Can Illustrator increment labels?
Feb 19, 2011 5:48 PM
Hi, we'll be getting a laser engraver, and have been considering Illustrator to format the designs. Some of our engravings will include serial numbers. So I was wondering (having never used Illustrator) if I could create a file containg, say 10 identical engravings - except for an automatically incrementing serial number (I would set the first serial number, and the 9 others would follow). The 10 engravings would be applied to 10 similar parts simultaneously.
Am I looking into the right kind of software?
    Feb 19, 2011 5:54 PM   in reply to Mickey McFly
    Illustrator does not do auto-incrementing.
    You may be able to implement something using variables and scripts. But by default, there's no mechanism in Illustrator for what you're seeking.
    Feb 19, 2011 6:08 PM   in reply to [scott w]
    A variable of that nature would require a data base that generates the sequence and a script to update the variable in Illustrator.
    However you could set up the numbers manually save it as a data set do the same for the next sequence of 10 numbers and save that as a data set and so on then when you load the art which can also be a variable, then load the data sets but this is worthless if the sequences differ from art to art and when printing you will have to do ten at a time oose the data set and print again.
    You can script this but it takes a very good script creator to do this. I am sure it would not be cheap.
    There might be a plug in.
    Feb 20, 2011 5:50 AM   in reply to Mickey McFly
    This page describes two AI Javascripts that can be used to create serial numbers.
    Of course, it's also a trivial matter to use the Fill Down command of whatever spreadsheet program you already have on your computer (Excel, etc.) to generate a list of serialized numbers, select the column, copy, and paste into Illustrator:
    JET
    May 3, 2012 9:26 AM   in reply to JETalmage
    Thanks for the response. Are those scripts hosted anywhere else by chance? I've tried looking and can't seem to find them anywhere. We are running a charity event and would like to add serially incremented numbers to the tickets.
    Thanks.
    Andre
    May 3, 2012 9:34 AM   in reply to AndreNgo
    If you have access to InDesign, you might find it's Data Merge feature much easier to use. Just place your AI graphic in InDesign and setup a variable based on a spreadsheet.
    Dec 21, 2012 5:25 AM   in reply to JETalmage
    Does any body have the scripts that JETalmage is referign to. I would like to see how they work. I click the link but it seems to be gone. Thanks
    Dec 21, 2012 7:31 AM   in reply to pctechtv
    This may not be what JETalmage is referring to. It is a script to convert Excel to AI-compatible XML file, for use with the AI Data-driven graphics.
    http://dl.dropbox.com/u/3910250/Excel_Text_to_AI_XML.zip
    Dec 21, 2012 2:29 PM   in reply to rcraighead
    Thanks so much. Where would I begin using this script, Excel or Illustrator? I know something about adding scripsts to Excel via the Developer Tab. I tried there and via Illustrator Scripts folder. I am using Illustrator CS6. I am anxious to see how this works.
    Dec 21, 2012 2:35 PM   in reply to pctechtv
    If my memory serves me right, you can drag an Excel file onto the script and it will generate an AI-compatible XML file of the Excel text file.
    Hmm… after opening the zip file, it may be a PowerPC application. Sorry, it won't work on newer Macs.
    Dec 21, 2012 3:03 PM   in reply to rcraighead
    Thanks for trying anyway. I am on Windows. I am pretty good with Excel and found a way to do it. Wanted to try your help as well. I have never used the Variables Panel much in Illustrator I am now discovering that it is a powerful tool. I like InDesigns DataMerge features but some times more than what I need. I find I have better control over intrecate graphics if I just keep them in Illustrator. Some times I link my Illustrator files in InDesign and use DataMerge, and it works great. Exploring the Variables Panel more and experimenting I see I don't always have to combine Illustrator and InDesign, I can just use Illustrator. Thanks again!
    Dec 21, 2012 3:15 PM   in reply to pctechtv
    Sure. It's been several years since I used that tool. It simply converted the Excel text file to an XML file compatible with AI. Glad you found a solution. There seems to be very little documentation on that portion of AI.
    FWIW… Here are a few samples of variable graphics I did, using AI and PSD several years ago. The skater card was done exclusively in AI and could not have been accomplished using InDesign data merge.
    Dec 21, 2012 4:47 PM   in reply to rcraighead
    Very nice!
