andrey.mironov
Alchemy does not release ByteArray objects
Feb 3, 2011 9:52 AM
I'm trying to use libjpeg encoder to encode bitmap to jpeg and notice, that original data never releases from memory. After some testing I found tha alchemy hold references to them. Is that a bug or am I doing something wrong?
Here is my ActionScript code:
protected function doSomethingButton_clickHandler(event:MouseEvent):void
     var data:ByteArray = new ByteArray();
     for (var i:int = 0; i < 1000; i++) {
          data.writeInt(Math.round(10000 * Math.random()));
     Demo.doSomething(data); // This is an alchemy class
And here is my *.gg file:
import flash.utils.ByteArray;
public function doSomething(data:ByteArray):void
The functiion does nothing! And profiler shows that all of this ByteArray objects stay in memory:
    Feb 4, 2011 10:42 AM   in reply to andrey.mironov
    deleted
    Feb 10, 2011 8:08 AM   in reply to andrey.mironov
    I'd like to know if the AS3_Release(data) is a valid thing to do, or not.
    It's been a while, but the last time I profiled for a leak in alchemy, it appears that the passed-in parameters (to an API compiled with gluegen) are kept in alchemy in some sort of weak reference Dictionary.  These get cleaned up when alchemy decides to scan for cleanup - not when you want them gone.
    So, passing-in objects that hold lots of memory (like a byte array) is a bad thing.  I had thousands of Rectangle objects being held by alchemy (and they do not get cleaned by a manual garbage collect in the profiler), but sure enough, they eventually go away.
    I didn't think that the AS3_Release on input parameters was a valid thing to do, but perhaps it is, provided the object isn't referenced anywhere else in alchemy for other valid reasons?  I wouldn't want things to blow up.
