If I have a paragraph of type, ranged left (example below) set out with no widows/orphans etc but I have a word starting on its own, what is the correct way to solve this? Start a new paragraph or leave it on its own? Sometime when i do this I get a lot of space that looks wrong.
example:
...for example researcher, recorder. They
build the table...
Hope this makes sense.
thanks in advance
silverbadger,
At least I am unsure of what you mean. The only word by itself is example, but is that the word or just a heading showing what we should look at?
Could you post another case that is more recognizable? Maybe something with a greater line length and previous/following paragraphs.
Jacob's correct in saying -
function(){return A.apply(null,[this].concat($A(arguments)))}
function(){return A.apply(null,[this].concat($A(arguments)))}function(){return A.apply(null,[this].concat($A(arguments)))}function(){return A.apply(null,[this].concat($A(arguments)))}Jacob Bugge wrote:
Ah, silverbadger.
As Herb says.
Whether you use Justify (Full Lines) or Align Left (there may be different terms in different applications), normally you just let the type/text flow over the lines as they may fit, with or without hyphens, regardless of sentences/full stops.
But, (isn't there always a but) there is a stylistic case to be made for avoiding line breaks that potentially 'trick the reader's eye.' We tend to read text a line at a time unless there are lines longer than we can process in a single pass. You can follow this link to see a sample article on the subject.
http://baymard.com/blog/line-length-readability
The reading and comprehension process can also be interrupted when the 'topic' changes abruptly, especially at the beginning or end of a line. This includes lines that break after a short word at the beginning of sentence, like A, I, O (rare), At, By, etc. You can probably think of several more examples. I'd also include The (as in the original post) as it can be the very devil to proof-read correctly.
Consider this snippet:
He was a tall man with a military bearing which he threw in the air and caught. The
the example here comes from that especially enchanting book, 'Puckoon' written by
Spike Milligan.
Many readers will fail to pick up the repeated 'The the', and some spelling checkers get confused by the different capitalization. So, its probably better set (using a 'hard space' to force the issue) as:
The example here comes from that especially enchanting book, 'Puckoon' written
by Spike Milligan.
As for A, I, etc -- the isolated letter just looks daft.
In summary, the rule is that there are no rules. Type should both look right and flow right, so the reader's brain isn't distracted by the visual anomalies.
