ggenit029
Project management sofware to aid InDesign
Feb 10, 2011 5:52 AM
I stumble upon this
articlewhich features 43 compared project management software alternatives and I am still having problem on what to choose that would be perfect for InDesign.
  • Cari Jansen
    Sep 16, 2006
    Feb 10, 2011 4:02 PM   in reply to ggenit029
    What is it you want to do with project management software aids for InDesign?
    I'm wondering if you might need to look at workflow/production based solutions for InDesign instead?
    For example these are three that I'm thinking of:
    Cari
    www.twitter.com/carijansen
    Feb 11, 2011 12:18 AM   in reply to Cari Jansen
    Funny – I was just starting to look around for flat-plan / page management software myself. It's exciting to see what's available (thanks Cari!).
    As a starting point, can you recommend any free flat-plan software? At this stage I don't need sophisticated cross-application integration or project management capabilities, just something basic to create and edit page plans.
  • Cari Jansen
    Sep 16, 2006
    Feb 11, 2011 4:10 AM   in reply to Graham van de Ruit
    Graham,
    Have you considered doing this:
    • Use InDesign and generate the number of pages needed for your publication.
    • Setup a separate layer called 'flatplan'.
    • Set-up different object styles that would apply a different colour for different content-zones (e.g. editorial, ad etc.), and include in the object-style a paragraph style reference and text-inset so that you can also type some details for each content-zone (e.g. ad-number or something).
    • Once you've completed the flat-plan in InDesign
    • You can communicate to others for instance by printing it as thumbnails  (In Print > Setup, enable Thumbnails).
    You could even use your publication template for this and just add the flatplan related layer and styles to it.
    • As long as you use a separate layer for your flatplan info, you can change that layer to 'non-printing' when production is completed, and you can also use it to retain status information for your publication during the production process.
    It's not automatic... but if you've already got InDesign its definitely not costing you anything extra ;-)
    I'm not aware of a flatplan plug-in for InDesign. I did come across:
    Cari
    Feb 11, 2011 4:48 AM   in reply to Cari Jansen
    Thanks Cari. I hadn't thought of doing it like this, probably partly because I hadn't used the Thumbnails option for printing and want a way to view many pages at once. The trouble with my previous method of using tables came when I wanted to move pages around, but that won't be an issue here. I'll give it a try.
    That Mao Workflow looks pretty good, but I couldn't find any purchase or download info.
    Thanks for the suggestions!
