3dfingers777
Run flex based apps on iPad???
Jan 31, 2011 10:38 AM
Does anyone know if it is possible to use the packager to run programs developed in Flex on the iPad?
    Feb 1, 2011 12:16 AM   in reply to 3dfingers777
    Relax,
    Just browse to this:
    http://www.openplug.com/services/projects
    So there's a way...
    Feb 1, 2011 12:46 AM   in reply to 3dfingers777
    On Below link from adobe site read "Epilogue". According to that if we wait for some time to release final verson of adobe which is fully supportable for iOS Devices as well as according to me may be adobe complate to built iOS flash player as soon as possible for run swf in iOS Devices .
      http://blogs.adobe.com/cantrell/archives/2010/09/packager-for-iphone-r efresher.html
    Feb 1, 2011 7:37 AM   in reply to Mohit M Chavda
    Hey Man,
    I hear ya. Adobe is terrible with documentation and most of these forum guys don't have a clue! They just regurgitate what Adobe puts on their websites. I just used the packager for iphone within Flash.
    1. Export your Flex app as a swf as you normally would. Frame rate 30 fps.
    2. Then create an iPhone app in Flash. Don't worry about the size.
    3. Go to File > iPhone OS Settings...
    4. You will see an Included files lists at the bottom. The xml is the key. It automatically generates that file in the same folder when you save your Flash file. Open this file and change the .swf file name to the Flex app file name.
    5. Include all file within the Included file area.
    6. Change your device setting to iPad. Name your file.
    7. Add the icons within the icon section. 72 x72 is iPad.
    8. Make sure to put all of your certificate and provisioning profiles in the deployment area.
    Depending on what functionality you have in the Flex app things may and may not work. For example, the iPad cannot open external .swf files with actionscript. If the files does not have actionscript then you are good to go. Yeah it sucks because this happened to me. You would think Adobe would have planned for this but I guess they are too smart for that.
    I also found that certain things may run slower, but still work.
    Good luck!
    Nathan
    Feb 1, 2011 10:15 AM   in reply to naButler
    How does this work exactly. I think you're missing steps.
    Calculating status...
    Feb 1, 2011 10:31 AM   in reply to 3dfingers777
    ...Because insulting the forum users and claiming higher intelligence will result in so many people just jumping up and down to serve you, master. How keen of you.
    A forum is a community effort. We are individuals helping each other out. To come barging in here demanding and expecting to be handed a solution to your problem, despite the fact that you aren't an active user, is laughable
    Use your perspicacious brain power to understand this: you give some, you get some.
    I'm surprised you got a response at all, and I'm embarassed for you.
    "The first rule of business is: Do other men for they would do you," Mister Businessman.
    Feb 1, 2011 10:34 AM   in reply to trainsimple
    Make sure to save your .fla first. It will generate an xml file for the iOS app. Open the xml and change the swf file it points to. The file it will point to is your .fla file you created. Here you will replace it with your Flex app swf that you exported. Then when you get back into your iPhone OS Settings include all of the associated files in the included files list. Basically your telling it to open your Flex swf instead of your Flash swf.
    It took me a few times to get used to it, but it's easier than trying to open up the terminal and typing in all of the information.
    Feb 1, 2011 10:46 AM   in reply to naButler
    but when you publish the iPhone/iPad app, doesn't the xml file get re-written pointing to the .fla versions of the swf? At least that's what seems t o be happening to me.
    Feb 1, 2011 11:06 AM   in reply to trainsimple
    I haven't had that happen to me. Once changed, it stayed. If you are making changes to your .fla and saving again it may regenerate the xml, but I haven't seen that either. Have you put it on your iPad or iPhone yet?
    One thing I did do was to put my Flex swf on the root of the included files list. Then in the xml just reference the swf within the <content>myFile.swf</content> tag. I don't think it likes being buried within a folder. However, all of my other files the Flex app called I put in their normal folders within the included files. So basically when you export your bin-release version from Flex or Flash Builder, just put that same structure into your included files list. Since mine is a web app, I didn't need to put the .html file it exported in the list because iOS doesn't called it.
    Feb 1, 2011 11:57 AM   in reply to 3dfingers777
    I really appreciate your apology, and I don't doubt that others do as well. I don't see that sort of thing very often, especially on the internet. I think most of us are pretty frustrated with Adobe as well, and I've been programming (or trying to) all day, so I was feeling at the end of my rope. This whole situation seems pretty tense lately.
    On that note, sorry I can't actually help you with your original question.
