xcoy0teee
Can't get widget browser to work
Mar 1, 2011 6:22 PM
Hi., I installed the widget browser and its giving me this
Failed getting Widget Feed. Reload | Show More Information
Show more information :
Failed getting Widget Feed. Make sure you are connected to the internet.
Unknown error.
Tried signing in :
The login attempt timed out.  Make sure that you are connected to the internet, and try to log in again.
I am connected to the internet,. I cleared all cookies, and have it on Accept All Cookies in both Firefox and iExplorer.
Please someone help me
Thank You
Kylie
    Mar 1, 2011 10:14 PM   in reply to xcoy0teee
    Hi Kylie,
    Do you have a firewall that could block outgoing communication from Widget Browser? If yes, you need to add an exception for Widget Browser to allow it to connect to the internet.
    Mar 2, 2011 10:24 AM   in reply to xcoy0teee
    Are you able to connect to http://www.adobe.com using your browsers? Maybe you have an internet filter that is blocking access to that site?
    Also, you may need to allow internet access to Adobe AIR.
    When all else fail, you could also try rebooting your machine & uninstalling/reinstalling Widget Browser
    Mar 2, 2011 7:30 PM   in reply to xcoy0teee
    Hum, maybe you have a corrupted cache.
    Are you on Windows 7? If yes, go to C:\Users\yourname\AppData\Roaming & look for a folder named com.adobe.WidgetBrowser.
    Delete it.
    Then, go to  C:\Users\yourname\AppData\Roaming\Adobe\AIR\ELS & look for a folder named com.adobe.WidgetBrowser
    Delete it also.
    Launch Widget Browser & see if it works.
    Mar 4, 2011 10:15 AM   in reply to xcoy0teee
    Hello,
    In order to see those folders, you may need to enable the "Show hidden folder" option on your pc (Start>Control Panel>Large Icons view>Folder options>View tab>Advanced Settings>Show hidden files, folders, and drives)
    But, it looks like some other user (JudeGr) may have found the solution. Can you try it:
    http://forums.adobe.com/message/3442087
    I hope this does the trick
