forfuxayk
Access Denied message in Flash CS5 help
Jun 15, 2010 6:24 AM
  I had the problem with an Access Denied message when running community help and followed the technote instructions to re-install, but still had errors.
  Browsing the config files in my newly created folder for the chc app:
  %appData%\chc.4875E02D9FB21EE389F73B8D1702B320485DF8CE.1\Local Store\HelpCfg\en_US
  I find that the "baseURL" setting in Flash_11.0.helpcfg was set to: baseUrl="http://help.stage.adobe.com/"
  Which also shows the Access Denied error in the browser.
  Changing this to baseUrl="http://help.adobe.com/" seems to start it working and I get packages downloading etc.
  Not sure if the URL is right, but that helped me.
    Jun 15, 2010 8:16 AM   in reply to forfuxayk
    Thanks very much for the heads up! We had a workflow burp, but this should be fixed now.
    John Francis
    Adobe Learning Resources
    Jun 17, 2010 12:05 PM   in reply to jfrancis@adobe.com
    I am still getting this problem. I looked at my Flash_11.0.helpcfg and the base url is correct. It takes me to the access denied page in both the air help appicated and the browser help. All the other CS5 applications' help work fine, just Flash Pro CS5 is having this problem.
    Any ideas?
    Jun 17, 2010 12:07 PM   in reply to Tristan559
    Hi Tristan,
    What OS are you running?
    Jun 17, 2010 12:13 PM   in reply to jfrancis@adobe.com
    Windows 7 32 bit
    Jun 17, 2010 12:17 PM   in reply to Tristan559
    Okay, make sure that .stage is removed from the helpcfg file located here (note that you'll have to enable Tools > Folder Options > View > Show hidden files, folders, and drives to see the AppData folder):
    C:/User//AppData/Roaming/chc.4875E02D9FB21EE389F73B8D1702B320485DF8CE. 1/LocalStore/HelpCfg/en_US
    If you're still having no joy, then you can delete the chc.REALLYLONGID folder above and relaunch help. That'll reinitialize everything.
    Sorry for the inconvenience!
    John Francis
    Jun 17, 2010 12:20 PM   in reply to Tristan559
    One other note, it was tremendously difficult getting the CS5 programs to install on Windows 7 via Master Collection CS5. I constantly ran into "This program failed to install" I looked at the log, and it said so and so file was being used by another process and could not be deleted. I had to go in and hand-deleted multiple folders a few dozen times to get all the programs installed correctly. I doubt this is what is causing the Flash Help access denied issue, but I just wanted to bring this up.
    I need to install Master Collection CS5 on another Windows 7 machine, and I am not looking forward to doing so as a result of what I had to go through on my first Windows 7 machine.
    Jun 17, 2010 12:22 PM   in reply to Tristan559
    Thanks, Tristan, I've forwarded your message to the group that handles the Suite installer.
    John Francis
    Jun 17, 2010 12:25 PM   in reply to jfrancis@adobe.com
    Deleting the folder ended up being the solution that worked. Thank you so much
    Jun 17, 2010 12:30 PM   in reply to Tristan559
    My pleasure, Tristan, and, again, sorry for the inconvenience!
    John Francis
    Jun 18, 2010 9:49 AM   in reply to forfuxayk
    I am getting the same error but cannot find the file/folder that need fixing. I am using Mac OSX 10.6.3 and installed the Master Collection. Thanks.
    Jun 18, 2010 9:54 AM   in reply to the_ARTboy
    Hi there,
    You need to look here on Mac OSX:
    Users//Library/Preferences/chc.4875E02D9FB21EE389F73B8D1702B320485DF8C E.1/Local Store/HelpCfg/en_US/
    Again, if modifying the Flash_11.0.helpcfg doesn't work, just delete the chc.REALLYLONGID folder and everything will reinitialize.
    John Francis
    Jun 18, 2010 10:01 AM   in reply to jfrancis@adobe.com
    Thanks. It works again.
    Jun 18, 2010 10:15 AM   in reply to forfuxayk
    For the sake of completeness, if you're using Windows XP, you'll find the CHC folder here:
    C:/Documents and Settings/<username>/Application Data/chc.4875E02D9FB21EE389F73B8D1702B320485DF8CE.1/LocalStore/HelpCf g/en_US
    Again, if removing stage from the Flash_11.0.helpcfg doesn't work, just delete the whole chc.REALLYLONGID, and everything will reinitialize.
    John Francis
    Jun 19, 2010 9:34 AM   in reply to jfrancis@adobe.com
    Thanks!  Removing the .stage did the trick.  :-)
    Jul 1, 2010 8:33 AM   in reply to jfrancis@adobe.com
    Thanks.
    I'm on Mac and had the same problem. Deleting chc.487.... folder did the trick for me.
    Dave
    Jul 4, 2010 5:42 AM   in reply to forfuxayk
    I am having the same issue, Mac OSX.
    Can't find ANY of the files you have referred to, and I'm incredibly frustrated that once again Adobe has screwed up my day's work.
    Why can't we just have the reference documentation instead of all this 'community' help.
    There's a time an a place for that - and it's online. Why can't I just get the reference info I want for the app I am using by clicking on HELP?
    And why does my CD-based install require access to your website to get help files?
    Now I have to waste time finding and fixing another of your bugs because you're trying to make something overly complicated.
    I understand why you do not give printed documentation with boxed product - but WHY can't we just have a PDF file?
    Jul 4, 2010 6:31 AM   in reply to Mr Delete Happy
    @VeryIrritated,
    Maybe I can help direct you to the location. Quit Flash. Open a new Finder window, navigate to your HOME within your User. You should see folders like: Applications, Desktop, Documents, Downloads, ect... Look for LIBRARY then double click into that folder. Now you're in the Library directory, look for the Preferences folder, double click into there. Now your in the (home is your user folder) HOME->LIBRARY->PREFERENCES. Inside the Preferences folder look for the FOLDER named "chc.4875E02D9FB21EE389F73B8D1702B320485DF8CE.1". Now delete that folder, restart Flash and that should fix the problem. A new Preference folder with that same long name should be recreated by Flash.
    Let me know if that doesn't work.
    Dave
    Jul 4, 2010 8:04 AM   in reply to k-yo!
    Thanks Dave, apologies for not finding that path in the post earlier in this thread.
    Now I have to ascertain why the search function on my Mac wasn't able to find those files and folders...!
    Jul 4, 2010 9:06 PM   in reply to Mr Delete Happy
    BTW, you can also get a PDF file from the link at the top of this page:
    http://help.adobe.com/en_US/flash/cs/using/
    Jul 17, 2010 11:22 AM   in reply to jfrancis@adobe.com
    Thanks for the good advice on this issue.its solved my Access denied issue, you really know your stuff , Thanks Man  : )
    Oct 24, 2010 1:12 PM   in reply to jfrancis@adobe.com
    Thank you!
    This solves the problem in Lightroom 3 (LR3) as well.
    (It broke when Adobe sent out an update for the Community Help application in September.)
    Feb 15, 2011 4:14 AM   in reply to forfuxayk
    Thank you so so much! This fixed the issue for me too since I could not see the help files for Flash 5 only.
