End-2-end sample Cairngorm3 application with Maven
Feb 7, 2011 11:49 PM
I am setting up a project using "best of breed" technologies "Flex-Spring-Hibernate" with Maven support, just like our great "todo sample" http://opensource.adobe.com/svn/opensource/cairngorm3/trunk/samples/to do.
But my skill is just so limited so I can't do it by myself. I need a sample to follow (even copy/paste). All I need is something like our "todo sample" on its own (not an application inside cairngorm3 source code).
If you have or saw something like that, please tell me.
P/S: side question: I built the todo app successfully then deploy to tomcat. But I got a empty screen when I run it. I guess I miss some installation steps. I searched for the installtion guide but couldn't find one. Please share me if you have the guide
    Feb 8, 2011 12:51 AM   in reply to Pham Huy Anh
    There were a few issues indeed with maven and the version of the sdk we used in the sample.
    I just fixed by comitting a few upgrades in the builds:
    * we migrated the todo sample to flex-mojos 4 (you'll have to migrate to maven3 as well)
    ** This change was tested with maven 3.0.2.
    * and the flex sdk to 4.5.0.18623.
    Please note that as mentioned in the flexmojos docs in addition, there is one JAR (AIR development tools) that is packaged with the Flex SDK but is not open source.
    Because of this, flexMojos cannot host this artifact. To build from source, you will need to install this artifact into your own private repo:
    mvn install:install-file -DgroupId=com.adobe.flex -DartifactId=adt -Dversion=4.5.0.18623 -Dpackaging=jar -Dfile=adt.jar
    This JAR is bundled with the Flex SDK, which is freely available from: http://opensource.adobe.com/wiki/display/flexsdk/Downloads
    This changes (cf. http://forums.adobe.com/thread/788583?tstart=0 ) should fix the issue you were facing with our todo sample.
    If you still have any, feel free to ping us again.
    Meanwhile there's also a very nice and very simple sample on sonatype docs presenting the maven/java/flex stack (but without cairngorm) :
    http://flexmojos.sonatype.org/reference-application.html
    Mar 30, 2011 3:22 AM   in reply to Pham Huy Anh
    • I recently publish a fork of this todo sample in git cf. https://github.com/Adobe-TXI/cairngorm3-todo-sample
    • The flashbuilder files are committed  just use them
    • As for the java project files you may use M2eclipse to generate them
    • a complete guide, that will come: what kind of stuff are looking for in this guide ?
