purplthundr
SVG Plugin and Operation Can't be Completed Error Msg
Oct 1, 2010 10:55 AM
Just added the HTML5 Pack to Illustrator and now I get two error msgs every time I open Illustrator that says "error loading plugins SVG file format.aip" and a "Operation cannot be complete because of an unknown error." Is there a fix to this? I'm on a Windows XP system.
Thanks in advanced!
    Oct 4, 2010 9:54 PM   in reply to purplthundr
    Did you follow the install instructions completely?
    Can you try doing it once again i.e. take the install zip on Windows and extract at the correct location as per the install instructions.
    When do you get message "Operation cannot be complete because of an unknown error."? On application launch itself?
    Mar 5, 2011 5:18 AM   in reply to purplthundr
    Hi there,
    I get the same error-massage, and have the same problems with the SVG-file-format-plugin.
    Anyone knows how to fix that??\\Thanks
    May 11, 2011 5:59 AM   in reply to purplthundr
    Hello there, i've updated ai to 15.0.2 and installed the pack, but i've got the same error!! i installed it following the instructions very carefully... how does it fix? anyone has the same error? I'm in a 64bit windows 7 (but my ai is 32bit)
    thanks fof the help
