jacq_vyr
Background missing when exporting from indesign to pdf
May 18, 2010 12:55 PM
Sometimes when I export a file  from indesign to pdf, my background doesn't show up. The background is  just a block of solid colour, or gradient. The background block of  colour is usually the full size of the page. I've tried to play around  to see what is causing this to happen and sometimes if I reduce the size  of the block to say, 1/3 of the page then the block of colour shows up,  but then when I make it the full size of the page as I actually need it  to be, the colour block doesn't show up when I export it to pdf (i've  tried all the different pdf presets and it doesn't make a difference)???  Does anyone know why and how to fix it?
thanks!
    May 19, 2010 2:25 PM   in reply to jacq_vyr
    I see nobody has had any ideas yet. Maybe I can get the ball rolling.
    Do you get any error or warning messages during the export? What settings are you using? Have you tried any of the other presets?
    Is the background visible when you go to Preview mode or use Overprint Preview in ID?
    What version of ID are you using? Is it fully patched? What is your OS?
    May 19, 2010 3:21 PM   in reply to jacq_vyr
    I have seen this plenty of times in the past, I think up to CS4, definitely CS3.  When I had a very basic page with an overall coloured background made with a rectangle bleeding off all four sides, sometimes it would not appear at all in PDF.  I found that the program is not clear about which page the object belongs to and would assign it to a neighbouring page where it was actually out of sight to that page.
    As more items were added to the page, it was as though the item would interact somehow with those items and suddenly start appearing, so I would put hidden items behind the missing object and that seemed to help.
    I have a strong feeling that this stopped happening part way through CS4, so maybe there was an update that improved the behaviour, you could try updating or putting more things on the page.  Or start drawing the rectangle on the desired page and then drag edges to make the bleed to ensure that it is still attached to the appropriate page.
    May 19, 2010 3:49 PM   in reply to jacq_vyr
    jacq_vyr wrote:
    ... it doesn't show in overprint or preview mode.
    Are you saying that in ID it disappears in overprint or Preview mode, or that it still doesn't appear on screen in the PDF?
    If you don't see it in ID in those modes it means it's set not to print.
    May 19, 2010 5:07 PM   in reply to Peter Spier
    I experienced the inconsistent appearance too, it was dependent on how the subsequent app was using it, if there was an adjoining page with the missing part 'hanging off', it would be visible on the desired page but still seemed to be part of the neighbouring page but when viewing the single page alone it would not be there, of course...
    Sorry I can't give examples, I have not seen it in a while, as I said, I expect an update has ended it.
    May 19, 2010 5:25 PM   in reply to jacq_vyr
    Agree...the preview modes seem to be single page mode where the neighbour is ignored and the print RIP and InDesign main mode are 'spread' views where the distant item is valid.
    May 26, 2010 11:52 PM   in reply to jacq_vyr
    If possible, can you provide us with the sample indd file where you are encountering this problem?
    Feb 15, 2011 11:03 AM   in reply to jacq_vyr
    I have been pulling my hair out on this problem as well.  I am using CS4 ID and Acrobat Pro 9.  I originally thought it was an ID EXPORT problem.  But now I think it is some DISPLAY problem in Acrobat.
    I work for a magazine and we are constantly making ID files into PDFs and sending them to press.  This problem has shown up for me in the last few months.  I believe related to an update or some settings of Acrobat.  I have a coworker who is using the same software as me and DOES NOT have these issues when looking at the same files.
    EXAMPLE:
    here is a tester ID file I made with a CMYK gray background and some text on top:
    http://ccie-media.s3.amazonaws.com/downloads/acrobat_problem/backgroun d_test.indd
    Here is the PDF  EXPORT SETTINGS:
    http://ccie-media.s3.amazonaws.com/downloads/acrobat_problem/export_su mmary.txt
    Here is the PDF that I made (that likely looks correct on your machine.  It looks correct on my coworker's macbook)
    http://ccie-media.s3.amazonaws.com/downloads/acrobat_problem/backgroun d_test.pdf
    Here is a JPEG of what I see on my screen (macbook pro circa 2008 running 10.6.3)
    http://ccie-media.s3.amazonaws.com/downloads/acrobat_problem/backgroun d_test.jpg
    Here is the OUTPUT dialog JPEG-  my Acrobat does not recognize any background color in any plates... even when I run the crosshairs over the background to get percentages of color... all 0%)
    http://ccie-media.s3.amazonaws.com/downloads/acrobat_problem/backgroun d_output.jpg
    When I print this PDF out on a printer-  the background is there.  When I send to other people the background is there.  I believe the PDF file is fine... but it is an ACROBAT display issue that I am missing...  like FAST WEB VIEWING or some weird thing like that.  Let me know if you have any insights
    Feb 15, 2011 11:33 AM   in reply to birdtone1
    In this checked in your Acrobat preferences. It is a user setting so you can't force it on anyone.
    Feb 15, 2011 11:34 AM   in reply to birdtone1
    Your links don't seem to be working....
    Screen captures can be embedded using the camera icon:
    Does your background show in ID whe you go to Overprint Preview?
    Feb 15, 2011 1:32 PM   in reply to Peter Spier
    YES-  the Show Large Images box is checked - although I suspect it something like this...  headache box is clicked.
    Links - sorry-  something is up with my Amazon S3 permissions
    Here is all of the above files in a ZIP (1.2MB):
    http://www.ccie.com/scott/background_problem.zip
    YES - background shows up in ID with overprint preview and in every other viewing option that I can find in ID.  The problem shows up in the PDF.
    Feb 15, 2011 2:55 PM   in reply to birdtone1
    Everything looks just peachy (or should I say gray?) here.
    When was the last time you did a general cache cleaning on your Mac?
    Feb 16, 2011 10:08 AM   in reply to Peter Spier
    No - I can't say that I have ever on this machine.  What is the preferred way to do this ?   Trash my library cache folder ?
    Feb 16, 2011 11:39 AM   in reply to birdtone1
    I'm not a Mac user, but I think most would recommend running a utility like Cocktail.
    Apr 7, 2012 1:14 PM   in reply to jacq_vyr
    I have CS5 and I am having the same problem. Except even when I try to print directly from the PSD I still get no background color
    Apr 7, 2012 1:43 PM   in reply to Seamisti
    Seamisti wrote:
    ...when I try to print directly from the PSD I still get no background color
    Are you working in Photoshop or InDesign? This is the InDesign forum...
