Tiigra
Project bin shows over pictures, not under
Feb 21, 2011 12:45 PM
I have been using PSE for a few months now.  Previously when I enlarged the picture that I was working with it would show above the Project Bin.
All of a sudden something changed and now the enlarged picture goes under the Project Bin so that its bottom is covered.
If I somehow changed something in the options, it happened inadvertently and I definitely was not opening any options dialogues and changing anything there.
Is there a way to make the pictures cover the Project Bin, not vice versa?
  • 99jon
    Jan 6, 2010
    Feb 21, 2011 1:03 PM   in reply to Tiigra
    Click reset panels on the top menu to put it back in the correct position.
    Then you can click Window on the tool bar and check or uncheck project bin from the drop down menu - to show or hide the bin as you wish.
    Feb 21, 2011 2:50 PM   in reply to Tiigra
    Check under Preferences>General and check Alow floatng documents in
    Full Edit Mode if it's not checked and see if that makes a difference.
    You may be working in the tabbed image mode.
    MTSTUNER
