Repeated file loss in PS CS5
Sep 21, 2010 12:18 PM
We have been having repeated loss of files when saving to network drives from PS CS5, version 12.0.1. This is on MacPro, 3.32GHz, 16GB RAM, NVidia GeForce GT 120 w 512 RAM on card. This especially occurs when pulling up an existing PS file into CS5 working with it and then saving it back. After repeated saves (3 or 4) the file will no longer save with "unexpected end of file encountered ...". Fortunately, the file has still been on the screen and saveable to the desktop, but not always. A recent save resulted in complete loss of the file on the network drive. The network drive is accessed via smb protocol. We have also gotten the error "Could not complete your request because there is not enough memory (RAM)." This is coming up several times a day among the three designers on identically configured machines. Any help or suggestions would be greatly appreciated -- Best, Tom
    Sep 21, 2010 4:45 PM   in reply to TomCA0
    Something is wrong with the server or network.
    Until that can be resolved, don't save over the network -- save the file locally, then copy it over the network via the Finder (which is what we normally recommend, given all the things that can go wrong with network file systems).
    And why the default MacOS APIs can't handle error correction over the network is a mystery to us as well, but the Finder does additional error checking and will usually catch more network errors.
    Sep 21, 2010 7:56 PM   in reply to TomCA0
    TomCA0 wrote:
    …we upgraded our PPC G5's to Intel G5's…
    There is no such animal.  All G5 Macs are PPC machines.
    If they have an Intel CPU, they are Mac Pros, not G5s.
    Sep 21, 2010 8:00 PM   in reply to TomCA0
    As for your issue, please check this old post as an example of many old threads explaining why Adobe can't support working across a network:
    http://forums.adobe.com/message/1934807#1934807
    ____________
    Wo Tai Lao Le
    我太老了
    Sep 21, 2010 8:01 PM   in reply to TomCA0
    We see similar problems with networks all the time (and have been for as long as I've been working on Photoshop).
    We haven't seen anything really specific to CS5 yet - but we did change a few OS file APIs when moving to Cocoa. The new file APIs could be more or less sensitive to network problems (hard to know until you find the perfect malfunctioning server).
    No, I don't know of any particular bugs in that server version - but that is a bit old, and there are probably a lot of SMB server fixes since then.
    Sep 22, 2010 10:15 AM   in reply to TomCA0
    Again: Photoshop CS5 is a Cocoa application, and uses slightly different file APIs compared to Photoshop CS4, which was based on the Carbon APIs.
    Those OS APIs may have different problems with networked filesystems.  We don't control the code in those file APIs, so we can't tell exactly where they might do better or worse. We've tested with many networked servers on many different protocols and haven't found any problems -- but, again, there's always that one special server.....
    So, yes, there is a change in CS5 - it calls different code in MacOS.  It should be working, but something with your network setup isn't working.
    Mar 10, 2011 8:43 AM   in reply to TomCA0
    Hey Tom,
    I too experience issues when trying to save to a network drive.
    It just started happening when the IT department reformatted my machine (MAC) and installed Snow Leopard. I was previously running Leopard, and saving CS5 files to a network drive was seamless.
    Since the OS upgrade I get all sorts of unexpected behavior when trying to Save files. Sometimes the file completely disappears, more frequently though I get a "Could not save 'FILE' because an unexpected end-of-file was encountered.", which forces me to use the "Save As" command. If I don't "Save As" after seeing that error the file will no longer be visible in the finder when browsing the network drive???
    I'm not sure what's causing this weirdness but I can confirm that I wasn't having these issues before the Leopard -> Snow Leopard (10.6.6) upgrade.
    Look forward to hearing if anyone else has experienced these issues and has a solution to the problem.
    Thanks, r/c
    Mar 10, 2011 3:10 PM   in reply to RomeoCrugnale
    I have noticed various things about file opening and saving in CS5. It seems to be less efficient, (ie there is a weird pause) and generally slower. In CS4 it all runs smooth as clockwork, in CS5 there are inexplicable pauses and a general feeling of inefficiency. This is noticeable even more so, on large files.
    Jul 6, 2011 1:17 AM   in reply to Chris Cox
    Chris: We too, have the same problems after the upgrade to CS5 and Snow Leopard. In our case, it's happening EVERY time we save to a mapped network drive on an other MAC.
    Also, Indesign has comparable issues after the upgrade. Is that using Cocoa APIs too?
      Stephan
    Jul 6, 2011 10:51 AM   in reply to stephan glathe
    InDesign CS5 is not using Cocoa APIs.
    But, again, there are good reasons why we don't support opening and saving over the network.
    We're still investigating issues that appear to be MacOS bugs involving file operations with a network server.  But those problems don't seem to exist when opening or saving locally.
    Nov 8, 2011 6:33 AM   in reply to Chris Cox
    Has anyone with this problem upgraded to OSX Lion 10.7 and noticed that the issue went away?
