stereo, VBR, 2 Pass, Target 0.90 Mbps, Max 1.20 Mbps
Hmm, well I just popped in my install discs and, under Flash, just clicked the box for Adobe Media Encoder. It may have reinstalled Flash as well (I went out and grabbed some food during much of the installing, so I missed the specifics of what happened). I guess that might be a price you'll have to pay in order to get a second pass of VBR...
I guess back up any files, plugins, settings, etc you may have for Flash and reinstall. I can't guarentee that it'll work for you, but I hope it does!
Also, now that you mention it, I *did* do an Adobe update prior to all my issues and I haven't run the updater since reinstalling... Perhaps it's an issue with an update for something? I guess I'll have to see if an update renews my problems... After I finish converting things for my current project.
Thanks for following up. I tried your method of just reinstalling Media Encoder from the install media and watched what it did. I chose the Media Encoder option from InDesign instead of Flash since I don't use that as often. I unchecked everything EXCEPT Media Encoder, but as it ran it still listed all sorts of applications it touched during the install. Once the installer was done, AME was indeed back to release 5.0.0 but when I checked the available updates, almost every component of CS5 was listed as needing updates.
I suspect that just running all of the updates again (without the 5.0.1 update to AME) would work fine, and is probably what you will have to try after you are done with your current project. I happened to have a hard drive image from last week that was taken before I ran the CS5 updates, so I rolled my computer back to that point and installed the updates again (unchecking the AME update). This worked great and I can confirm that Media Encoder stayed at release 5.0.0 and still happily does the second pass on F4V encodes. I'll just wait until version 5.0.2 comes out before I let AME update again. Thanks for posting the information that got me headed in the right direction.
Well, I had the same exact problem and I solved it using info from this post. I figured I would simplify it for those who come to this forum in the future with the same problem by providing a step by step tutorial on how I solved the issue.
1) Close out all Adobe applications.
2) Insert CS5 install Disk 1 into computer.
3) When you get to the install options, click the check box next to Flash Professional.
4) The programs associated with this program will appear to the right. Uncheck all of the applications except media encoder.
5) Re-install media encoder.
6) Update all Adobe software applications.
Hopefully, this will solve the issue.
Sincerely,
Michael Feig
I've tried all of the above without sucess. VBR 1pass and CBR work just fine, but VBR2 hangs and fails at 2nd pass everytime.
I also seem to get the "System running low on memory" message after a failed encoding as well. I allow Premiere to have 4.5GB of my 6GB of system memory. 35GB free space on scratch disk, Core i7 920 and the project is only 3min long.
I've heard that using still images can cause problems. I use tiff files in premiere to make slideshows. What's the issue with still images?
Premiere Pro (pre update) rendered everything just fine, BTW...
So... What gives?
I have the same problem ...
I also get the "System running low on memory" message after a failed encoding as well.
This issue appears only since august 2010. My export settings (f4v, CBR-2) worked fine before.
Josef
Two things I can suggest at a glance.
Trash your preferences (Media Encoder). I'm on a mac as I type this so that one would be user folder>library>preferences>adobe>media encoder>5.0. Take the 5.0 folder and toss it.
The other solution you can try is to;
Dennis
Dennis,
thanks for your fast response:
Thanks again !
Josef
Here are my experiences:
This issue depends on update-level... Adobe please help.
Josef
JoPo999 wrote:
- I update Premiere Pro CS5 from Version 5.0.0 to Version 5.0.2: Rendering 2 pass f4v FAILS !!!
Before I updated, 2 pass f4v worked fine. But with AME 5.0.1, the encoding stops at exactly halfway through.
I had to reinstall CS5 yesterday. I'm going to wait until this issue is fixed before I update AME.
As i see i'm not the only one who have this problem with the 2nd pass i will also post my problem here.
Like the others the encoding stops after the first pass with an "unknown error".
I tried to delete the cache and the 5.0 folder from adobe. Nothing helped. I don't want to reinstall the master collection because there has to be another solution for this!!
I hope i could help to solve this problem.
Thanks in advance ...
I don't have anything useful to add except "Me too."
Win 7 Professional, 64 bit
Adobe Media Encoder CS5 5.0.1.0 (64 bit)
Core i7 920
9GB
NVidia GeForce GTX 260
*Everything* fails on 2-pass now. Used to work fine, but now fails at the start of the second pass. Every single time.
Message was edited by: jookymcfee (Added AME version)
Any news on this Adobe, I can't render out my 2 pass F4V?
http://forums.adobe.com/thread/749586?tstart=0
Regards
Mikael
Yep. To my knowlege Adobe never fixed it. It's terrible really, I've
nearly had CS5 for a year and I can't update my Flash because doing so
updates Media Encoder (which I use a lot) to a version that crashes for me.
I've come to believe Adobe won't get around to it until CS6 or something...
I'd stick to my previous advice: uninstall, reinstall, check to see if VBR 2
pass works and, if so, avoid any Adobe updates (to Flash at least) until
someone reports that the error is fixed.
Anyone know if there's a better way to report errors like these to Adobe
besides posting on the forum and crossing your fingers?
