How / Why is audio being truncated
Mar 1, 2011 1:47 PM
Basic Problem:  All the audio on imported video clips is being cut off after approximately 7 secs.
Description:
I have a set of clips that were made on a Nikon Coolpix. They were imported firstly into iMovie where they played correctly. Then I imported the same clips into PRE.
I moved a couple of clips onto the timeline where they appeared to play correctly.
I started experimenting with a narration track, the narration coming from a USB mic.
I now find that the audio on the video tracks is truncated after about 7 secs, in other words the sound starts playing and then stops at about the 7 sec mark.
If I detach the audio from the video and look at the waveform you can see the first 7 secs as an expected sound waveform and then the display changes to a rectangular box with no sound waves. I tried to capture an image of the waveform, or lack of it but it appears that the waveform view is on the same level as the screen capture process so I can't capture the image.
All of the clips seem to be suffering from this problem suggesting that I must have changed something at the macro level to create this problem but I'm at a loss to know what would effect it.
I'd appreciate any pointers as to what might be the source of the problem and how I might correct it.
Thanks.
Background:
OS X 10.5.8
PRE 9.0.1
    Mar 1, 2011 2:17 PM   in reply to dorich24
    Did you let the Conforming of your Audio to complete 100%? That is the main reason for truncated Audio - one begins editing, before Conforming completes. This ARTICLE will give you background.
    Good luck,
    Hunt
    Mar 2, 2011 8:23 AM   in reply to dorich24
    Interesting observations.
    Going back to Conforming, there is a little progress bar at the very bottom-right of the GUI, that shows the progress of the Conforming. PrE must Conform the Audio stream to 32-bit, floating point for accurate editing. The closer the Audio is to 48KHz 16-bit PCM/WAV, the shorter the Conforming time will be, and might go by so quickly, that one would miss it. The Duration of the Clip also plays a role in how long this progress bar will display. On a short, 48KHz 16-bit PCM/WAV Audio stream, it will be in the blink of an eye. For, say 32KHz 12-bit Audio, and a long Clip, it might take a minute, or more to Conform. I recommend not even touching the computer, while Conforming is going on, and to definitely NOT drag any Clip to the Timeline, while Conforming is in progress. One should just be patient.
    Now, Adobe programs have issues with some MPEG Audio, whether muxed (Multiplexed into a single file with both an Audio and Video stream), or even just an Audio stream, like an MP3. MPEG Audio can just be problematic, and the issues can manifest themselves in various ways.
    When dealing with MPEG Audio, I always convert to 48KHz 16-bit PCM/WAV, outside the program. If muxed, then I rip the Audio from that combined file, convert it and Import it separately. If an elemental stream, say an MP3, then I just convert before Import. I use Adobe Audition, but the free audio-editor, Audacity, will do this too, and do it well.
    Many Nikons use the MJPEG CODEC for motion, and I believe with MPEG Audio. Though I have a handful of Nikons, I have to admit that I have never used any for motion capture, plus my units are rather old by today's standards, so even a test might not apply with newer Nikons. Were I faced with MPEG Audio, I would rip, and then convert everything to PCM/WAV 48KHz 16-bit, and be done with it.
    Good luck, and hope that you have found the key to editing the material. Does your Nikon use the MJPEG CODEC, regardless of what the format "wrapper" is? What is the CODEC used for the Audio stream in those muxed files? Just curious.
    Hunt
    Mar 3, 2011 8:31 AM   in reply to dorich24
    I assume that once its imported the conforming process "sync's" the audio with the video?
    In most cases, after Conforming, there is no loss of sync.
    Now, some of that can depend on the specs. of the original Audio stream. When there is OOS, it is usually because the original Audio stream used some form of MPEG CODEC. Those can, and often do, cause issues. One of the reasons is that the block size for MPEG Audio is different than for Video. In short Clips, this is never noticed, but with very long Clips, can manifest itself as dynamic OOS.
    If one does encounter OOS, whether static, or dynamic, this ARTICLE might be useful.
    Good luck,
    Hunt
