garyfr
UNABLE TO DOWNLOAD FLASH PLAYER
Feb 3, 2011 11:26 PM
      I have been unsuccessfully attempting to download Flash Player on IE and Mozilla.  When i get to the "install" window on both browsers it says that download will commence once browsers are closed.  When i close browsers i am unable to access Adobe without a browser opened.??
    Feb 4, 2011 12:50 PM   in reply to garyfr
    Hi, Do you have a link to the website that you are using? Does the message say that the Installation will proceed, instead of the download?
    I'm not clear what site you are on to be receiving this message.
    eidnolb
    Feb 4, 2011 8:56 PM   in reply to garyfr
    Download the executable installers from http://www.adobe.com/products/flashplayer/fp_distribution3.html and save them to disk, then close all browser windows and run the downloaded installers.http://www.adobe.com/products/flashplayer/fp_distribution3.html
    Feb 5, 2011 7:41 AM   in reply to garyfr
    Hi, I would like to add to what Pat posted and that is to make sure you download and SAVE to your Desktop the Uninstaller first
    from here:
    http://kb2.adobe.com/cps/141/tn_14157.html
    Then download and SAVE the Installer for IE and the Installer for FF(plug-in) to your Desktop.
    Once you have those on your Desktop, then Close all browsers.
    Be sure to use the Administrator Account for this.
    Check the system tray(area near the clock) and disable any instant messengers, like yahoo, msn, aol, etc.
    Also you may want to Disable any Anti-Virus that you use as some can block the Install. Re-enable when finished with this.
    Run the Uninstaller and when finished, Reboot(restart) your computer.
    Then Run the IE Installer and then the FF Installer, when finished, Reboot.
    Test each browser here and you should be able to see the Flash logo animation and the vs of Flash Player will be displayed.
    http://www.adobe.com/software/flash/about/
    If you have any questions, let me know.
    Also you may want to print this out to make it easier.
    eidnolb
    Mar 17, 2012 10:30 PM   in reply to eidnolb
    I am having the same failure, fails to initialize. I will now follow your advice, saving uninstall and BOTH installs to desktop. Rebooting after each operation.
    Wish me luck, am nearing throwing computer into firepit for warmth.
    Mar 17, 2012 11:48 PM   in reply to DrWhom
    You can also find the uninstallers and full installers at http://forums.adobe.com/thread/909550
    Make sure you download the correct executables (32-bit or 64-bit) for your system.
    Mar 18, 2012 1:46 AM   in reply to Pat Willener
    Hi Pat-
      I have unistalled/re-installed with no result.  I believe there is a compatibility issue between the latest (.63) Flash and Firefox 10. I’ve even updated to Firefox 11. Same warning….”update Flash NOW”…and when I try, “initialization failed”.
    Hmmmmmph
    Monty
    Mar 18, 2012 6:06 PM   in reply to DrWhom
    And you downloaded the uninstaller / installers from the link I posted earlier?  I don't think so; that message only appears if you use the standard installer.
    B.t.w. what is your Windows version & edition?
    Mar 18, 2012 11:51 PM   in reply to Pat Willener
    Yes, I followed instructions to the letter.  I'm getting pretty quick at it...I've used Reg cleaner/defrag/CleanUp/etc so my re-boot times are minimised.
    And I always exit Malwarebytes, my virus software, before attempt.
    Windows XP Home 2002 service pack 3. I've even established a clean restore point, since...after each failed attempt, I'm left with no flash player at all.
    I'm downloading the 32 bit uninstaller from your link, a 229kb file. Saved in 'my downloads', or saved shortcut to desktop, browsers open, browsers closed, it's all the same.
    "Failed to initialize"
    Mar 19, 2012 12:17 AM   in reply to Pat Willener
    I found this little infonugget at MozillzZine.
    The Flash uninstaller may not remove all Flash plugin files from all locations so you should search for and delete the following files, if found:
    • NPSWF32.dll
    • flashplayer.xpt
    • GetFlash.exe
    • GetFlash.exe.manifest
    • NPSWF32_FlashUtil.exe
    I'll try this next, if I can figger out how....
    Mar 19, 2012 1:06 AM   in reply to DrWhom
    No joy.  I did find four NPSWF32.dll which I deleted.  Had high hopes. Am reminded of the axiom that, if you keep doing the same damn thing expecting a different result...you may be a redneck.  Or, was that a corrolary? Nevermind, I HATE FIREFOX now.  Does this help?
    C:\Windows\system32\Macromed\Flash\FlashInstall.log
    =O====== M/10.1.53.64 2010-06-15+03-47-44.843 ========
    0000 [I] 00000010 "C:\DOCUME~1\MONTYJ~1\LOCALS~1\Temp\FlashPlayerUpdate.exe"
    0001 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/Version 2
    0002 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/Version 2
    0003 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
    0004 [W] 00001036 Software\Mozilla\Mozilla\extensions/Plugins 2
    0005 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
    0006 [W] 00001036 Software\Opera Software/Last CommandLine 2
    0007 [W] 00001036 Software\Opera Software/Last CommandLine 2
    0008 [W] 00001036 Software\Opera Software/Plugin Path 2
    0009 [W] 00001036 Software\Opera Software/Plugin Path 2
    0010 [I] 00000014 C:\WINDOWS\system32\Macromed\Flash\NPSWF32.dll
    0011 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10h_Plugin.exe
    0012 [I] 00000017 C:\WINDOWS\system32\Macromed\Flash
    =X====== M/10.1.53.64 2010-06-15+03-47-59.125 ========
    =O====== M/10.1.53.64 2010-08-18+05-49-18.281 ========
    0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10h_Plugin.exe" -update plugin
    0001 [I] 00000011 0
    =X====== M/10.1.53.64 2010-08-18+05-50-34.859 ========
    =O====== M/10.1.82.76 2010-08-18+05-50-35.015 ========
    0000 [I] 00000010 "C:\DOCUME~1\MONTYJ~1\LOCALS~1\Temp\4.dir\InstallFlashPlayer.exe" -iv 0
    =X====== M/10.1.82.76 2010-08-18+05-50-48.734 ========
    =O====== M/10.1.53.64 2010-08-25+13-19-24.937 ========
    0001 [I] 00000011 0
    =X====== M/10.1.53.64 2010-08-25+13-19-46.171 ========
    =O====== M/10.1.82.76 2010-08-25+13-19-46.218 ========
    0000 [I] 00000010 "C:\DOCUME~1\MONTYJ~1\LOCALS~1\Temp\5.dir\InstallFlashPlayer.exe" -iv 0
    0001 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
    0002 [W] 00001036 Software\Mozilla\Mozilla\extensions/Plugins 2
    0003 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
    0004 [W] 00001036 Software\Opera Software/Last CommandLine 2
    0005 [W] 00001036 Software\Opera Software/Last CommandLine 2
    0006 [W] 00001036 Software\Opera Software/Plugin Path 2
    0007 [W] 00001036 Software\Opera Software/Plugin Path 2
    0008 [I] 00000014 C:\WINDOWS\system32\Macromed\Flash\NPSWF32.dll
    0009 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10i_Plugin.exe
    0010 [I] 00000017 C:\WINDOWS\system32\Macromed\Flash
    =X====== M/10.1.82.76 2010-08-25+13-19-55.937 ========
    =O====== M/10.1.82.76 2010-09-22+13-13-47.765 ========
    0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10i_Plugin.exe" -update plugin
    0001 [I] 00000011 0
    =X====== M/10.1.82.76 2010-09-22+13-14-22.875 ========
    =O====== M/10.1.85.3 2010-09-22+13-14-22.937 ========
    0000 [I] 00000010 "C:\DOCUME~1\MONTYJ~1\LOCALS~1\Temp\6.dir\InstallFlashPlayer.exe" -iv 0
    0009 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10k_Plugin.exe
    =X====== M/10.1.85.3 2010-09-22+13-15-54.437 ========
    =O====== M/10.1.85.3 2010-11-11+05-04-38.156 ========
    0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10k_Plugin.exe" -update plugin
    0001 [I] 00000011 0
    =X====== M/10.1.85.3 2010-11-11+05-05-37.000 ========
    =O====== M/10.1.102.64 2010-11-11+05-05-37.125 ========
    0009 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10l_Plugin.exe
    =X====== M/10.1.102.64 2010-11-11+05-05-54.359 ========
    =O====== M/10.1.102.64 2011-02-12+06-09-54.218 ========
    0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10l_Plugin.exe" -update plugin
    0001 [I] 00000011 0
    =X====== M/10.1.102.64 2011-02-12+06-10-49.250 ========
    =O====== M/10.2.152.26 2011-02-12+06-10-49.437 ========
    0009 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10m_Plugin.exe
    =X====== M/10.2.152.26 2011-02-12+06-11-18.859 ========
    =O====== M/10.2.152.26 2011-03-05+23-15-12.656 ========
    0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10m_Plugin.exe" -update plugin
    0001 [I] 00000011 0
    =X====== M/10.2.152.26 2011-03-05+23-16-16.843 ========
    =O====== M/10.2.152.32 2011-03-05+23-16-16.875 ========
    0009 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10n_Plugin.exe
    =X====== M/10.2.152.32 2011-03-05+23-16-32.406 ========
    =O====== M/10.2.152.32 2011-03-27+05-20-46.218 ========
    0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10n_Plugin.exe" -update plugin
    =X====== M/10.2.152.32 2011-03-27+05-22-15.250 ========
    =O====== M/10.2.152.32 2011-04-03+15-27-29.265 ========
    0001 [I] 00000011 0
    =X====== M/10.2.152.32 2011-04-03+15-35-26.265 ========
    =O====== M/10.2.153.1 2011-04-03+15-35-26.359 ========
    0009 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10o_Plugin.exe
    0011 [E] 00001039
    =X====== M/10.2.153.1 2011-04-03+15-35-36.218 ========
    =O====== M/10.2.153.1 2011-04-17+15-30-45.500 ========
    0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10o_Plugin.exe" -update plugin
    0001 [I] 00000011 0
    =X====== M/10.2.153.1 2011-04-17+15-37-34.109 ========
    =O====== M/10.2.159.1 2011-04-17+15-37-34.171 ========
    0009 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10p_Plugin.exe
    =X====== M/10.2.159.1 2011-04-17+15-37-49.203 ========
    =O====== M/10.2.159.1 2011-05-16+23-07-34.171 ========
    0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10p_Plugin.exe" -update plugin
    0001 [I] 00000011 0
    =X====== M/10.2.159.1 2011-05-16+23-17-43.046 ========
    =O====== M/10.3.181.14 2011-05-16+23-17-43.093 ========
    0009 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10q_Plugin.exe
    0011 [I] 00000019 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
    =X====== M/10.3.181.14 2011-05-16+23-17-52.375 ========
    =O====== M/10.3.181.14 2011-06-07+23-47-56.437 ========
    0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10q_Plugin.exe" -update plugin
    0001 [I] 00000011 0
    =X====== M/10.3.181.14 2011-06-07+23-49-30.781 ========
    =O====== M/10.3.181.22 2011-06-07+23-49-30.843 ========
    0009 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10s_Plugin.exe
    0012 [W] 00001024 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl 183
    =X====== M/10.3.181.22 2011-06-07+23-49-41.515 ========
    =O====== M/10.3.181.22 2011-06-21+23-10-47.593 ========
    0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10s_Plugin.exe" -update plugin
    0001 [I] 00000011 0
    =X====== M/10.3.181.22 2011-06-21+23-11-52.937 ========
    =O====== M/10.3.181.26 2011-06-21+23-11-53.093 ========
    0000 [I] 00000010 "C:\DOCUME~1\MONTYJ~1\LOCALS~1\Temp\7.dir\InstallFlashPlayer.exe" -iv 0
    0009 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10t_Plugin.exe
    =X====== M/10.3.181.26 2011-06-21+23-12-10.609 ========
    =O====== M/10.3.181.26 2011-08-12+23-34-27.203 ========
    0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10t_Plugin.exe" -update plugin
    0001 [I] 00000011 0
    =X====== M/10.3.181.26 2011-08-12+23-37-25.781 ========
    =O====== M/10.3.183.5 2011-08-12+23-37-25.843 ========
    0000 [I] 00000010 "C:\DOCUME~1\MONTYJ~1\LOCALS~1\Temp\8.dir\InstallFlashPlayer.exe" -iv 0
    0009 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10v_Plugin.exe
    0012 [I] 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
    0013 [W] 00001024 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl 183
    =X====== M/10.3.183.5 2011-08-12+23-38-04.859 ========
    =O====== M/10.3.183.5 2011-09-25+14-58-06.531 ========
    0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10v_Plugin.exe" -update plugin
    0001 [I] 00000011 0
    =X====== M/10.3.183.5 2011-09-25+15-00-42.421 ========
    =O====== M/10.3.183.10 2011-09-25+15-00-42.468 ========
    0009 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10x_Plugin.exe
    =X====== M/10.3.183.10 2011-09-25+15-52-24.062 ========
    =O====== M/10.3.183.10 2011-10-16+15-26-31.015 ========
    0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10x_Plugin.exe" -update plugin
    0001 [I] 00000011 0
    =X====== M/10.3.183.10 2011-10-16+15-27-09.359 ========
    =O====== M/11.0.1.152 2011-10-16+15-27-09.484 ========
    0001 [I] 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
    0002 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
    0003 [W] 00001036 Software\Mozilla\Mozilla\extensions/Plugins 2
    0004 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
    0009 [I] 00000014 C:\WINDOWS\system32\Macromed\Flash\NPSWF32.dll
    0010 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11c_Plugin.exe
    0011 [I] 00000017 C:\WINDOWS\system32\Macromed\Flash
    0012 [I] 00000019 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
    =X====== M/11.0.1.152 2011-10-16+15-27-25.218 ========
    =O====== M/11.1.102.55 2011-11-14+01-25-24.062 ========
    0000 [I] 00000010 "C:\DOCUME~1\MONTYJ~1\LOCALS~1\Temp\5.dir\InstallFlashPlayer.exe" -iv 4
    0009 [W] 00001015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11c_Plugin.exe 5
    0011 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11e_Plugin.exe
    0013 [I] 00000019 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
    0014 [W] 00001024 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl 183
    =X====== M/11.1.102.55 2011-11-14+01-25-34.109 ========
    =O====== M/11.0.1.152 2011-11-14+01-19-29.296 ========
    0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil11c_Plugin.exe" -update plugin
    0001 [I] 00000011 0
    =X====== M/11.0.1.152 2011-11-14+01-25-34.140 ========
    =O====== M/11.1.102.62 2012-02-22+17-10-21.468 ========
    0000 [I] 00000010 "C:\DOCUME~1\MONTYJ~1\LOCALS~1\Temp\6.dir\InstallFlashPlayer.exe" -iv 4
    0009 [W] 00001015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11e_Plugin.exe 5
    0011 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11f_Plugin.exe
    =X====== M/11.1.102.62 2012-02-22+17-10-32.265 ========
    =O====== M/11.1.102.55 2012-02-22+17-09-09.484 ========
    0000 [I] 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil11e_Plugin.exe" -update plugin
    0001 [I] 00000011 0
    =X====== M/11.1.102.55 2012-02-22+17-10-32.296 ========
    =O====== M/11.1.102.62 2012-03-18+00-12-06.820 ========
    0000 [I] 00000010 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11f_Plugin.exe -maintain plugin
    =X====== M/11.1.102.62 2012-03-18+00-12-20.429 ========
    =O====== M/11.1.102.62 2012-03-18+00-12-23.179 ========
    =X====== M/11.1.102.62 2012-03-18+00-12-31.289 ========
    =O====== M/11.1.102.62 2012-03-18+00-12-50.007 ========
    =X====== M/11.1.102.62 2012-03-18+00-12-57.226 ========
    =O====== M/11.1.102.62 2012-03-18+02-43-26.000 ========
    0001 [W] 00001015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11f_Plugin.exe 5
    0002 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
    0003 [W] 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
    0004 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
    0005 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
    0006 [W] 00001021
    0007 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0008 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0009 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
    0010 [W] 00001036 Software\Mozilla\Mozilla\extensions/Plugins 2
    0011 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
    0012 [W] 00001036 Software\Opera Software/Last CommandLine 2
    0013 [W] 00001036 Software\Opera Software/Last CommandLine 2
    0014 [W] 00001036 Software\Opera Software/Plugin Path 2
    0015 [W] 00001036 Software\Opera Software/Plugin Path 2
    0016 [W] 00001015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11f_Plugin.exe 5
    0017 [I] 00000012
    =X====== M/11.1.102.62 2012-03-18+02-43-34.187 ========
    =O====== M/11.1.102.63 2012-03-18+04-22-42.703 ========
    0000 [I] 00000010 "C:\Documents and Settings\Monty  Johnson\My Documents\Incoming Files\uninstall_flash_player_32bit.exe" -force
    0001 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0002 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0003 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0004 [W] 00001018
    0005 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
    0006 [W] 00001019
    0007 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
    0008 [W] 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
    0009 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
    0010 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
    0011 [W] 00001021
    0012 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0013 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0014 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\{2CA4F306-B280-4ab2-B5E1-1DFA3583F046}/C:\WINDOWS\system32 \FlashPlayerCPLApp.cpl 2
    0015 [W] 00001048
    0016 [I] 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
    0017 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0018 [W] 00001018
    0019 [W] 00001036 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
    0020 [W] 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
    0021 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
    0022 [W] 00001019
    0023 [W] 00001020
    0024 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
    0025 [W] 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
    0026 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
    0027 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
    0028 [W] 00001021
    0029 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0030 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0031 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\{2CA4F306-B280-4ab2-B5E1-1DFA3583F046}/C:\WINDOWS\system32 \FlashPlayerCPLApp.cpl 2
    0032 [W] 00001048
    0033 [I] 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
    0034 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
    0035 [W] 00001036 Software\Mozilla\Mozilla\extensions/Plugins 2
    0036 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
    0037 [W] 00001036 Software\Opera Software/Last CommandLine 2
    0038 [W] 00001036 Software\Opera Software/Last CommandLine 2
    0039 [W] 00001036 Software\Opera Software/Plugin Path 2
    0040 [W] 00001036 Software\Opera Software/Plugin Path 2
    =X====== M/11.1.102.63 2012-03-18+04-22-59.843 ========
    =O====== M/11.1.102.63 2012-03-18+04-43-06.781 ========
    0004 [W] 00001018
    0005 [W] 00001037 Software\Macromedia\FlashPlayer\SafeVersions/ 2
    0006 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
    0007 [W] 00001019
    0008 [W] 00001020
    0009 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
    0010 [W] 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
    0011 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
    0012 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
    0013 [W] 00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
    0014 [W] 00001021
    0015 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0016 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0017 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\{2CA4F306-B280-4ab2-B5E1-1DFA3583F046}/C:\WINDOWS\system32 \FlashPlayerCPLApp.cpl 2
    0018 [W] 00001048
    0019 [I] 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
    0020 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0021 [W] 00001018
    0022 [W] 00001036 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
    0023 [W] 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
    0024 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
    0025 [W] 00001019
    0026 [W] 00001020
    0027 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
    0028 [W] 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
    0029 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
    0030 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
    0031 [W] 00001021
    0032 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0033 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0034 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\{2CA4F306-B280-4ab2-B5E1-1DFA3583F046}/C:\WINDOWS\system32 \FlashPlayerCPLApp.cpl 2
    0035 [W] 00001048
    0036 [I] 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
    0037 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
    0038 [W] 00001036 Software\Mozilla\Mozilla\extensions/Plugins 2
    0039 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
    0040 [W] 00001036 Software\Opera Software/Last CommandLine 2
    0041 [W] 00001036 Software\Opera Software/Last CommandLine 2
    0042 [W] 00001036 Software\Opera Software/Plugin Path 2
    0043 [W] 00001036 Software\Opera Software/Plugin Path 2
    =X====== M/11.1.102.63 2012-03-18+04-43-18.156 ========
    =O====== M/11.1.102.63 2012-03-18+04-47-18.859 ========
    0004 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0005 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0006 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0007 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0008 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0009 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0010 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0011 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0014 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0017 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0018 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0019 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0020 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0021 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0022 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0023 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0024 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0025 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0026 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0027 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0028 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0030 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0031 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0033 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0034 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0035 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0036 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0037 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0038 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0039 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0040 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0041 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0042 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0043 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0044 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0045 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0046 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0047 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0048 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0049 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0050 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0051 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0052 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0053 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0054 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0055 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0056 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0057 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0058 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0059 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0060 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0061 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0062 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0063 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0064 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0065 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0066 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0067 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0068 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0069 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0070 [W] 00001018
    0071 [W] 00001037 Software\Macromedia\FlashPlayer\SafeVersions/ 2
    0072 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
    0073 [W] 00001019
    0074 [W] 00001020
    0075 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
    0076 [W] 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
    0077 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
    0078 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
    0079 [W] 00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
    0080 [W] 00001021
    0081 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0082 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0083 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\{2CA4F306-B280-4ab2-B5E1-1DFA3583F046}/C:\WINDOWS\system32 \FlashPlayerCPLApp.cpl 2
    0084 [W] 00001048
    0085 [I] 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
    0086 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0087 [W] 00001018
    0088 [W] 00001036 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
    0089 [W] 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
    0090 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
    0091 [W] 00001019
    0092 [W] 00001020
    0093 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
    0094 [W] 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
    0095 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
    0096 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
    0097 [W] 00001021
    0098 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0099 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
    0100 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\{2CA4F306-B280-4ab2-B5E1-1DFA3583F046}/C:\WINDOWS\system32 \FlashPlayerCPLApp.cpl 2
    0101 [W] 00001048
    0102 [I] 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
    0103 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
    0104 [W] 00001036 Software\Mozilla\Mozilla\extensions/Plugins 2
    0105 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
    0106 [W] 00001036 Software\Opera Software/Last CommandLine 2
    0107 [W] 00001036 Software\Opera Software/Last CommandLine 2
    0108 [W] 00001036 Software\Opera Software/Plugin Path 2
    0109 [W] 00001036 Software\Opera Software/Plugin Path 2
    =X====== M/11.1.102.63 2012-03-18+04-47-42.000 ========
    =O====== M/11.1.102.63 2012-03-18+05-33-52.578 ========
    0000 [I] 00000010 "C:\Documents and Settings\Monty  Johnson\Desktop\uninstall_flash_player_32bit(1).exe" -force
    0040 [E] 00001039
    =X====== M/11.1.102.63 2012-03-18+05-34-06.484 ========
    =O====== M/11.1.102.63 2012-03-18+05-39-13.796 ========
    0004 [W] 00001018
    0007 [W] 00001019
    0008 [W] 00001020
    0014 [W] 00001021
    0018 [W] 00001048
    0021 [W] 00001018
    0025 [W] 00001019
    0026 [W] 00001020
    0031 [W] 00001021
    0035 [W] 00001048
    =X====== M/11.1.102.63 2012-03-18+05-39-20.890 ========
    =O====== M/11.1.102.63 2012-03-18+05-43-29.375 ========
    =X====== M/11.1.102.63 2012-03-18+05-43-33.468 ========
    =O====== M/11.1.102.63 2012-03-18+06-20-13.187 ========
    0004 [W] 00001018
    0007 [W] 00001019
    0008 [W] 00001020
    0014 [W] 00001021
    0018 [W] 00001048
    0021 [W] 00001018
    0025 [W] 00001019
    0026 [W] 00001020
    0031 [W] 00001021
    0035 [W] 00001048
    =X====== M/11.1.102.63 2012-03-18+06-20-19.796 ========
    =O====== M/11.1.102.63 2012-03-18+23-34-13.234 ========
    0000 [I] 00000010 "C:\Documents and Settings\Monty  Johnson\My Documents\Incoming Files\uninstall_flash_player_32bit(1).exe" -force
    0001 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
    0003 [W] 00001018
    0004 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
    0005 [W] 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
    0006 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
    0007 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
    0008 [W] 00001021
    0010 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
    0011 [W] 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
    0012 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
    0013 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
    0014 [W] 00001021
    0017 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
    0018 [W] 00001036 Software\Mozilla\Mozilla\extensions/Plugins 2
    0019 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
    0020 [W] 00001036 Software\Opera Software/Last CommandLine 2
    0021 [W] 00001036 Software\Opera Software/Last CommandLine 2
    0022 [W] 00001036 Software\Opera Software/Plugin Path 2
    0023 [W] 00001036 Software\Opera Software/Plugin Path 2
    =X====== M/11.1.102.63 2012-03-18+23-34-22.078 ========
    =O====== M/11.1.102.63 2012-03-19+07-26-14.140 ========
    0000 [I] 00000010 "C:\Documents and Settings\Monty  Johnson\My Documents\Incoming Files\uninstall_flash_player_32bit(2).exe" -force
    0003 [W] 00001018
    0008 [W] 00001021
    0014 [W] 00001021
    =X====== M/11.1.102.63 2012-03-19+07-26-22.187 ========
    Mar 19, 2012 3:41 AM   in reply to DrWhom
    Thank you for the FlashInstall.log file; I can see that there are many errors or warnings during the uninstall process. However, I cannot see any attempts to run the installers - could it be that the error occurs before it starts logging?
    Two things to try:
    1. a clean install; it's almost the same as you have already done, but a bit more thorough: http://http://forums.adobe.com/thread/928315
    2. if the install still fails, can you try to run this Microsoft tool: http://support.microsoft.com/mats/Program_Install_and_Uninstall
    Mar 19, 2012 11:55 AM   in reply to Pat Willener
    Pat-
    I tried the two things you suggested, no joy.
    But, undaunted...I learned from your Fixit tool that I was missing two killbits activex updates, so I fixed.
    Then...when checking my Java performance, (suggested elsewhere on da web), I learned I had SEVEN old Java versions that needed uninstalling. I didn't know this about Java!
    So I deleted almost 900meg of old Java program.
    Rebooted and loaded both new Flash (.exe and .msi) and...............................................................etc ...................
    YA-HOO IT'S A GO!
    ps thank you thank you for all your help......
    Mar 19, 2012 10:28 PM   in reply to DrWhom
    Thank you for the feedback; didn't know that Java could do such a thing...
    Mar 20, 2012 7:26 AM   in reply to Pat Willener
    Me either, and I still don't with any certainty.  I did 2 different fixes at once.  Uploading 2 "killbits actvex" updates in Windows, then uninstalling my 7 outdated Java files.
    Which operation was the fix.....
    But thanks again! Your suggestions gave me the inspiration to keep up the fight; not take hammer to cpu.
    Mar 24, 2012 11:40 AM   in reply to garyfr
    Isn't there an executable file that you can send to me?  I am not computer savvy and I tried using the uninstall feature, and it worked, however when flash goes to open up, it stays stuck at 0% then becomes unresponsive, and I have to stop it .
    Mar 24, 2012 9:16 PM   in reply to ediejessesmom
    What is your operating system, version & edition?
    What is your web browser & version?
    Mar 25, 2012 1:37 PM   in reply to Pat Willener
    I have Microsoft XP and use Firefox
    Mar 25, 2012 5:58 PM   in reply to ediejessesmom
    Mar 26, 2012 8:39 AM   in reply to Pat Willener
    I really appreciate you trying to help me.  I downloaded the 32 bit version
    and tried to open it and run it, but I received a box that only showed me an
    error box with a red circle and an x through it, the ok button, and the
    title of Adobe Flash Player Installer/Uninstaller on it.
    Mar 26, 2012 8:45 AM   in reply to Pat Willener
    I just tried it again and received an error msg that stated "Certificate
    authentication failed, please re-install to correct the problem."
  • Xircal
    Mar 29, 2011
    Mar 26, 2012 9:28 AM   in reply to ediejessesmom
    Which version of Firefox do you have installed?
    Mar 26, 2012 9:38 AM   in reply to Xircal
    11.0
  • Xircal
    Mar 29, 2011
    Mar 26, 2012 1:19 PM   in reply to ediejessesmom
    11.0
    OK, do the following please.
    1. If you have the Firefox view with the oblong orange button top left, hit the ALT key to get the text links. Then click Help | Restart with add-ons disabled.
    2. In the next menu which appears, click the button called "Continue in Safe Mode" without checkmarking any of the boxes.
    3. When Firefox restarts, all your add-ons will be disabled and you'll only see the default layout.
    4. Download the Flash uninstaller. This is a direct link so you won't see a page, only the file to be downloaded.
    5. Download the latest Flash installer 11.1.102.83 This is also a direct download link.
    6. Close Firefox.
    7. Disable your antivirus. This is important because most modern AV incorporate scanners which interfere with the installation process. If you have AVAST, right click the orange icon in systray and go to "AVAST Shields Control". Choose to disable all shields for one hour. If you have a different AV, consult this list for instructions on how to disable it: http://www.bleepingcomputer.com/forums/topic114351.html
    8. Run the Flash uninstaller to remove Flash player (even if you think it's not installed).
    9. Next, double click the Flash installer you downloaded to install Flash.
    10. Finally, re-enable your antivirus.
    Should work.
    Mar 26, 2012 2:06 PM   in reply to Xircal
    Thank you so much for helping me.  This worked, and now my husband won't be
    upset with me.  I really appreciate all of the help.
    Michelle
  • Xircal
    Mar 29, 2011
    Mar 27, 2012 2:13 AM   in reply to ediejessesmom
    You're welcome Michelle.
