Hi Experts,
I use LCD ES 8.2 to make a form which checks the mandatory fields in presign event and in case some left with blank set xfa.event.cancelAction = 1 to make the signiture procedure to stop.
This check and stop logic was working wonderfully in version 9 (Reader and Pro) but when I tested in Reader X, it seems something is not working well.
Once I set xfa.event.cancelAction to 1, it seems that it is not resetted to zero.
In other words, none of the events work once the xfa.event.cancelAction was set to 1...
Is this some kind of change that Adobe made?
Could somebody advise how to make it work again?
Thanks in advance
Total Likes
That is interesting. I can't say what is going on but it seems like a bug to me.
XFA Spec 3.1 states:
I can't locate a copy of XFA Spec 3.3, which would relate to Acrobat/Reader X. This may be because the version of LC Designer supporting XFA Spec 3.3 hasn't been released yet.
I also have an example that works in Acrobat/Reader 9.1, but not in Reader X. The cancel action is wrapped in an if statement.
This example uses the cancelAction to prevent printing if mandatory fields are not filled in. http://assure.ly/ej9Syg
Note that normally the validationState will clear the red highlight as information is typed into the fields. However in Reader X the red highlight is not cleared. In addition if the print action is cancelled, then the print button ceases to work.
I would be inclined to report as a bug, unless someone else has a better handle on this. https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
Good luck,
Niall
Niall,
Thanks for the reply!!
I guess
> Scripts must not attempt to clear this flag.
this means I better ask the users not to update to Reader X untill I clarify with Adobe.
Just made the bug report, I'll make a feedback to this post once they reply back.
Thanks Again!
Total Likes
I've checked with Reader 10.0.1.434 Japanese version, and thank god it's working now.
Just in case somebody is interested.
Total Likes
Did you report the bug? If not, I will because I am having the same issue. After cancelEvent, none of the buttons or select lists are working in Reader X.
Total Likes
