puregas
ColdFusion 7.0.2
Jun 29, 2006 7:15 AM
I have a problem with ColdFusion and Dreamweaver which is driving me up the post.
I have upgraded ColdFusion to version 7.0.2 and this is my problem.
In Dreamweaver – the Application Panel – under Databases.
My Database table is now showing the full string i.e. C:\Databases\MallsOnCall\mallsoncall01.tbl_centres_classify
In the past it only showed the database table i.e. tbl_centres_classify
How do I get the Application Panel to only show the table i.e. tbl_centres_classify ???
Can someone please help??
    Jun 29, 2006 11:31 PM   in reply to puregas
    This was also prevalent with CF Updater 7.0.1 and as some have
    found out is also present with the 7.0.2 updater.
    At this point in time the only thing I have found to do is install the
    CF Server 7.0.0 version, which does not cause the problem and
    do not install the updaters.
    I also uninstalled the CF Server completely, downloaded the
    most current CF Server version (7.0.2) and tried it as opposed
    to just processing an updater. The same problem is still
    present.
    The Adobe staff really needs to take a look at this and get a
    fix out for it.
    Leonard B
    Jun 30, 2006 8:36 AM   in reply to puregas
    I will try to replicate this issue and see if I can get our development department to do something about it.
    Thanks for reporting it!
    Jun 30, 2006 8:47 AM   in reply to puregas
    What version of Dreamweaver you are using?
    Jun 30, 2006 10:28 AM   in reply to dimaint
    I am using DreamweaverMX 2004 version 7.0.1
    I would also like to add, that I have noted the following is occurring.
    With MS Access:
    -- The full path to the DB table is displayed
    -- C:\folder\path\to\db\folder\etc.
    With MySQL:
    -- The datasource.tablename is displayed
    -- r3fire.events
    Leonard B
    Jul 1, 2006 6:45 AM   in reply to puregas
    Me too. Same problem and same versions as CoffeeCup
    Bill
    "CoffeeCup" <webforumsuser@macromedia.com> wrote in message
    news:e83s00$jpj$1@forums.macromedia.com...
    >I am using Dreamweaver 8.0.2 and ColdFusion 7.0.2
    > From some our members our user group is seem this problem is in ColdFusion
    > 7.0.1 & 7.0.2. Version 7 doesn't have the same problem.
    > I look forward to your guys sorting this out
    > Thank you
    Jul 2, 2006 11:26 PM   in reply to puregas
    same here...
    Just downloaded and installed CF7 today, DW8 with latest updates.
    and, like the others, I would love to see this fixed!
    However, I should add... the example db tables seem normal.
    ( there are 4 databases already in the list in DW )
    I only see this problem on my own .mdb file, just added from within DW.
    Michael Evangelista
    "DataPacks.com" <info@REMOVEdatapacks.com> wrote in message
    news:e85u8v$496$1@forums.macromedia.com...
    > Bill
    >> ColdFusion
    >> Thank you
    Jul 5, 2006 7:21 AM   in reply to puregas
    Guys, I do see the same behavior using 7.0.2 and DW MX 2004. I will submit a bug for this. Not sure how fast this can be fixed though. I'll try to keep you posted.
    Jul 5, 2006 8:28 AM   in reply to dimaint
    It looks like everything works fine if you select Microsoft Access with Unicode driver instead of just Microsoft Access. So the problem is wth Microsoft Access driver and this is what I will submit bug for. Meanwhile, as the workaround, you can change your datasources to use Access with unicode driver.
    Jul 5, 2006 10:34 AM   in reply to puregas
    Unfortunately, Access Unicode driver has its own problems. So before changing anything make sure that your application still works fine. If not, then it might not be a good option for you.
    Jul 5, 2006 10:55 AM   in reply to dimaint
    Aargh. Yet another good argument for mySQL I suppose.
    Any idea on a timeline when we might see a DW fix?
    Michael Evangelista
    Evangelista Design / Evangelista Consulting, inc.
    www.evangelista-web.com
    Custom Small Business Website Solutions
    "dimaint" <webforumsuser@macromedia.com> wrote in message news:e8glr3$8rm$1@forums.macromedia.com...
    Jul 11, 2006 9:57 AM   in reply to puregas
    I have submitted this bug and it was replicated by our OQ department. So now it is all in hands of development. We will have a call with them tomorrow to discuss this issue and see when this can be fixed. I will update you as soon as we know something new.
    Oct 27, 2006 9:11 PM   in reply to puregas
    Has there been any work done to fix this bug? This is really bothersome. Using Dreamweaver 8 and Dreamweaver MX2004 with CF 7.0.2 and the problem persists.
    Doug
    Oct 30, 2006 10:36 AM   in reply to puregas
    What bug are you guys talking about? I can't find it referenced in the
    thread.
    news:ehuss7$3na$1@forums.macromedia.com...
    Hi Doug,
    Not that I'm aware off. I've kind of given up on this been resolved.
    But I do agree it's very frustrating, because you cannot drag and drop.
    My wish is for someone to HELP ?????
