Is there a way to set the duration of all pictures when creating a video from a set of pictures?
I can see that you can select individual pictures, use the "time stretch" and reduce the duration of the picture.
However, if I select all the pictures, in the timeline, and try the same thing the value in the "time stretch" menu is grayed out/ not editable.
Also are there any good tutorials published on creating a time lapse video from a set of pictures.
It appears to me that the help function only deals with the built in tools and they are focused on capture of pictures for time lapse video.
Thanks.
Depending on what I want to do with either Time Lapse, or Stop Motion, I set the desired Duration in Edit>Preferences, before Import. There is no easy way to adjust the Duration, after Import, other than click-drag on the Head, or Tail, and probably with the Info Panel open.
For most Stop Motion, I like a 3 Frame Duration, though that does differ by the subject matter, and the "look" that I want.
Good luck, and hope that helps,
Hunt
PS - don't forget to reset the Edit>Preferences>General>Still Duration back, or you will be surprised, when you do, say a Title.
@ Bill Hunt
Hi Bill:
Thanks for your response.
It turned out that the problem with setting all the durations in one action was caused by the fact that I had different durations on a couple of pictures. Once I reset all pictures to the same duration I found I could do the following:
After note:
Thanks for your help.
