Script - To add watermark text with more than 1 line / font size
Jan 31, 2011 4:36 PM
Hi everyone, I've managed to find a cool script that adds a border and some text (if you want it - http://www.oblius.com/projects/photoborder/)
This results in the following -
What I really need is to change the script so I can have 2 lines, centered, the second line in a smaller font, like this:
Any help very appreciated, I know this will be really easy for anyone with script experience (its my 1st day using them!)
Script is:
/* Customizable variables */
// Outer border settings
outerBorderThickness = 10; // Adds to each side (left, right, top,
bottom)
outerBorderColor = new SolidColor(); // RGB Outer Border Color (see next 3 lines)
outerBorderColor.rgb.red = 255; // Red value of outer border
outerBorderColor.rgb.green = 255; // Green value
outerBorderColor.rgb.blue = 255; // Blue value
// Inner border settings
innerBorderThickness = 0; // **Must be smaller than or equal to
outer border**
innerBorderOpacity = 75.0; // Percent value opacity for inner
border
innerBorderColor = new SolidColor(); // RGB Inner Border Color (see next 3 lines)
innerBorderColor.rgb.red = 255; // Red value of outer border
innerBorderColor.rgb.green = 255; // Green value
innerBorderColor.rgb.blue = 255; // Blue value
// Signature
signatureText = "John + Jane www.Sabrina.co.nz"; // Text to place as signature
signatureOffsetX = 370 // From RIGHT edge of document (tweak
these after setting font/size/text etc)
signatureOffsetY = 46 // From BOTTOM edge of document (tweak
signatureFont = "Verdana"; // PostScript font name for signature
signatureFontSize = 5.0; // Font size in Points
signatureOpacity = 100.0 // Opacity for signature
signatureAA = AntiAlias.NONE; // Anti-alias mode (options: NONE, CRISP,
SHARP, etc - same as palette)
signatureColor = new SolidColor(); // RGB Signature Color (see next 3 lines)
signatureColor.rgb.red = 255; // Red value
signatureColor.rgb.green = 255; // Green value
signatureColor.rgb.blue = 255; // Blue value
/* End Customizable Variables */
* BEGIN SCRIPT
// Open sample file if no document is opened.
if (!app.documents.length > 0) {
var fileName = app.path.toString() + "/Samples/Dune.tif";
var docRef = open( File(fileName) );
// Save old units and set to px
oldUnits = app.preferences.rulerUnits;
app.preferences.rulerUnits = Units.PIXELS;
// Save original document size
oldWidth = app.activeDocument.width;
oldHeight = app.activeDocument.height;
// Resize canvas to make room for outer border
newWidth = app.activeDocument.width + (outerBorderThickness*2);
newHeight = app.activeDocument.height + (outerBorderThickness*2);
app.activeDocument.resizeCanvas(newWidth, newHeight, AnchorPosition.MIDDLECENTER);
// Create a layer for the outer border and make it active
var outerBorderLayer = app.activeDocument.artLayers.add();
outerBorderLayer.name = "Black Outer Border";
outerBorderLayer.blendMode = BlendMode.NORMAL;
app.activeDocument.activeLayer = app.activeDocument.layers["Black Outer Border"];
// Select the original image area
selectionBounds = new Array
new Array(outerBorderThickness, outerBorderThickness),
new Array(oldWidth + outerBorderThickness, outerBorderThickness),
new Array(oldWidth + outerBorderThickness, oldHeight + outerBorderThickness),
new Array(outerBorderThickness, oldHeight + outerBorderThickness)
app.activeDocument.selection.select(selectionBounds, SelectionType.REPLACE);
// Fill the outer border area
app.activeDocument.selection.invert();
app.activeDocument.selection.fill(outerBorderColor);
// Create the inner border layer and make it active
var innerBorderLayer = app.activeDocument.artLayers.add();
innerBorderLayer.name = "White Inner Border";
innerBorderLayer.blendMode = BlendMode.NORMAL;
innerBorderLayer.opacity = innerBorderOpacity;
app.activeDocument.activeLayer = app.activeDocument.layers["White Inner Border"];
// Fill the inner border
app.activeDocument.selection.expand(innerBorderThickness);
app.activeDocument.selection.fill(innerBorderColor);
app.activeDocument.selection.contract(innerBorderThickness);
app.activeDocument.selection.clear();
// Deselect
app.activeDocument.selection.deselect();
// Create a text layer
var signatureLayer = app.activeDocument.artLayers.add();
signatureLayer.name = "Signature";
signatureLayer.kind = LayerKind.TEXT;
signatureLayer.opacity = signatureOpacity;
signatureLayer.blendMode = BlendMode.NORMAL;
app.activeDocument.activeLayer = app.activeDocument.layers["Signature"];
// Add signature to text layer and position it
signatureLayer.textItem.contents = signatureText;
signatureLayer.textItem.font = signatureFont;
signatureLayer.textItem.size = signatureFontSize;
signatureLayer.textItem.color = signatureColor;
signatureLayer.textItem.antiAliasMethod = signatureAA;
txtPos = new Array((newWidth - signatureOffsetX), (newHeight - signatureOffsetY));
signatureLayer.textItem.position = txtPos;
// Restore the original ruler units
app.preferences.rulerUnits = oldUnits;
// Clear up memory
outerBorderThickness = null;
outerBorderColor = null;
innerBorderThickness = null;
innerBorderColor = null;
innerBorderOpacity = null;
signatureText = null;
signatureOffsetX = null;
signatureOffsetY = null;
signatureOpacity = null;
signatureFont = null;
signatureFontSize = null;
signatureAA = null;
signatureColor = null;
selectionBounds = null;
newWidth = null;
newHeight = null;
oldWidth = null;
oldHeight = null;
oldUnits = null;
layerRef = null;
signatureLayer = null;
// EOF
