rohsin47
where i can find lc workspace bug free source code?
Jan 31, 2011 11:06 PM
I have adobe livecycle es2 pack installed alongwith workbench 9.0. i need bug free workspace source code for customization. as souce code availabe in live cycle es2 sdk is not what has been described in "customize workspace ui". I don't want to downlaod full live cycle server again or workbench?
i just need patched livecycle workspace source code?
where i can find the zip file or is there any other way to update the same?
    Feb 1, 2011 5:32 AM   in reply to rohsin47
    The source can be found under C:\Adobe\Adobe LiveCycle ES2\LiveCycle_ES_SDK\misc\Process_Management\Workspace\adobe-workspac e-src.zip
    Jasmin
    Feb 1, 2011 7:36 AM   in reply to rohsin47
    It is not clear what version you have (es2 pack?) but there were definite problems with the workspace source code and customization in the ES2 GM release.  These were fixed in SP1 and are also in SP2.
    Note that the workspace source is distributed in both the LC and Workbench installs but the Workbench install may contain the original GM release source, depending on the Workbench version you have.  Workbench 9.5 was released with LC ES 2.5 (aka SP2), but i'm not sure if that even has the updated source.
    To avoid any confusion, you should only use the source from the LC ES2 install.  And to get the latest workspace source you should apply the latest service pack (this would be SP2 at this time) and get the latest ProcessManagement Patch for SP2.  The workspace source is in the zip file at the location indicated in Jasmine's reply.
    Feb 2, 2011 4:09 AM   in reply to rohsin47
    I'm unaware of any way to get the code other than applying the SP (1 or 2) and then applying the latest Process Management QuickFix for the SP you choose.  My opinion is that keeping as current as safely possible is best if you want to benefit from all fixes so I would go with SP2.  SP2 has been out for quite a while so I consider it a safe choice.   The SP2 workbench introduced some new features but fully supports any existing applications so this shouldn't be a problem.  Whatever you choose, testing with your environment is always advised, but I'm sure you would do this anyway,
    Also note that updated workspace source could depend on changes in the server code so taking a newer workspace source and running it against an older version of the server may have problems.  So whatever source you get, you should make sure the server is at least as current.
    Jon
    Jun 14, 2012 11:52 PM   in reply to rohsin47
    Hi, was just going through this post. Can you please let me know what was the issue with the source code of the original release (one without SP1 or SP2)?
