News feed box
Jan 30, 2011 6:59 AM
<style type="text/css">
#marqueecontainer{
position: relative;
width: 200px; /*marquee width */
height: 200px; /*marquee height */
background-color: white;
overflow: hidden;
border: 3px solid orange;
padding: 2px;
padding-left: 4px;
</style>
<script type="text/javascript">
var delayb4scroll=2000 //Specify initial delay before marquee starts to scroll on page (2000=2 seconds)
var marqueespeed=2 //Specify marquee scroll speed (larger is faster 1-10)
var pauseit=1 //Pause marquee onMousever (0=no. 1=yes)?
////NO NEED TO EDIT BELOW THIS LINE////////////
var copyspeed=marqueespeed
var pausespeed=(pauseit==0)? copyspeed: 0
var actualheight=''
function scrollmarquee(){
if (parseInt(cross_marquee.style.top)>(actualheight*(-1)+8)) //if scroller hasn't reached the end of its height
cross_marquee.style.top=parseInt(cross_marquee.style.top)-copyspeed+"p x" //move scroller upwards
else //else, reset to original position
cross_marquee.style.top=parseInt(marqueeheight)+8+"px"
function initializemarquee(){
cross_marquee=document.getElementById("vmarquee")
cross_marquee.style.top=0
marqueeheight=document.getElementById("marqueecontainer").offsetHeight
actualheight=cross_marquee.offsetHeight //height of marquee content (much of which is hidden from view)
if (window.opera || navigator.userAgent.indexOf("Netscape/7")!=-1){ //if Opera or Netscape 7x, add scrollbars to scroll and exit
cross_marquee.style.height=marqueeheight+"px"
cross_marquee.style.overflow="scroll"
return
setTimeout('lefttime=setInterval("scrollmarquee()",30)', delayb4scroll)
if (window.addEventListener)
window.addEventListener("load", initializemarquee, false)
else if (window.attachEvent)
window.attachEvent("onload", initializemarquee)
else if (document.getElementById)
window.onload=initializemarquee
</script>
<div id="marqueecontainer" onMouseover="copyspeed=pausespeed" onMouseout="copyspeed=marqueespeed">
<div id="vmarquee" style="position: absolute; width: 98%;">
<!--YOUR SCROLL CONTENT HERE-->
<h4>Your scroller contents</h4>
</div>
</div>
This is the code i am using it seems to be working fine when i have only one of these on the page, but if add one more, then the second box does'nt work, infact the two get mixed up.. take a look at it http://www.haramausic.com/test.html, notice how the boxes are mixed up.
Please help. Thank you.
    Jan 30, 2011 11:36 AM   in reply to NeilSBob
    Well the problem with just putting 2 marquees on the same page is you aren't changing your variable names to make each one unique and therefore the script confuses the 2 marquees.
    The solution is to make 2 different marquee IDs:
    #marqueecontainer1{
    position: relative;
    overflow: hidden;
    padding: 2px;
    padding-left: 4px;
    #marqueecontainer2{
    position: relative;
    overflow: hidden;
    padding: 2px;
    padding-left: 4px;
    </style>
    Then you need to use the javascript to activate each one.  Something like this:
    function initializemarquee1(){
    cross_marquee=document.getElementById("vmarquee1")
    marqueeheight=document.getElementById("marqueecontainer1").offsetHeight
    return
    function initializemarquee2(){
    cross_marquee=document.getElementById("vmarquee2")
    marqueeheight=document.getElementById("marqueecontainer2").offsetHeight
    return
    and then you need to call both functions when the page loads:
    window.addEventListener("load", initializemarquee1, false)
    window.attachEvent("onload", initializemarquee1)
    window.onload=initializemarquee1
    window.addEventListener("load", initializemarquee2, false)
    window.attachEvent("onload", initializemarquee2)
    window.onload=initializemarquee2
    Of course this means you need to have 2 different marquees in the body too:
    <div id="marqueecontainer1" onMouseover="copyspeed=pausespeed" onMouseout="copyspeed=marqueespeed">
    <div id="vmarquee1" style="position: absolute; width: 98%;">
    <div id="marqueecontainer2" onMouseover="copyspeed=pausespeed" onMouseout="copyspeed=marqueespeed">
    <div id="vmarquee2" style="position: absolute; width: 98%;">
