How does one permanently set illustrator to save at its fine drawing state and go to the 72 dpi state on those rare occasions one like me wants low resolution instead of fine drawings?
When I open an illustrator 10.2 document with illustrator CS5 and then save the new document there is a warning that the new document is 72 ppi or less. If I copy and paste the old drawing onto a new illustrator CS5 file it behaves normally. It seems very inefficient to go through years of drawings and copy and paste all the layers into new documents but I guess if that's the only way I will just gradually do it.
There is a way now, for new documents you create. Use a "print" profile when you create a new document.
Your issue is due to the opening of old documents that were set incorrectly. There's no way to tell old documents to change unless you open them. Originally when you created the old documents, the settings were wrong. Since Illustrator has gorwn up a bit, it's now showing you things are set incorrectly, previously you simply didn't notice the incorrect setting (but it was still wrong just the same).
