I have built a custom workpace as per the requiremnts. also, custom approval container,
now what is happening is that while submit the data from custom workspace , it is throwing exception;
Exception when invoking service 'remoting-service': flex.messaging.MessageException: Cannot invoke method 'prepareForSubmit'. Method 'prepareForSubmit' not found.
incomingMessage: Flex Message (flex.messaging.messages.RemotingMessage)
operation = prepareForSubmit
parameters = [EBB9CD44-7C5C-102D-8E25-00000A051045, 2902]
clientId = BC3D5FB2-9709-5A3C-5C2A-92AB0A3A1430
destination = task-actions
messageId = A3AA04BE-D287-DAE6-C042-2D277978BD5A
timestamp = 1297837685127
timeToLive = 0
body = null
hdr(DSId) = BC3CAB65-5D1C-688A-272F-3D7C4343E301
hdr(DSEndpoint) = workspace-polling-amf
Exception: flex.messaging.MessageException: Cannot invoke method 'prepareForSubmit'. Method 'prepareForSubmit' not found.
at flex.messaging.util.MethodMatcher.methodNotFound(MethodMatcher.java:3 78)
at flex.messaging.util.MethodMatcher.getMethod(MethodMatcher.java:186)
at flex.messaging.services.remoting.adapters.JavaAdapter.invoke(JavaAdap ter.java:420)
at flex.messaging.services.RemotingService.serviceMessage(RemotingServic e.java:183)
at flex.messaging.MessageBroker.routeMessageToService(MessageBroker.java :1406)
at flex.messaging.AsyncMessageBroker.routeMessageToService(AsyncMessageB roker.java:571)
at flex.messaging.endpoints.AbstractEndpoint.serviceMessage(AbstractEndp oint.java:1005)
at flex.messaging.endpoints.amf.MessageBrokerFilter.invoke(MessageBroker Filter.java:103)
at flex.messaging.endpoints.amf.LegacyFilter.invoke(LegacyFilter.java:15 8)
at flex.messaging.endpoints.amf.SessionFilter.invoke(SessionFilter.java: 44)
at flex.messaging.endpoints.amf.BatchProcessFilter.invoke(BatchProcessFi lter.java:67)
at flex.messaging.endpoints.amf.SerializationFilter.invoke(Serialization Filter.java:165)
at flex.messaging.endpoints.BaseHTTPEndpoint.service(BaseHTTPEndpoint.ja va:293)
at flex.messaging.MessageBrokerServlet.service(MessageBrokerServlet.java :364)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
and form remains as usual in workspace. this is not happening with only my custom apprval container but also with default and approval container too.
it's seems to me there is some probem with my custom workspace code. as it is working fine with default workspace.
what i did, was created custom login, as well as some header comp and just lc:ToDo componet to which session is bound in Main.mxml.
what is going wrong here? can anybody explain?
want to add some more is that "prepareForSubmit" is present in TaskManager - api project - workspcae source code. But what i don't understand why it is not able to found it?
Thanks a lot Jon.
it working fine now. after reading your comments i realised my mistake. what i did actually, when i was customizing workspace code, i found files missing and realised that it contains bugs. so, i decided to apply workbench sp1 update for Es2 gm which updated the workspace source code.
and i started working on new souce code and after customizations done , i deployed it on server. but i found that when i was hitting any of the approval container window task, which involves interaction with livecycle. it is generating fault events. i put my whole day into debugging and sorting out. but no results.
as per the exeption, after you hit approve or deny button , it will go to TaskManager.prepare forSubmit() and there in taskutem ation , it is generating faultevent instead of resultevent for reason beyond my fathom.
But ,after you said about version mismatch, i got it imedaitely, that i applied the sp1 update to workbench only and not to server. So, i applied it to the server and sort out some issues while that. and finally evything working gr8 again.
thanks once again Jon.
