I am trying to get the name of the connected machines to client machine. Does any external API support this feature? But not getting single clue.
Please suggest me.
Thanks in advance....
I doubt there is any way to do this in a Flex based web app. On the server a CGI Variable will contain the IP Address of the machine that made the remote call. But, this could be masked with routers and internal vs external IPs. For example five computers in my home network share the same Internet connection and therefore all use the same IP address. This is a pretty common setup. Getting the names of machines connected to the client would be impossible from the server.
If you're running an AIR app, you may be able to use NativeProcess to execute a program on the client machine to get the information you need. This is way out of scope for what I'd expect to be built in as a Flash Player or AIR API.
I do not know about air, but for flex app, if you are calling server, you can get IP of the machine which is callin the server from the request object in the server (if you are using j2ee in the server).Same for the blazeds.
http://old.nabble.com/-flex_india:17272--Example-to-get-Client-ip-addr ess-td20951629.html
http://stackoverflow.com/questions/1352751/can-i-get-the-clients-ip-ad dress-in-an-lcds-service-call
http://www.exampledepot.com/egs/javax.servlet/GetClientInfo.html
I worked on Scanner on the client machine, how they do is, they have a .dll file in the windows folder of the PC, and, there is a library in the Java applet which calls the dll to communicate with the scanner. I've no clue on how the applet calls the dll from the browser. but, I load applet(which is signed) and call the dll, get the data as the image and save it into the server.
Twain is the dll
Morena is the Java applet
