How to transform  PDF to WORD??
Dec 20, 2010 7:09 PM
I have some PDF file,i want to edit the information in it ..so i should transform the PDF from WORD first ,then i can edit it..hope i can get help from here ..thanks!!!
    Dec 20, 2010 10:29 PM   in reply to dan lisa
    Acrobat X has a greatly improved PDF to Word Converter!
              - Dov
    Feb 9, 2011 9:58 PM   in reply to dan lisa
    There are many ways that you can use to transform PDF to Word. If your PDF file does not include complex content like images, tables, vector graphics and so on. You may just use the "save as Word" function in the adobe reader! Or if the PDF is open to everyone, you also can directly copy and paste by "ctrl + c"
    and "ctrl + v" to the Word program.
    If the PDF is a complex one which has different types of content like images, spreadsheet or anything else, you may need a PDF to Word converter like adobe acorbat series. Online or offline converter as you like.
    But I guess if it is better for you to edit in PDF direclty, then reproduce to modified PDF. If you want to do that, you can also use a PDF editor, it enables you to edit text in PDF no matter add,delete,modify text in the target PDF file.
