Interactive Statement - why doesn't it update in LC?
Feb 27, 2011 1:29 PM
Hi there!
After editing the .nav file and the XML, nothing changed when i invoked the process from Workbech, even after undeploying, checking out checking in and deploying again the solution.
Previously, as a test, I copied the .nav from Flash Builder structure and pasted it in a folder I called assets in LC structure.
So when I invoke the AssembleStatemente process, I indicate the new XML file in *data field, the new .nav in the documentTemplate field and the other new XML file in the *packageDefinition field.
After all this, I still get the old .nav and XML in the statement. Why?? This is not intuitive!
Thank you for any hints.
Marcos
    Feb 28, 2011 5:45 AM   in reply to Marcos J Pinto
    That's all you should have to do. As long as the Package definition, Document templand and XML data fields are correct, then the process should give you a portfolio with the new templates/data.
    Is there more than one version of your application on the server?  If you choose File -> Get Application do you see other versions of your application in the resulting dialog box?
    You also may try right clicking on your process in the Applications tab and select Synchronize.
    Mar 1, 2011 12:29 PM   in reply to Marcos J Pinto
    Before you do that, you may try deleting the local copy first.
    Close workbench
    On your local machine, go to the Workbench ES 2 directory (in mine its under (c:\Users\username\Workbench ES2).
    There you should see a folder with the server name.  In that will be another folder with the application name and another with the the version number.
    That folder should contain at least two files for each process.
    For example I connect to a server called pike to get an app called myApp 1.0.  The files are in:
    c:\Users\hodmi\Workbench ES2\pike\myApp\1.0\
    Delete the entire application (myApp) folder (or move it somewhere safe).
    Restart Workbench and re-synch.  That should pull down the version that is currently running on the server and you should be able to carry on.
    Mar 2, 2011 11:24 AM   in reply to Marcos J Pinto
    That's just strange, its the first time I've heard of that happening.
    If you check out, make changes, save and deploy now does the server get updated? If not, then you may have to create a new application.
    Mar 3, 2011 1:28 PM   in reply to Hodmi
    Hi Marcos,
    Before deleting your application in Workbench, you might want to make sure that your process does not cache the .nav.
    In Workbench, open your process and check that field "Caching ID" is empty:
    Hope it helps,
    Oana
