I was wondering if there is a way to automate the export of an Adobe PDF Form to XML, either using the Adobe SDK/AcroExch.App or the PDF Test Toolkit.
I'm wanting to perform this action via a QuickTest Pro Script and thought there might be a funciton already written to perform this action, rather than having to automate the selection of Document>>Forms>>Export Data... from the Adobe Reader Menu and the Export Dialog.
Any suggestions would be much appreciated ![]()
Thanks in advanced,
Ross
Are you trying to edit the Adobe Test Toolkit ? If yes, I think it’s not easy to edit Adobe Test Toolkit. If you want to export PDF file to Microsoft XML file and Adobe is not working with you, than I will recommend you to try Classic PDF Editor which can easily export PDF files to Microsoft XML files. Classic PDF Editor also done many other type of file conversation like PDF to Doc, XML, PPT etc
If Classic PDF Editor solve your problem, must come back share your important views about this software.
You may checkout the video tutorial of how to convert XML file to PDF file http://vimeo.com/20467374
