My Products.cfc is:
<cffunction name="getProducts" access="remote" returntype="any" output="yes">
<cfargument name="page">
<cfargument name="pageSize">
<cfargument name="gridsortcolumn">
<cfargument name="gridsortdirection">
<cfif ARGUMENTS.gridsortcolumn EQ ""><cfset ARGUMENTS.gridsortcolumn = "artcod"></cfif>
<cfif ARGUMENTS.gridsortdirection EQ ""><cfset ARGUMENTS.gridsortdirection = "ASC"></cfif>
<cfquery name="qryProducts" datasource="#this.DSN#" result="result">
SELECT * FROM articoli
ORDER BY
<cfqueryparam cfsqltype="cf_sql_varchar" value="#ARGUMENTS.gridsortcolumn#">
<cfqueryparam cfsqltype="cf_sql_varchar" value="#ARGUMENTS.gridsortdirection#">
</cfquery>
<cfreturn QueryConvertForGrid(qryProducts, page, pageSize)>
</cffunction>
The query params work correctly, my query runs in the right way but.... the returning JSON is not sorted!
Could this be an error in the queryconvert function?
However my cfgrid doesn't work:
<cfset args = StructNew()>
<cfset args.name = "ProductsGrid">
<cfset args.format = "html">
<cfset args.bindOnLoad = "true">
<cfset args.bind = "cfc:Products.getProducts({cfgridpage},{cfgridpagesize},{cfgridsortcolumn},{cfgridsortdirection})">
<cfset args.stripeRows = true>
<cfset args.selectColor = "##D9E8FB">
<cfset args.selectmode = "edit">
<cfset args.onchange = "cfc:Products.editProduct({cfgridaction},{cfgridrow},{cfgridchanged})">
<cfform>
<cfgrid attributeCollection="#args#" pagesize="20">
<cfgridcolumn name="artid" display="false">
<cfgridcolumn name="artcod" header="xxx">
<cfgridcolumn name="artdes" header="Descrizione" width="250">
<cfgridcolumn name="artdesrc" header="xxx">
<cfgridcolumn name="artcodpr" header="xxx">
<cfgridcolumn name="artcodbar" header="xxx">
<cfgridcolumn name="artprzacq" header="xxx">
<cfgridcolumn name="artprzvend" header="xxx">
</cfgrid>
</cfform>
What am I missing? ![]()
My thinking is that it has nothing to do with cfgrid, and everything to do with cfqueryparam binding. Run the following code on a test page, and you will see what I mean:
<cfset col = "someColumnName">
<cfset sort = "desc">
<cfquery name="qryProducts" datasource="yourDSN" result="result">
ORDER BY
<cfqueryparam cfsqltype="cf_sql_varchar" value="#col#">
<cfqueryparam cfsqltype="cf_sql_varchar" value="#sort#">
</cfquery>
<cfdump var = "#result#">
The SQL that ColdFusion sends to the database server at compile-time is "SELECT * FROM articoli ORDER BY ? ?", plus instructions to use 'someColumnName' and 'desc' as the respective input parameters.
I've tried your version of the default cfset, but haven't had much luck in the past. I typically use something like the following in the ORDER BY section of the SQL:
<cfif ARGUMENTS.gridSortColumn NEQ "" AND ARGUMENTS.gridSortDir NEQ "">
ORDER BY #ARGUMENTS.gridSortColumn# #ARGUMENTS.gridSortDir#
<cfelse>
ORDER BY artcod ASC
</cfif>
Good Luck!
<cfwild>
