Creating Time Lapse Video from set of pictures
Feb 13, 2011 10:43 PM
Is there a way to set the duration of all pictures when creating a video from a set of pictures?
I can see that you can select individual pictures, use the "time stretch" and reduce the duration of the picture.
However, if I select all the pictures, in the timeline, and try the same thing the value in the "time stretch" menu is grayed out/ not editable.
Also are there any good tutorials published on creating a time lapse video from a set of pictures.
It appears to me that the help function only deals with the built in tools and they are focused on capture of pictures for time lapse video.
Thanks.
    Feb 14, 2011 12:59 PM   in reply to dorich24
    Depending on what I want to do with either Time Lapse, or Stop Motion, I set the desired Duration in Edit>Preferences, before Import. There is no easy way to adjust the Duration, after Import, other than click-drag on the Head, or Tail, and probably with the Info Panel open.
    For most Stop Motion, I like a 3 Frame Duration, though that does differ by the subject matter, and the "look" that I want.
    Good luck, and hope that helps,
    Hunt
    PS - don't forget to reset the Edit>Preferences>General>Still Duration back, or you will be surprised, when you do, say a Title.
    Feb 14, 2011 2:23 PM   in reply to dorich24
    Good news, and thank you for reporting your steps, and your success.
    Good luck,
    Hunt
