"He said third party programs are suppose to write code to work with Apple, not the other way around. "
Next time, ask him if he can read minds and predict the future perfectly.
No? Well, neither can Apple's developers. We don't know all the bugs Apple has in their code, or what bugs they will add in future versions of the OS. A responsible OS vendor would fix their bugs, make sure their APIs work as documented (esp. don't crash), and test their new OS releases against existing applications to make sure the new OS works correctly.
If we can work around the OS bug, we do. If we know about an OS bug, we avoid it or get it fixed. (that happens a LOT on MacOS)
But we can't read minds or predict the future. Nor can we fix Apple's code for them.
If I were you, I would call Apple and ask for a supervisor - the support person you spoke to was reading a generic problem solving script, not responding to the crashes you reported.
Chris,
I know. This is very frustrating. I knew if I called Apple they would point the finger back to Adobe.
I guess I will just "try" to do the uninstall and reinstall of Photoshop CS4 today.
Well, first I'm going to restart again and try working all day without attaching those external hard drives. Last night I had all the hard drives disconnected and had no crashes. Then, after a couple of hours I had to attach one to get a file and forgot to detach it again. Within 15 minutes I had a crash. It's probably just coincidence but I thought I'd try that prior to unstalling Photoshop.
I'm certain another Apple call is in my future. And, I can't tell you how frustrating it is to pay $185 for what may end up being a code problem with them! I love my Mac though, far better than a PC. I've not had this kind of problem ever.
I'll keep you up to date on the outcome.
Thanks so much for all your help.
You've really been a great help! I really appreciate it!
Dedra
Hi Chris,
Sorry, I didnt mean the actual code. It's just that it's much easier if we know what the problems are. The OP is already getting fingers pointed in both directions. If the crash reports that everyone is sending in point to a problem with the OS then it would be best if we knew what not to do in the meanwhile that its "hopefully" being fixed.
Does "text crash" point to font issues?
I had misc crashes last month and went through some extensive cleaning and organizing, and this seemed to help.
regards
j
No, the "text crash" means that we use a text entry control somewhere in the UI, and the Apple code for that crashes for unknown reasons. It seems worst when opening SFW or ACR, but crashes just about anywhere at any time -- only in MacOS 10.5.x. MacOS 10.4.x hasn't seen that crash at all.
Same things for the QuickDraw crash - it crashes at seemingly random times when the application draws something. Kind of hard to avoid.
If there was something simple you could do to avoid it, we would have already said or done something (like we have for font, TWAIN, and driver crashes).
Hi Chris
Much appreciated.
We buy hardware and software, send in crash reports and it tends to be a one way conversation as we wait for the occasional bug fix and unfortunately get tangled up in trying to repaiir problems that sometimes (as in this case) are not within our ability to fix.
In a way, we are all partnered in business, the Adobe products are critical to our everyday work so I appreciate you taking the time to explain and to know that this is an active process.
regards
j
I had a problem recently that one I thought I fixed because I had duplicate helvetica fonts installed. But i also have a public beta call Flow install which was working fine, so I did not suspect it. I removed the fonts and that seemed to fix the disk error problem. the problem was after one or two adjustments I receive a could not complete because of a disk error warning which could not be dismissed cause a force quit of Photoshop.
However after removing the duplicate fonts all was well and no disk error and for some reason Flow seemed to stop working.
Then I updated to 10.5.7 and all was well then all of a sudden Flow seemed to be working and the disk error returned. So I turned it off and without thinking went and looked at my permissions and either Flow or the 10.5.7 update caused massive permissions damage it took a ver y long time to repair everything and it seemed like just about every file need to be repaired it took a couple of hours.
But Photoshop works well again I think.
I think I will try and turn Flow back on and see if that was the problem. I should mention that though flow is a third party application both Adobe and Apple and I believe Microsoft as wel have a stake of some kind it this application.
I will check it out it does not seem to be the flow software unless it works on the something over time.
but I will assume it was permissions problem ad my startup disk had the permissions set that everyone was read only. The permissions for the admin, Me and the account was fine but you need access for everyone as well.
So I am going to say something on Apples thing is causing changes to the permissions at seemingly random times for a variety of reasons.
So Apple was telling you the correct thing this is a permissions problem and obviously an issue they know about but $185 dollars to tell you this is a bit much.
I'm installing CS3 so I can get some work done without fear of crashing
Process: Adobe Photoshop CS4 [11172]
Path: /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/MacOS/Adobe Photoshop CS4
Identifier: com.adobe.Photoshop
Version: 11.0.1 (11.0.1x20090216 [20090216.r.522 2009/02/16:17:00:00 cutoff; r branch]) (11.0.1)
Code Type: X86 (Native)
Parent Process: launchd [149]
Date/Time: 2009-05-21 11:43:44.430 -0400
OS Version: Mac OS X 10.5.7 (9J61)
Report Version: 6
Anonymous UUID: 9A059F57-309E-4E59-893D-54D405B7DCE2
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00000000096890a8
Crashed Thread: 0
Thread 0 Crashed:
0 com.apple.QD 0x92cf2ea8 _GetDstBits32BGRA + 4
1 com.apple.QD 0x92cb64f0 DevFrameRect + 795
2 com.apple.QD 0x92c7b89d StdRectWithPort + 267
3 com.apple.QD 0x92c7b77b CallRect + 53
4 com.apple.QD 0x92cb61d3 FrameRect + 43
5 com.adobe.Photoshop 0x000ce083 0x1000 + 839811
6 com.adobe.Photoshop 0x00571249 0x1000 + 5702217
7 com.adobe.Photoshop 0x00568ba0 0x1000 + 5667744
8 com.adobe.Photoshop 0x00350997 0x1000 + 3471767
9 com.adobe.Photoshop 0x0006aa63 0x1000 + 432739
10 com.adobe.Photoshop 0x0006af52 0x1000 + 434002
11 com.adobe.Photoshop 0x000629f0 0x1000 + 399856
12 com.adobe.Photoshop 0x0006a7e5 0x1000 + 432101
13 com.adobe.Photoshop 0x00063d65 0x1000 + 404837
14 com.adobe.Photoshop 0x00063ed3 0x1000 + 405203
15 com.adobe.Photoshop 0x0006222f 0x1000 + 397871
16 com.adobe.Photoshop 0x002206aa 0x1000 + 2225834
17 com.adobe.Photoshop 0x00220736 0x1000 + 2225974
18 com.adobe.Photoshop 0x00003912 0x1000 + 10514
19 com.adobe.Photoshop 0x00003839 0x1000 + 10297
Thread 1:
0 libSystem.B.dylib 0x900649c6 kevent + 10
1 libSystem.B.dylib 0x90065155 _pthread_start + 321
2 libSystem.B.dylib 0x90065012 thread_start + 34
Thread 2:
0 libSystem.B.dylib 0x900342ce semaphore_wait_signal_trap + 10
1 libSystem.B.dylib 0x900662c6 _pthread_cond_wait + 1267
2 libSystem.B.dylib 0x900ab539 pthread_cond_wait + 48
3 com.adobe.amt.services 0x04b83552 AMTConditionLock::LockWhenCondition(int) + 46
4 com.adobe.amt.services 0x04b7e995 _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 115
5 com.adobe.amt.services 0x04b835b0 AMTThread::Worker(void*) + 20
6 libSystem.B.dylib 0x90065155 _pthread_start + 321
7 libSystem.B.dylib 0x90065012 thread_start + 34
Thread 3:
0 libSystem.B.dylib 0x9003b46e __semwait_signal + 10
1 libSystem.B.dylib 0x90065dcd pthread_cond_wait$UNIX2003 + 73
2 libGLProgrammability.dylib 0x91afeb32 glvmDoWork + 162
3 libSystem.B.dylib 0x90065155 _pthread_start + 321
4 libSystem.B.dylib 0x90065012 thread_start + 34
Thread 4:
0 libSystem.B.dylib 0x900342da semaphore_timedwait_trap + 10
1 ...ple.CoreServices.CarbonCore 0x96cf047f MPWaitOnSemaphore + 125
2 MultiProcessor Support 0x1e332eff 0x1e303000 + 196351
3 ...ple.CoreServices.CarbonCore 0x96cdd057 PrivateMPEntryPoint + 56
4 libSystem.B.dylib 0x90065155 _pthread_start + 321
5 libSystem.B.dylib 0x90065012 thread_start + 34
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:
Thread 14:
Thread 15:
Thread 16:
Thread 17:
Thread 18:
Thread 19:
2 ...ple.CoreServices.CarbonCore 0x96cdee83 TSWaitOnCondition + 126
3 ...ple.CoreServices.CarbonCore 0x96cbdd6a TSWaitOnConditionTimedRelative + 202
4 ...ple.CoreServices.CarbonCore 0x96cdeb00 MPWaitOnQueue + 208
5 AdobeACE 0x027c138d 0x2790000 + 201613
6 AdobeACE 0x027c0d85 0x2790000 + 200069
7 ...ple.CoreServices.CarbonCore 0x96cdd057 PrivateMPEntryPoint + 56
8 libSystem.B.dylib 0x90065155 _pthread_start + 321
9 libSystem.B.dylib 0x90065012 thread_start + 34
Thread 20:
Thread 21:
Thread 22:
Thread 23:
Thread 24:
Thread 25:
Thread 26:
Thread 27:
Thread 28:
Thread 29:
Thread 30:
Thread 31:
Thread 32:
Thread 33:
Thread 34:
0 libSystem.B.dylib 0x900343a6 mach_wait_until + 10
1 libSystem.B.dylib 0x900ab3ad nanosleep + 314
2 com.adobe.PSAutomate 0x23d7f755 ScObjects::Thread::sleep(unsigned int) + 143
3 com.adobe.PSAutomate 0x23d7f7b5 ScObjects::Thread::wait(unsigned int) + 23
4 com.adobe.PSAutomate 0x23d70502 ScObjects::BridgeTalkThread::run() + 332
5 com.adobe.PSAutomate 0x23d7fa77 ScObjects::Thread::go(void*) + 239
Thread 35:
0 libSystem.B.dylib 0x90034286 mach_msg_trap + 10
1 libSystem.B.dylib 0x9003ba7c mach_msg + 72
2 com.apple.CoreFoundation 0x9477704e CFRunLoopRunSpecific + 1790
3 com.apple.CoreFoundation 0x94777cd4 CFRunLoopRun + 84
4 com.apple.DesktopServices 0x90614e17 TSystemNotificationTask::SystemNotificationTaskProc(void*) + 123
5 ...ple.CoreServices.CarbonCore 0x96cdd057 PrivateMPEntryPoint + 56
Thread 36:
4 com.apple.DesktopServices 0x90614f90 TFSEventsNotificationTask::FSEventsNotificationTaskProc(void*) + 216
Thread 37:
5 com.apple.DesktopServices 0x9061ff72 TNodeSyncTask::SyncTaskProc(void*) + 84
6 ...ple.CoreServices.CarbonCore 0x96cdd057 PrivateMPEntryPoint + 56
7 libSystem.B.dylib 0x90065155 _pthread_start + 321
8 libSystem.B.dylib 0x90065012 thread_start + 34
Thread 38:
Thread 39:
0 libSystem.B.dylib 0x900836fa select$DARWIN_EXTSN + 10
Thread 40:
5 com.adobe.CameraRaw 0x275bd438 0x27402000 + 1815608
6 com.adobe.CameraRaw 0x275bcd36 0x27402000 + 1813814
Thread 41:
Thread 42:
Thread 43:
Thread 44:
Thread 45:
Thread 46:
Thread 47:
Thread 48:
Thread 49:
Thread 50:
Thread 51:
Thread 52:
Thread 53:
Thread 54:
Thread 55:
3 com.adobe.CameraRaw 0x2744703a 0x27402000 + 282682
4 com.adobe.CameraRaw 0x276f8374 EntryFM + 802340
5 com.adobe.CameraRaw 0x274e70e6 0x27402000 + 938214
Thread 56:
4 com.adobe.CameraRaw 0x27787f88 EntryFM + 1391160
Thread 57:
0 libSystem.B.dylib 0x900342e6 semaphore_timedwait_signal_trap + 10
1 libSystem.B.dylib 0x900662af _pthread_cond_wait + 1244
2 libSystem.B.dylib 0x90067b33 pthread_cond_timedwait_relative_np + 47
3 com.apple.Foundation 0x93034dcc -[NSCondition waitUntilDate:] + 236
4 com.apple.Foundation 0x93034be0 -[NSConditionLock lockWhenCondition:beforeDate:] + 144
5 com.apple.Foundation 0x93034b45 -[NSConditionLock lockWhenCondition:] + 69
6 com.apple.AppKit 0x90f9fd20 -[NSUIHeartBeat _heartBeatThread:] + 753
7 com.apple.Foundation 0x92feee0d -[NSThread main] + 45
8 com.apple.Foundation 0x92fee9b4 __NSThread__main__ + 308
9 libSystem.B.dylib 0x90065155 _pthread_start + 321
10 libSystem.B.dylib 0x90065012 thread_start + 34
Thread 58:
3 data_flow 0x03ba02b2 boost::detail::condition_impl::do_wait(_opaque_pthread_mutex_t*) + 24
4 data_flow 0x03b9365b void boost::condition::do_wait<boost::recursive_mutex>(boost::recursive_mu tex&) + 51
5 data_flow 0x03b96061 boost::threadpool::detail::pool_core<boost::threadpool::prio_task_fun c, boost::threadpool::prio_scheduler, boost::threadpool::static_size, boost::threadpool::resize_controller, boost::threadpool::wait_for_all_tasks>::execute_task() volatile + 135
6 data_flow 0x03b96bba boost::threadpool::detail::worker_thread<boost::threadpool::detail::p ool_core<boost::threadpool::prio_task_func, boost::threadpool::prio_scheduler, boost::threadpool::static_size, boost::threadpool::resize_controller, boost::threadpool::wait_for_all_tasks> >::run() + 232
7 data_flow 0x03b9390b boost::_bi::bind_t<void, boost::_mfi::mf0<void, boost::threadpool::detail::worker_thread<boost::threadpool::detail::p ool_core<boost::threadpool::prio_task_func, boost::threadpool::prio_scheduler, boost::threadpool::static_size, boost::threadpool::resize_controller, boost::threadpool::wait_for_all_tasks> > >, boost::_bi::list1<boost::_bi::value<boost::shared_ptr<boost::threadpo ol::detail::worker_thread<boost::threadpool::detail::pool_core<boost:: threadpool::prio_task_func, boost::threadpool::prio_scheduler, boost::threadpool::static_size, boost::threadpool::resize_controller, boost::threadpool::wait_for_all_tasks> > > > > >::operator()() + 43
8 data_flow 0x03b95fd1 boost::function0<void, std::allocator<boost::function_base> >::operator()() const + 79
9 data_flow 0x03ba1bc5 thread_proxy + 99
10 libSystem.B.dylib 0x90065155 _pthread_start + 321
11 libSystem.B.dylib 0x90065012 thread_start + 34
Thread 59:
Thread 60:
Thread 61:
Thread 62:
Thread 63:
Thread 64:
Thread 65:
Thread 66:
Thread 67:
Thread 68:
Thread 69:
Thread 70:
Thread 71:
Thread 72:
Thread 73:
Thread 74:
3 ...ple.CoreServices.CarbonCore 0x96cbdd96 TSWaitOnConditionTimedRelative + 246
4 ...ple.CoreServices.CarbonCore 0x96cbdb76 TSWaitOnSemaphoreCommon + 422
5 ...ple.CoreServices.CarbonCore 0x96cbd877 AsyncFileThread(void*) + 73
Thread 75:
5 com.apple.DesktopServices 0x90621ebc TFolderSizeTask::FolderSizeTaskProc(void*) + 104
Thread 76:
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x096890a8 ebx: 0x0000003f ecx: 0xbfffed9e edx: 0x096890a8
edi: 0xbfffefe8 esi: 0xbfffed86 ebp: 0xbfffea48 esp: 0xbfffe9ec
ss: 0x0000001f efl: 0x00010292 eip: 0x92cf2ea8 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0x096890a8
Binary Images:
0x1000 - 0x19aefdf +com.adobe.Photoshop 11.0.1 (11.0.1x20090216 [20090216.r.522 2009/02/16:17:00:00 cutoff; r branch]) (11.0.1) <5151e2340b0a4c1da3dea7ac2285e24e> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/MacOS/Adobe Photoshop CS4
0x207f000 - 0x2084fff org.twain.dsm 1.9.3 (1.9.3) /System/Library/Frameworks/TWAIN.framework/Versions/A/TWAIN
0x208d000 - 0x246701f +com.adobe.linguistic.LinguisticManager 4.0.0 (7863) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/Adob eLinguistic
0x251b000 - 0x2715fcf +AdobeOwl ??? (???) <4cca2c7b48964ddaa14b725fb0c202b5> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
0x2790000 - 0x289dfff +AdobeACE ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
0x28bb000 - 0x2c85fef +AdobeMPS ??? (???) <277e01a3cac34fa9a5914bc0a5bc125a> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
0x2d14000 - 0x2d74fc7 +AdobeXMP ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
0x2d83000 - 0x307efff +AdobeAGM ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
0x313e000 - 0x33d1fe7 +AdobeCoolType ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeC oolType
0x3455000 - 0x346efff +AdobeBIB ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
0x3478000 - 0x3499ff7 +AdobeBIBUtils ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeB IBUtils
0x34a6000 - 0x34c1ff9 +AdobePDFSettings ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/Ado bePDFSettings
0x34db000 - 0x34ffff6 +AdobeAXE8SharedExpat ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A /AdobeAXE8SharedExpat
0x3512000 - 0x359f2cb +libicucnv.dylib.36.0 ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/ICUConverter.framework/Versions/3.6/libic ucnv.dylib.36.0
0x35cc000 - 0x35e780f +libicudata.dylib.36.0 ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/ICUData.framework/Versions/3.6/libicudata .dylib.36.0
0x35ea000 - 0x37a0ff4 +com.adobe.amtlib amtlib 2.0.1.10077 (2.0.1.10077) <cb2ec3bf67714dabbf296775fb6f9608> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
0x37d7000 - 0x3867fc3 +WRServices ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/WRServices.framework/Versions/A/WRService s
0x39e9000 - 0x39edffc +com.adobe.AdobeCrashReporter 2.5 (3.0.20080806) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/A dobeCrashReporter
0x39f3000 - 0x3a0ffd7 +com.adobe.LogTransport 1.0 (1.0) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/LogTransport.framework/Versions/A/LogTran sport
0x3a1a000 - 0x3aeffdd +FileInfo ??? (???) <f0932f89fc984ba9b4f2c58d0e71d3c1> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
0x3b20000 - 0x3b77fff +aif_core ??? (???) <b4dcb439e1eeabe3bd122c42e980366b> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
0x3b8f000 - 0x3bacffd +data_flow ??? (???) <8e452b6f803239d8eb5c49a4e31cb988> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/data_flow.framework/Versions/A/data_flow
0x3bd8000 - 0x3c51fff +image_flow ??? (???) <498a857df8c6f9e0c92fbc3ec8680ed0> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/image_flow.framework/Versions/A/image_flo w
0x3cb7000 - 0x3cc7fff +image_runtime ??? (???) <f379a95229831e44676dbbd8259f131a> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/image_runtime.framework/Versions/A/image_ runtime
0x3cdc000 - 0x3e9bffe +aif_ogl ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
0x3f4c000 - 0x444afc3 +AdobeOwlCanvas ??? (???) <fcb2d1a31f6e41828e2cd0b23572d285> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeOwlCanvas.framework/Versions/A/Adobe OwlCanvas
0x4593000 - 0x4665fe7 +AdobeAXEDOMCore ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/Adob eAXEDOMCore
0x4719000 - 0x477bfe7 +com.adobe.PlugPlug 1.0.0.73 (1.0.0.73) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
0x47dc000 - 0x4823fc7 +com.adobe.adobe_caps adobe_caps 2.0.99.0 (2.0.99.0) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_cap s
0x4833000 - 0x4872fff com.apple.vmutils 4.1 (104) <ce02dba5e2e99fa2eb41a81bc9680985> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutil s
0x4b50000 - 0x4b51fe1 com.apple.textencoding.unicode 2.2 (2.2) <09ac11c81bf4e673a30cc364868fdc11> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x4b63000 - 0x4c04fc3 +com.adobe.amt.services AMTServices 2.0.1.10077 (BuildVersion: 53.352460; BuildDate: Tue Jul 29 2008 16:31:09) (2 . 0) <31e82904c3c2424ea1aea5efadbb19b8> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/amtservices.framework/Versions/a/amtservi ces
0x4dad000 - 0x4daffff +com.unsanity.menuextraenabler 1.0.3 (1.0.3) /Library/InputManagers/Menu Extra Enabler/Menu Extra Enabler.bundle/Contents/MacOS/Menu Extra Enabler
0x4de1000 - 0x4deffeb libSimplifiedChineseConverter.dylib ??? (???) <c3123eb807ed45151fe0d12da8e51d04> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter. dylib
0x4df4000 - 0x4df5ff3 ATSHI.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
0x4f00000 - 0x4f12fff libTraditionalChineseConverter.dylib ??? (???) <8a2b4c7bfd8d7941fcf64a2575095e36> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter .dylib
0x4f80000 - 0x4f8dff7 +com.adobe.asneu.framework asneu version 1.6.2f01 (1.6.2) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/asneu.framework/Versions/a/asneu
0x4f9b000 - 0x4f9bffd libmx.A.dylib ??? (???) /usr/lib/libmx.A.dylib
0x4f9f000 - 0x4fa1ffa +Adobe Unit Types a2.0.0 (2.0.0) /Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types
0x1914d000 - 0x19157ffe com.apple.URLMount 3.1.1 (3.1.1) <0189760dca64cd07c190e1a7b10283e5> /System/Library/PrivateFrameworks/URLMount.framework/URLMount
0x19896000 - 0x19899fff +com.stclairsoft.DefaultFolderX.osax Default Folder X Addition version 1.0 (4.2d11) <20ae7639d6757ddcf4bc4056fe20f03c> /Users/beige/Library/ScriptingAdditions/Default Folder X Addition.osax/Contents/MacOS/Default Folder X Addition
0x1c1d2000 - 0x1c1f3feb +com.stclairsoft.DefaultFolderX.CarbonPatcher kBundleVersion (kBundleVersion) <8b93f82fae47535ac5ac173ee8e6040b> /Users/beige/Library/PreferencePanes/Default Folder X.prefPane/Contents/Resources/Default Folder X.bundle/Contents/Resources/Carbon Patcher.bundle/Contents/MacOS/Carbon Patcher
0x1c200000 - 0x1c21eff7 +Cocoa Patcher ??? (???) <f334cea477fc7dfa50ece44251cb5a78> /Users/beige/Library/PreferencePanes/Default Folder X.prefPane/Contents/Resources/Default Folder X.bundle/Contents/Resources/Cocoa Patcher.bundle/Contents/MacOS/Cocoa Patcher
0x1c2b5000 - 0x1c2baff3 libCGXCoreImage.A.dylib ??? (???) <3a78abc535c80f9819931b670da804a2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage. A.dylib
0x1c5d4000 - 0x1c7ccfff com.apple.RawCamera.bundle 2.0.14 (436) <a8dd51882088fae463f33bc0674583e8> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamer a
0x1c935000 - 0x1c944fe3 +FontAgent Pro ??? (???) <cd990c15489c946a041b570f3f9879ed> /Applications/Adobe Photoshop CS4/Plug-ins/FontAgent Pro.plugin/Contents/MacOS/FontAgent Pro
0x1ca48000 - 0x1cbcdfe3 GLEngine ??? (???) <3bd4729832411ff31de5bb9d97e3718d> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle /GLEngine
0x1cbfb000 - 0x1ced9ff1 com.apple.ATIRadeonX2000GLDriver 1.5.44 (5.4.4) <aeb5e93202779fb8e0f5da88291ce9f6> /System/Library/Extensions/ATIRadeonX2000GLDriver.bundle/Contents/Mac OS/ATIRadeonX2000GLDriver
0x1cf3d000 - 0x1cf59ff7 GLRendererFloat ??? (???) <927b7d5ce6a7c21fdc761f6f29cdf4ee> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRe ndererFloat.bundle/GLRendererFloat
0x1e0a2000 - 0x1e0adfff +Enable Async IO ??? (???) <fd91e79fc4aa4ebcaf6d3e154f14878f> /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/Enable Async IO.plugin/Contents/MacOS/Enable Async IO
0x1e0b2000 - 0x1e0bdfff +UseOldShortcuts ??? (???) <a9de9f74fcf34c1cacf5cc296335f84d> /Applications/Adobe Photoshop CS4/Plug-ins/UseOldShortcuts.plugin/Contents/MacOS/UseOldShortcuts
0x1e0c2000 - 0x1e0d002f +FastCore ??? (???) <f12878b7bee940ca9f0565cd0f5688e2> /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/FastCore.plugin/Contents/MacOS/FastCore
0x1e0d6000 - 0x1e0e1ffb +PPCCore ??? (???) <ed521eb7681d45aa9ae36bf4663e4bd3> /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/PPCCore.plugin/Contents/MacOS/PPCCore
0x1e0e7000 - 0x1e0f2ffe +AltiVecCore ??? (???) <a967ae2af2ae4e12a7b668b981cbd906> /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/AltiVecCore.plugin/Contents/MacOS/AltiVecCore
0x1e200000 - 0x1e265fe3 +MMXCore ??? (???) <e206c8dcaea849df8fbc8b447e3a59a1> /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/MMXCore.plugin/Contents/MacOS/MMXCore
0x1e303000 - 0x1e34aff7 +MultiProcessor Support ??? (???) <001a163b53144613a23af35b63065fd0> /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
0x1e366000 - 0x1e4b8fc7 +com.adobe.coretech.adm 3.10x16 (3.1) /Applications/Adobe Photoshop CS4/Plug-ins/ADM/AdobeADM.bundle/Contents/MacOS/AdobeADM
0x1f30e000 - 0x1f31bfff +com.alienskin.autolayer2 2.0.1 (2.0.1) <420807129f42aa6e0264f66de8c18c6b> /Applications/Adobe Photoshop CS4/Plug-ins/Alien Skin/Autolayer2.plugin/Contents/MacOS/Autolayer2
0x20432000 - 0x20432fff +com.insidersoftware.fontagentpro.pluginsupportframework FontAgent Pro 4.0.3 build 41A6 (4.0.3) <1a613241bd6d4f4a8d3cad85995d88cd> /Library/Frameworks/FAProPluginSupport.framework/FAProPluginSupport
0x23c4b000 - 0x23ea7fdf +com.adobe.PSAutomate 11.0 (11.0) /Applications/Adobe Photoshop CS4/Plug-ins/Extensions/ScriptingSupport.plugin/Contents/MacOS/Script ingSupport
0x2413b000 - 0x24209fff +AdobeExtendScript ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/Ad obeExtendScript
0x24280000 - 0x24321fd7 +AdobeScCore ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScC ore
0x243be000 - 0x243e1ff7 +CSI-Launcher.dylib ??? (???) /Library/Application Support/Adobe/CS4ServiceManager/CSI-Launcher.dylib
0x24b92000 - 0x24bc3fe3 +com.adobe.amt.registration AMTRegistration 2.0.1.10077 (BuildVersion: 53.352460; BuildDate: Tue Jul 29 2008 16:31:09) (2 . 0) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/registration.framework/Versions/a/registr ation
0x24de2000 - 0x25264fe3 +AdobeLM_libFNP.dylib ??? (???) <02e9ac769cc64974af0548e737c2cc20> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/amtlib.framework/Versions/a/AdobeLM_libFN P.dylib
0x2538e000 - 0x253eaff2 +AdobeUpdater ??? (???) <064cfaa41caf46e3bebf04948641c927> /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeUpdater.framework/Versions/a/AdobeUp dater
0x27402000 - 0x27b09ff9 +com.adobe.CameraRaw 5.3 (5.3.0f21) <077769d6e7737a315c4fb417c2ae4dcd> /Library/Application Support/Adobe/Plug-Ins/CS4/File Formats/Camera Raw.plugin/Contents/MacOS/Camera Raw
0x2f40b000 - 0x2f479fd7 + ??? (???)
0x35ced000 - 0x35df4fcf +com.adobe.versioncue ??? (4.0.1.095) /Library/Application Support/Adobe/Adobe Version Cue CS4/Client/4.0.1/VersionCue.framework/VersionCue
0x40000000 - 0x400ae030 +AdobeJP2K ??? (???) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
0x8fe00000 - 0x8fe2db43 dyld 97.1 (???) <9736a715ebabb914fef61680520dc1e0> /usr/lib/dyld
0x90003000 - 0x90019fff com.apple.DictionaryServices 1.0.0 (1.0.0) <7d20b8d1fb238c3e71d0fa6fda18c4f7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/DictionaryServices.framework/Versions/A/DictionaryServices
0x9001a000 - 0x90026ff9 com.apple.helpdata 1.0.1 (14.2) /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpD ata
0x90033000 - 0x9019aff3 libSystem.B.dylib ??? (???) <b47c8e6e45aef620730710a732bf1930> /usr/lib/libSystem.B.dylib
0x9019b000 - 0x9024bfff edu.mit.Kerberos 6.0.13 (6.0.13) <804bd1b3f08fb57396781f012006367c> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x9024c000 - 0x9028bfff com.apple.CoreMediaIOServicesPrivate 15.0 (15.0) /System/Library/PrivateFrameworks/CoreMediaIOServicesPrivate.framewor k/Versions/A/CoreMediaIOServicesPrivate
0x9028c000 - 0x90290fff libGIF.dylib ??? (???) <3578a8fe9fb40ab4abf8f3c8356320c2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x90291000 - 0x90335fec com.apple.CFNetwork 438.10 (438.12) <fde64bbb20532794396fb21911ccaa98> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CFNetwork.framework/Versions/A/CFNetwork
0x90336000 - 0x90367ffb com.apple.quartzfilters 1.5.0 (1.5.0) <92b4f39479fdcabae0d8f53febd22fad> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qua rtzFilters.framework/Versions/A/QuartzFilters
0x90368000 - 0x90368ffa com.apple.CoreServices 32 (32) <373d6a888f9204641f313bc6070ae065> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServ ices
0x90369000 - 0x90391ff7 com.apple.shortcut 1.0.1 (1.0) <131202e7766e327d02d55c0f5fc44ad7> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Short cut
0x90392000 - 0x90392ffd com.apple.Accelerate.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/vecLib
0x90393000 - 0x903cafff com.apple.SystemConfiguration 1.9.2 (1.9.2) <eab546255ac099b9616df999c9359d0e> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/S ystemConfiguration
0x903cb000 - 0x903cbff8 com.apple.Cocoa 6.5 (???) <a1bc9247cf65c20f1a44d0973cbe649c> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x903cc000 - 0x903f5fff com.apple.CoreMediaPrivate 15.0 (15.0) /System/Library/PrivateFrameworks/CoreMediaPrivate.framework/Versions /A/CoreMediaPrivate
0x903f6000 - 0x905c7ffb com.apple.security 5.0.5 (36371) <c13e0bb1acfdcf94be4d3ee118ef190e> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x905c8000 - 0x90602fe7 com.apple.coreui 1.2 (62) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x90603000 - 0x90612ffe com.apple.DSObjCWrappers.Framework 1.3 (1.3) <182986b74247b459b2a67a47071bdc6b> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A /DSObjCWrappers
0x90613000 - 0x9069dfe3 com.apple.DesktopServices 1.4.8 (1.4.8) <3065de6531ce839c7cb5b6dd70e03f4f> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versi ons/A/DesktopServicesPriv
0x906d9000 - 0x907c1ff3 com.apple.CoreData 100.2 (186.1) <8fb61e1714a4b8d587ce97605ad32547> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x90846000 - 0x9086ffff libcups.2.dylib ??? (???) <1b0435164b9dc6c773d0b1f24701e554> /usr/lib/libcups.2.dylib
0x90ec2000 - 0x90ef1fe3 com.apple.AE 402.3 (402.3) <b13bfda0ad9314922ee37c0d018d7de9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/AE.framework/Versions/A/AE
0x90ef2000 - 0x90ef8fff com.apple.print.framework.Print 218.0.3 (220.2) <5b7f4ef7c2df36aff9605377775781e4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Pri nt.framework/Versions/A/Print
0x90ef9000 - 0x916f7fef com.apple.AppKit 6.5.7 (949.46) <a80f8cb62f6bdcb3bed3c8675d55881d> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x916f8000 - 0x9183eff7 com.apple.ImageIO.framework 2.0.4 (2.0.4) <bf2299657a0600d4d4bc1f0b45ce2252> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/ImageIO
0x9183f000 - 0x9190afff com.apple.ColorSync 4.5.1 (4.5.1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ColorSync.framework/Versions/A/ColorSync
0x9190b000 - 0x9194cfe7 libRIP.A.dylib ??? (???) <69bd09fcd8d8b235cee7a405290d6818> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x9195d000 - 0x91a3eff7 libxml2.2.dylib ??? (???) <068cab13eb4608a7c6a5fad807ee0e33> /usr/lib/libxml2.2.dylib
0x91a3f000 - 0x91a49feb com.apple.audio.SoundManager 3.9.2 (3.9.2) <df077a8048afc3075c6f2d9e7780e78e> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Car bonSound.framework/Versions/A/CarbonSound
0x91a4a000 - 0x91ad6ff7 com.apple.framework.IOKit 1.5.2 (???) <97b9f9d584f48891377f0481b9104434> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x91ad7000 - 0x91fa8fbe libGLProgrammability.dylib ??? (???) <7f18294a7bd0b6afe4319f29187fc70d> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LProgrammability.dylib
0x91fa9000 - 0x920e1fe7 com.apple.imageKit 1.0.2 (1.0) <c5d490cabf34706b82e70d6b900f3df6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Ima geKit.framework/Versions/A/ImageKit
0x920e2000 - 0x920e4ff5 libRadiance.dylib ??? (???) <232d7e7bbe8c65c16098bc1a52b30b9b> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x920e5000 - 0x92109fff libxslt.1.dylib ??? (???) <f0872c9ba3c17861fba8c45a3647cee1> /usr/lib/libxslt.1.dylib
0x9226e000 - 0x9226efff com.apple.Carbon 136 (136) <8ae1cd25fd33db22d69ecbd5f5103227> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x9226f000 - 0x9242bff3 com.apple.QuartzComposer 2.1 (106.13) <645bdfea218d17e8a51cc7fee78d9cd3> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qua rtzComposer.framework/Versions/A/QuartzComposer
0x9242c000 - 0x9242efff com.apple.securityhi 3.0 (30817) <547bdd9ce4e7276d9bdc137d4caf9c3f> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Sec urityHI.framework/Versions/A/SecurityHI
0x9242f000 - 0x92754fe2 com.apple.QuickTime 7.6.0 (1291) <07b7f2aca9aa205e9bd202f0cfa28c19> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x92755000 - 0x927c7fff com.apple.PDFKit 2.1.2 (2.1.2) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDF Kit.framework/Versions/A/PDFKit
0x927d2000 - 0x9281bfef com.apple.Metadata 10.5.2 (398.25) <281076cdaea1362e02b6892b93d16bbb> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/Metadata.framework/Versions/A/Metadata
0x9281c000 - 0x92837ffb libPng.dylib ??? (???) <ae92a25664039afc82409484407d5e83> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x9290f000 - 0x929c1ffb libcrypto.0.9.7.dylib ??? (???) <9d714c92872a93dd127ea8556b2c8945> /usr/lib/libcrypto.0.9.7.dylib
0x929c2000 - 0x92a13ff7 com.apple.HIServices 1.7.0 (???) <a2352abae2b8b44a95a8a76c8e111d36> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/HIServices.framework/Versions/A/HIServices
0x92a26000 - 0x92a2dfe9 libgcc_s.1.dylib ??? (???) <e280ddf3f5fb3049e674edcb109f389a> /usr/lib/libgcc_s.1.dylib
0x92b10000 - 0x92b10ff8 com.apple.ApplicationServices 34 (34) <ee7bdf593da050bb30c7a1fc446eb8a6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/A pplicationServices
0x92b48000 - 0x92b50fff com.apple.DiskArbitration 2.2.1 (2.2.1) <2664eeb3a4d0c95a21c089892a0ae8d0> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskA rbitration
0x92b51000 - 0x92c08ff3 com.apple.QTKit 7.6 (1291) /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x92c09000 - 0x92c10ffe libbsm.dylib ??? (???) <fa7ae5f1a621d9b69e7e18747c9405fb> /usr/lib/libbsm.dylib
0x92c11000 - 0x92c50fef libTIFF.dylib ??? (???) <745ad643ca5bde81a88c0cdc8c942380> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x92c51000 - 0x92c55fff libmathCommon.A.dylib ??? (???) /usr/lib/system/libmathCommon.A.dylib
0x92c56000 - 0x92c6eff7 com.apple.CoreVideo 1.6.0 (20.0) <c0f8e729d9876e91f79f9c3b6b13beb0> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x92c6f000 - 0x92d16feb com.apple.QD 3.11.56 (???) <a94d0f5438b730e88e5efdb233295c52> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/QD.framework/Versions/A/QD
0x92e97000 - 0x92ef3ff7 com.apple.htmlrendering 68 (1.1.3) <1c5c0c417891b920dfe139385fc6c155> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTM LRendering.framework/Versions/A/HTMLRendering
0x92ef4000 - 0x92f09ffb com.apple.ImageCapture 5.0.2 (5.0.2) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ima geCapture.framework/Versions/A/ImageCapture
0x92f0a000 - 0x92f63ff7 libGLU.dylib ??? (???) <a3b9be30100a25a6cd3ad109892f52b7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LU.dylib
0x92f64000 - 0x92fe3ff5 com.apple.SearchKit 1.2.1 (1.2.1) <bf8c50d86ebd0c199752065658b9e2c3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/SearchKit.framework/Versions/A/SearchKit
0x92fe4000 - 0x93260fe7 com.apple.Foundation 6.5.8 (677.24) <aa84b0383891378c348ffa4a94853082> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x93261000 - 0x932a3fef com.apple.NavigationServices 3.5.2 (163) <72cdc9d21f6690837870923e7b8ca358> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Nav igationServices.framework/Versions/A/NavigationServices
0x93308000 - 0x93333fe7 libauto.dylib ??? (???) <2e44c523b851e8e25f05d13a48070a58> /usr/lib/libauto.dylib
0x93334000 - 0x93402ff3 com.apple.JavaScriptCore 5525.26 (5525.26.2) <a8929f0de97428798f858023b3ce2f60> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaSc riptCore
0x93403000 - 0x93480fef libvMisc.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvMisc.dylib
0x93481000 - 0x9349fff3 com.apple.DirectoryService.Framework 3.5.6 (3.5.6) <daa1307737197c7757f44f16370249dc> /System/Library/Frameworks/DirectoryService.framework/Versions/A/Dire ctoryService
0x934a0000 - 0x9351dfeb com.apple.audio.CoreAudio 3.1.2 (3.1.2) <5a4e6329f8dbca5dcd70924525afd24a> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x9351e000 - 0x93536fff com.apple.openscripting 1.2.8 (???) <a6b446eb8ec7844096df5fb9002f5c7b> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ope nScripting.framework/Versions/A/OpenScripting
0x93537000 - 0x9383ffff com.apple.HIToolbox 1.5.5 (???) <b17766e3d8800a73f534c41f624f5ac4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIT oolbox.framework/Versions/A/HIToolbox
0x93840000 - 0x93907ff2 com.apple.vImage 3.0 (3.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vImage.framework/Versions/A/vImage
0x93997000 - 0x9399afff com.apple.help 1.1 (36) <1a25a8fbb49a830efb31d5c0a52939cd> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Hel p.framework/Versions/A/Help
0x939ce000 - 0x939d3fff com.apple.CommonPanels 1.2.4 (85) <c135f02edd6b2e2864311e0b9d08a98d> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Com monPanels.framework/Versions/A/CommonPanels
0x939d4000 - 0x939d4ffd com.apple.Accelerate 1.4.2 (Accelerate 1.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x939d5000 - 0x94075fe3 com.apple.CoreGraphics 1.409.3 (???) <25dceb14af3455b768f56e8765ecf3ca> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x94076000 - 0x94086ffc com.apple.LangAnalysis 1.6.4 (1.6.4) <7ae8dfd6cff0e34cf7c23ffc6cc291cb> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x94087000 - 0x94090fff com.apple.speech.recognition.framework 3.7.24 (3.7.24) <da2d8411921a3fd8bc898dc753b7f3ee> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Spe echRecognition.framework/Versions/A/SpeechRecognition
0x94091000 - 0x9409fffd libz.1.dylib ??? (???) <a98b3b221a72b54faf73ded3dd7000e5> /usr/lib/libz.1.dylib
0x940a0000 - 0x940a1ffc libffi.dylib ??? (???) <eaf10b99a3fbc4920b175809407466c0> /usr/lib/libffi.dylib
0x940a2000 - 0x94230fe7 com.apple.CoreAUC 3.07.2 (3.07.2) <08a5e0090d94e132ec9fa9ef4034941d> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAU C
0x94231000 - 0x9423efe7 com.apple.opengl 1.5.10 (1.5.10) <5a2813f80c9441170cc1ab8a3dac5038> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x9423f000 - 0x9425effa libJPEG.dylib ??? (???) <219f13f403b1e09a67f926c9269582e2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x942cd000 - 0x942cdffc com.apple.audio.units.AudioUnit 1.5 (1.5) /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x942ce000 - 0x9468cfea libLAPACK.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libLAPACK.dylib
0x94692000 - 0x94702ff7 com.apple.iLifeMediaBrowser 2.0.2 (321) <096200840dfe3556d984bed9e9e1e4bc> /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Version s/A/iLifeMediaBrowser
0x94703000 - 0x94703ffb com.apple.installserver.framework 1.0 (8) /System/Library/PrivateFrameworks/InstallServer.framework/Versions/A/ InstallServer
0x94704000 - 0x94837fef com.apple.CoreFoundation 6.5.6 (476.18) <2d52bab73660117571bd6486dc318f8e> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFo undation
0x9484c000 - 0x948a6ff7 com.apple.CoreText 2.0.4 (???) <f0b6c1d4f40bd21505097f0255abfead> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreText.framework/Versions/A/CoreText
0x9494b000 - 0x949d7ff7 com.apple.LaunchServices 290.3 (290.6) <bdba267184df88bd5b8e2116ea903872> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/LaunchServices.framework/Versions/A/LaunchServices
0x94ba4000 - 0x94cddff7 libicucore.A.dylib ??? (???) <cac059ebdac7d9a63ee0f7a648c9f6cf> /usr/lib/libicucore.A.dylib
0x94cde000 - 0x94cdeffe com.apple.quartzframework 1.5 (1.5) <6865aa0aeaa584b5a54d43f2f21d6c08> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x94cdf000 - 0x94cdfffd com.apple.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x94ce0000 - 0x94d9afe3 com.apple.CoreServices.OSServices 227 (227) <30cebcb68b1b571df7d77474e0c31556> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/OSServices.framework/Versions/A/OSServices
0x94da8000 - 0x94efaff3 com.apple.audio.toolbox.AudioToolbox 1.5.2 (1.5.2) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToo lbox
0x94efb000 - 0x94f8efff com.apple.ink.framework 101.3 (86) <d4c85b5cafa8027fff042b84a8be71dc> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink .framework/Versions/A/Ink
0x951f8000 - 0x95236fff libGLImage.dylib ??? (???) <a6425aeb77f4da13212ac75df57b056d> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LImage.dylib
0x95237000 - 0x9532bff4 libiconv.2.dylib ??? (???) <96ff4c6f84c4a1623cb78287371cdd3f> /usr/lib/libiconv.2.dylib
0x9532c000 - 0x9533cfff com.apple.speech.synthesis.framework 3.7.1 (3.7.1) <273d96ff861dc68be659c07ef56f599a> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x9533d000 - 0x9538cfff com.apple.QuickLookUIFramework 1.3.1 (170.9) /System/Library/PrivateFrameworks/QuickLookUI.framework/Versions/A/Qu ickLookUI
0x953bd000 - 0x96398ff6 com.apple.QuickTimeComponents.component 7.6 (1291) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacO S/QuickTimeComponents
0x96399000 - 0x967a9fef libBLAS.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libBLAS.dylib
0x967aa000 - 0x96831ff7 libsqlite3.0.dylib ??? (???) <3334ea5af7a911637413334154bb4100> /usr/lib/libsqlite3.0.dylib
0x96832000 - 0x96839fff com.apple.agl 3.0.9 (AGL-3.0.9) <d64d715dab8565014f5e2f239fd2410c> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x9683a000 - 0x968b4ff8 com.apple.print.framework.PrintCore 5.5.4 (245.6) <03d0585059c20cb0bde5e000438c49e1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/PrintCore.framework/Versions/A/PrintCore
0x968b5000 - 0x968c0fe7 libCSync.A.dylib ??? (???) <9e3544fe087bb4dc760b7afe0850dd6c> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x968f6000 - 0x96c93fef com.apple.QuartzCore 1.5.8 (1.5.8) <a28fa54346a9f9d5b3bef076a1ee0fcf> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x96c94000 - 0x96f6eff3 com.apple.CoreServices.CarbonCore 786.11 (786.13) <9e2d85d52e5e2951aa4dd53c48ccc52f> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore
0x96f6f000 - 0x9704ffff libobjc.A.dylib ??? (???) <d1469bf9fe852864d4fff185c72768e8> /usr/lib/libobjc.A.dylib
0x97050000 - 0x970adffb libstdc++.6.dylib ??? (???) <7d389389a99ce696726cf4c8980cc505> /usr/lib/libstdc++.6.dylib
0x970b1000 - 0x970b8ff7 libCGATS.A.dylib ??? (???) <211348279493364e9920adc86484cedd> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x97153000 - 0x97153ffe com.apple.MonitorPanelFramework 1.2.0 (1.2.0) <1f4c10fcc17187a6f106e0a0be8236b0> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/M onitorPanel
0x97154000 - 0x971e7ff3 com.apple.ApplicationServices.ATS 3.7 (???) <a535fc4982d3acff6530ec25c402e679> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/ATS
0x971ed000 - 0x971f9ffe libGL.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG L.dylib
0x9723f000 - 0x97244fff com.apple.DisplayServicesFW 2.0.2 (2.0.2) <df0c1a58d119d2dd90182cd2d88ccf58> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/ A/DisplayServices
0x97245000 - 0x97272feb libvDSP.dylib ??? (???) <4daafed78a471133ec30b3ae634b6d3e> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvDSP.dylib
0x97273000 - 0x97290ff7 com.apple.QuickLookFramework 1.3.1 (170.9) /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x97299000 - 0x972b7fff libresolv.9.dylib ??? (???) <39f6d8651f3dca7a1534fa04322e6763> /usr/lib/libresolv.9.dylib
0xb0000000 - 0xb0006ff8 com.apple.carbonframeworktemplate 1.3 (1.3.12) /Applications/Adobe Photoshop CS4/Adobe Photoshop CS4.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
0xba300000 - 0xba301fff libCyrillicConverter.dylib ??? (???) <4fec2bf92f6c26af7c58119df77674bf> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
0xba500000 - 0xba501ffb libGreekConverter.dylib ??? (???) <b63c7bb67f5eb753eb48fda5a428f638> /System/Library/CoreServices/Encodings/libGreekConverter.dylib
0xba900000 - 0xba916fff libJapaneseConverter.dylib ??? (???) <1ed47ca6a3bfe0c9bf656dfe3d5cc7c0> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0xbab00000 - 0xbab21fe2 libKoreanConverter.dylib ??? (???) <2c1a357c75d048e1eedb6c40a3f5b0e1> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
0xbb500000 - 0xbb500fe3 libThaiConverter.dylib ??? (???) <181e3ebe4ca849331c03a19ac575e3f0> /System/Library/CoreServices/Encodings/libThaiConverter.dylib
0xfffe8000 - 0xfffebfff libobjc.A.dylib ??? (???) /usr/lib/libobjc.A.dylib
0xffff0000 - 0xffff1780 libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
Edited by forum host : offensive language
DGJ: I mentioned in your other thread that your cleaning hint had nothing to do with your problems, and now you know.
The first thing you do when you have problems that hardly anyone else has, is disk repair, Then permissions. Then disconnect everything USB. Then new user. Then ask here. Then call Apple.
FYI: The crash that involves _SetDstBits32BGRA is an occasional crash in the OSX text edit field that can happen when you drag something (such as a panel) over the text edit field.
We have been able to provide a reproducible test case to Apple.
If you plan on contacting Apple regarding this issue, then you could refer to Apple bug (radar): 6913072 Crash in Carbon text edit fields when dragging
Well this is DGJ again...the original poster of this topic. I've been out of town a bit but have been back for the last week and wanted to post an update on my "crashing" problem. I'm hoping I've figured it out. Some of my crashing very well could be caused by the things Chris Cox has mentioned. But, I've greatly reduced my crashes by simply unpluggin my external hard drives!
I can't believe it! What clued me in was when my biz partner bought a new 1 TB external hard drive and when he began using it, he began having crashes, which he had not had before. So, he ended up returning that hard, a G Tech 1 TB, and replacing it with a Sea Gate 1 TB. FYI, on the G Tech external hard drive...it was purchased at the Apple store and was suppose to be "apple compatible" so I tried it srtaight out of the box but that caused crashes. Then we reformatted it for a Mac but that made no difference. It was attached directly to the computer and daisy-chained as well. It made no difference.
So, I returned that G Tech 1 TB external hard drive and exchanged it for another, thinking I just got a "bad" one. But, the second one did the same thing, caused crashes. (As a reminder, this was on my biz partners machine.) So, I checked my external hard drives and realized I had Lacie and a 500 GB G Tech external hard drive. So, I simply disconnected all the hard drives and have been working for a week without any attached.
And....
NO CRASHES!
I wanted to test this out a bit before posting here again. I wanted to be certain I had troubleshooted the problem before "assuming" I had a fix. So, you have seen my crash reports and some may have been due to this external hard drive issue or may be due to the issue Chris Cox noted or both. But, my crashes have ceased.
Hopefully, if any others have had this problem, you can see if disconnecting your external hard drives helps you. As a reminder, initially, I thought it might be due to having dual monitors. I guess that was not the case.
I'm just happy to have my issues corrected! It's been maddening and I can't believe I didn't think to unplug those external hard drives sooner! It was stupid! But, you live and learn!
I will post if I have additional crashes.
I just wanted to thank everyone for all the help. I really appreciate it.
Jesper-
Thanks for the info.
What percentage of the reported PS crashes are due to "_SetDstBits32BGRA"?
A common problem that I have experienced and others too, is that when trying to force Quit PS after the app freezes, PS won't force quit. What is causing PS to not force quit? Would all of the crashes that result in the same force quit problem have a similar origin, or is the force quit problem independent of the reason for the initial freezing of the app?
thanks
j
Hey JM,
I realize your question is for someone else but wanted to respond because I have had this "Photoshop won't force quit" problem as well. I can't say whether I've had a crash report mention this, " _SetDstBits32BGRA ". The crash report that I listed here of mine did not have this.
What I will say is that I did, and still do have, a Photoshop force quite problem. I don't believe this has anything to do with the G Tech issue I had. But, when I was having crashes, Photoshop would be frozen, unable to fully quit either with going through "file > quit" or through force quite. It would take a few minutes for it to actually "quit".
Then the other day, there was a storm and I wanted to just quickly quit everything and shut down (this was not due to a Photoshop crash). I began to force quite everything I had opened. However, the only one I had issue with was Photoshop CS4. I thought it was odd since I had just associated the "unable to force quite" problem with my crashing problem, which I now believe had to do with my G Tech external hard drive. But, I guess it was not.
It is very irritating as you have to "wait it out" until it finally does actually quit.
So, I am still having this issue but as of late, it was not associated with a crash.
(FYI...I just had a few programs opened and decided to "test it" and see if I could force quit Photoshop. And it didn't quit. It's frozen and unusable until it actually quits and is restarted. For the record, I timed it and it took just over 2 minutes to quit. But, I will say it's taken longer in the past.)
Dedra
There seems to be 2 common issues with the PS crashes/quits etc.
One is the above mentioned "force quit problem", and the other is when quitting PS ( and other apps in the CS4 suite) that the Adobe crash reporter sometimes appears as though the app has crashed upon quitting. I don't remember either of these problems with CS3. Are these also attributable to the MacOS?
"One is the above mentioned "force quit problem", and the other is when quitting PS ( and other apps in the CS4 suite) that the Adobe crash reporter sometimes appears as though the app has crashed upon quitting"
Part MacOS, part our crash reporter trying to gather information when it shouldn't (which relates back to the MacOS issue, but we can work around it). The delay in quitting is the Apple crash reporter code gathering information for us.
it appears that there was the ability to remove crash reporting on the Apple side but that has been removed with Leopard. This was reported on another tech site
"in earlier versions of OS X, one could edit /etc/hostconfig and change the line
"CRASHREPORTER=-YES-" to "CRASHREPORTER=-NO-"
not only is this line no longer in hostconfig, but the top of this file says
But Tinkertool still reports that it may be able to disable crash reporting
http://www.bresink.de/osx/0TinkerTool/details.html
scroll down to "Control how Mac OS X handles application crashes"
But this may only deal with the display of the information not the gathering which seems to be the problem.
" but we can work around it"
A work-around may be a good idea. Killing the crash reporting might allow everyone to get caught up with the existing problems, wait for Apple to fix their problems, and at the same time relieve the end users from problems related to crash reports that should be helping not hindering progress.
thx.
I dug a little deeper and unfortunately Tinkertool won't stop the crash reporter either, I received a speedy response from Marcel of TT:
Am 09.06.2009 um 14:12 schrieb CGI-Mailer:
By choosing "When applications crash: > Don't display anything" does this stop the crash reporter from gathering information
and also from passing this information on to other crash reporters such as those from Adobe?
I'm not helping; just ranting.
I find CS4 in general to be a buggy piece of garbage. I spend the bulk of time in ID and PS with constant issues from both. I've long since given up looking for solutions but have found some relief that I'm not alone. PS crashes on every single quit; ID constantly loses all my pallets and also likes to crash when quitting (although no where near as often as PS).
I used to send friendly reports to Adobe about it but in the last 4 months or so I've taken to harshly rebuking them for this abomination; so much so that I no longer get a report dialog when PS crashes. Has Adobe seen the light and disabled my reporting mechanism?
We purchased a multi site version of CS4 with varying degrees of success amongst us, even though we all installed from the same disks. Go figure!
While I don't expect perfection from any new upgrade, but do expect possible anomalies; I've never seen such a horrible piece of software outside of MS Office. CS5 came out fairly soon after CS4 so I took that as a sign that CS4 had some serious issues. We don't have CS5 yet but I'm hopeful that it's just one big patch.
Which third party plugins did you install just before it started doing that?
Though it's also possible you have a Brother printer/scanner (but a lot less common).
No, you had to disable the crash reporter. Adobe can't do that. If you go into your preferences folder and delete the adobe crash reporter plist, that'll reset it.
And you do know that while we fix bugs and report problems to third party manufacturers, there's no way we could respond to each and every crash report -- right?
Historically, each version ships 18 to 24 months after the last. CS5 was no exception.
in many ways that's how I looked at CS5. CS4 was crashing consistently, and from what I was told the crash reporter would kick in before or after ( I forget which) the problem could be identified.
I think my problems had to do with font activation with FAP and how it interacted with the CS4 suite because quite often when one app would crash on quit they all did. I don't know if the auto-activation problems were on the FAP side or CS4.... but in the end CS5, a high fiber diet and cleansing of my fonts has resulted in much less ( I might even say.... no crashing) at this point. So... even though I was one of unfortunate people that needed to reinstall CS5 it was worth upgrading just to get rid of the crash on quit issues.
regards
j
FYI: I have encountered situations where multiple applications crash on launch. Crashing applications can include Apple applications such as Mail. When I have encountered this, the OSX window server is typically "broken" and you need to restart your system.
When this is the case, your window server log (Console > Files > /private/var/log > windowserver.log) > may contain error messages such as:
CGSResolveShmemReference : offset exceeds bounds.
This is something that we have worked with Apple on, and is something that may be related to creating either many windows at the same time, or many windows over time.
In Cocoa we are able to reduce the number of windows that we use in Photoshop, and as such you should see this problem much less with CS5 than with previous versions.
I've installed no third party plugins; CS4 has been acting this way right off the disk.
I have not consciously disabled my reporting mechanism so let's just add that to the bug list. But thank you for pointing out the plist tip.
While admittedly frustrated, I'm still sane enough to know that Adobe does not reply to every crash report. My guess is that crash reports are scanned by software and not people. If Adobe does employ people to process crash reports they must have some serious overtime issues going on right now.
I've been using Adobe software from the time it came on floppy disks with printed manuals and have been through enough hardware and software upgrades in 16 years to justifiably state that CS4 has been my worst software experience yet. The only one that's topped is so far has been Publisher. I'm actually worried that Adobe might have gotten a bit too comfortable like Quark did (you all remember Quark, right?).
I have to say I have been pretty frustrated with CS4 myself. But more
so when I had a specific external hard drive attached to my computer.
I think it was Lacie.
Anyway, I'm a photographer and process tons of pretty large files and
had crashes almost hourly! Making production a living nightmare. I did
everything everyone said with no luck. Then one day I wondered if it
had anything to do with any of my external hard drives. I unhooked
each until I finally figured out which one it was. It's worth
mentioning I was NOT working off of this external hard drive. I'd
simply pull files to my desktop and when I was finished with the
project, I'd archive it onto one of three external hard drives.
Now, I have no clue why, but I don't have crashes anymore. I have
other irritating things that happen from time to time.
Like, Photoshop locks up on a force quit. Also, once in a while when i
restart Photoshop, my usual actions are no longer there and my
pallettes are changed around. Weird. And frustrating at times but I've
worked with it just fine.
I'd start unplugging hard drives one by one and see if this helps you.
Again, I'm no techy and have no idea what it's got to do with but it
worked for me! And what a relief!!! I was saving work about every
minute and woul inevitably loose something every time the thing
crashed!!! Worse than that, just reorienting yourself as to where you
were in the production process was such a waste of time!!!
Hope this helps!
Dedra Jenkins
Studio193 Photography
<<personal details removed>>
Well, so far our crashes on quit have been due to bugs in third party plugins, or bugs in printer and scanner drivers.
I read them, but again, we can't reply to all of them.
And really, Photoshop doesn't crash that often except for third party issues (see above).
If we find a bug in our code, we try to fix it as soon as we can...
If CS4 is crashing often, then there is a problem with something else on the system.
If you give me the email address you use when sending in the reports, I can do a search for your reports and find the exact cause.
(probably best to send me a private message, unless you like your email address going to SPAM bots)
Also, once in a while when i restart Photoshop, my usual actions are no longer there and my pallettes are changed around.
That would mean that the preferences got reset for some reason (keys held down at launch, or prefs were corrupt on disk).
Yeah, a bad external disk can cause some odd problems...
