Layer won't unlock
Aug 9, 2008 2:12 PM
I've been using Fireworks for about 7 years (Mac and PC current problem is on Mac) so there's not a lot I don't know about it although I admit I haven't spent a lot of time learning new features in CS3 but for the first time I have a layer I am unable to unlock.....It shows the lock I click to unlock and it just fades the lock. Its an un-unlockable lock. I can lock and unlock other layers no problem but this one layer is stuck. If it helps this WAS a sublayer when it was originally locked. Now it is at the root level.
I really really really do not want to delete whats in this layer but I can't get into it.
    Aug 10, 2008 3:05 AM   in reply to seanmayhew77
    Hi, are you trying to unlock a template of some kind? I ask because
    another Fireworker had a problem with unlocking a template folder. My
    copy of FWsCS3 has just locked me out with that wretched 'Hand'
    cursor problem, so I'm going to have to do a system re boot, if that
    cures it (usually does) I'll have another look and see if I can
    fathom it out.
    Peter
    ______________________
    "seanmayhew77" <webforumsuser@macromedia.com> wrote in message
    news:g7l18h$fi4$1@forums.macromedia.com...
    on
    have
    it
    other
    sublayer
    can't
    | get into it.
    Aug 10, 2008 4:24 AM   in reply to seanmayhew77
    This is what worked for the other guy who had a problem with this.
    1. Open up the image source file in Fireworks CS3
    2. Then look to the top right of the screen/workarea,
    3. Click on "Pages" then on layout[Master Page],
    4. Then select "layers" proceed to unlock the sections you need to work
    with.
    Peter
    ___________________
    "PJR" <flash@SLICEreclusivebillionaire.com> wrote in message
    news:g7mehr$2sg$1@forums.macromedia.com...
    | fathom it out.
    | Peter
    is
    | on
    haven't
    | have
    | it
    | other
    | sublayer
    | can't
    || get into it.
    Mar 5, 2011 3:46 PM   in reply to seanmayhew77
    I had this issue and saving the  file , quit FW and restarting solved the problem...
    Aug 16, 2012 11:52 AM   in reply to seanmayhew77
    Just FYI, if anyone else has this problem. I just had this same problem with a layer in Fireworks CS5 and I tried what estilan suggested above. It worked like a charm!
    Feb 23, 2013 8:20 AM   in reply to seanmayhew77
    Right. This is so so so simple i cant believe it. Steps:
    1. Go to your layers tab.
    2. scroll up.
    3. unlock ALL the layers you can
    It will work; trust me, I had the same prob, (faded the lock on mine to) and this worked swell!!!
    Feb 24, 2013 5:24 AM   in reply to jrdalby811
    Another helpful tip... if you click the alt/option key on the lock toggle it will lock or unlock all your layers. Note though,,, sometimes your sublayers will still remain locked. Usually repeating the Alt click + lock toggle will release the sublayers as well.
    *Note all things locked in the master page layer(s) have to be unlocked and edited when you are in the master page.
