Hi Folks
I just installed the "LiveCycle ES" Trial VMWare-image for ESX-Server (which uses JBoss) and tried to call the ReaderExtensionsServiceClient webservice using the java sample and always get this exception:
Caused by: com.adobe.idp.DocumentError: 405: HTTP method PUT is not supported by this URL
I sticked to the adobe webservice client sample as shown in the source below. The sniplet does not show the real IP address.
The WSDL-url works fine for GET in the browser: http://server-ip-address:8080/soap/services/ReaderExtensionsService?wsdl&lc_v ersion=9.0.0
The services are all activated in the Trial VMWare-image. I did not import ReaderExtensions credentials, as I was unable to find the view for this in the AdminUI, but the Trial VMWare-image should have some ReaderExtensions credentials preinstalled.
Any hints welcome what to change to get this working.
best regards
irgei
Properties connectionProps = new Properties();
connectionProps.setProperty(ServiceClientFactoryProperties.DSC_DEFAUL T_SOAP_ENDPOINT, "http://server-ip-address:8080");
connectionProps.setProperty(ServiceClientFactoryProperties.DSC_TRANSP ORT_PROTOCOL,
ServiceClientFactoryProperties.DSC_SOAP_PROTOCOL);
connectionProps.setProperty(ServiceClientFactoryProperties.DSC_SERVER _TYPE,
ServiceClientFactoryProperties.DSC_JBOSS_SERVER_TYPE);
connectionProps.setProperty(ServiceClientFactoryProperties.DSC_CREDEN TIAL_USERNAME, "Administrator");
connectionProps.setProperty(ServiceClientFactoryProperties.DSC_CREDEN TIAL_PASSWORD, "password");
UsageRights usageRights = new UsageRights();
usageRights.setEnabledComments(true);
ReaderExtensionsOptionSpec options = new ReaderExtensionsOptionSpec(usageRights, "my usage rights message");
ServiceClientFactory factory = ServiceClientFactory.createInstance(connectionProps);
ReaderExtensionsServiceClient service = new ReaderExtensionsServiceClient(factory);
Document inDocument = new Document(new File(testBaseDir, "test-input.pdf"), false);
Document rightsApplied = service.applyUsageRights(inDocument, "", "", options);
rightsApplied.copyToFile(new File(testBaseDir, "test-output.pdf"));
Okay, there's a lot going on in your post, let's try to break it down:
1 - You NEED a Reader Extensions credential. With out a valid credential you will not be able to RE any documents
2 - To do a quick test to see if Reader Extensions is up and running, start with the built in verification sample:
http://{yourServer}:{port}/ReaderExtensions/ for example
http://localhost:8080/ReaderExtensions/
Login using administrator/password
If you can convert using that tool, then at least we know Reader Extensions is working properly
3 - You need to pass in the RE credential's alias as a parameter to the web service call. I belive that this is the second parameter for the applyUsageRights method call
You may want to have a look at the examples that are provided in the Quick Start Guides:
http://help.adobe.com/en_US/livecycle/9.0/programLC/help/index.htm?con tent=000299.html
Hello Hodmi
Many thanks for the password hint. It is unbelievable. I had mixed up the text files after uncompressing the zip files...
The browser based ReaderExtensions are working fine at http://{yourServer}:{port}/ReaderExtensions/
The processed PDFs support commenting also with Adome Reader Verison 8.
I applied the suggested changes to the webservice client sourcecode:
inDocument, "SAMPLEREADEREXTENSIONSCREDENTIAL" , "vHcZIJ9Pt?", options);
The request still results in a HTTP 405: HTTP method PUT is not supported by this URL
Might it this be due to the MTOM / Base64 / etc. settings ?
I recorded the HTTP request in Wireshark:
PUT /soap/services/ReaderExtensionsService/dsc/upload?serviceName=ReaderE xtensionsService&returnContext=true HTTP/1.1
Authorization: Basic QWRtaW5pc3RyYXRvcjpwYXNzd29yZA==
User-Agent: Java/1.5.0_22
Host: server-ip-address:8080
Accept: text/html, image/gif, image/jpeg, *; q=.2, */*; q=.2
Connection: keep-alive
Content-Length: 85886
thanks for your effort
irgei
The HTTP Put error is a little odd. I've always thought the web service calls used HTTP Post or Get.
Having said that:
How are you passing your PDF to LiveCycle? As you say, LiveCycle will take the binary file in various formats including MTOM, base64 and a few others. You have to "tell" LiveCycle what method you are using however. This is done by appending a blob parameter to the end of the request URL.
For example if you are going to send your PDF as a base64 encoded string, you append: ?blob=base64 to the service URL. Then you would read the binary object into the blob's setBinaryData method.
If you are using MIME/DIME or MTOM then you need to set the attachment and then pass its reference to the blob object.
If you set nothing, then LiveCycle assumes that you are passing the file by reference. In that case you are not actually passing the document, but you are setting the blob object with the URL of the document. Similarly, LiveCycle will return a URL to the Reader Extended document.
I wrote an article on calling LiveCycle using Java and SOAP a while ago. It doesn't include MTOM (older versions of LC didn't support it), but the general idea is the same.
