I am new to the whole website creation. I used the Spry Image Slideshow widget from the widget browser and everything works perfectly when I tested it locally. However, once i uploaded to the server and tested the links I get errors stating that it cannot locate the .js files. Like stated, I am very much new to this and have no idea how to fix this problem. Has anyone else ran into this or know of a solution?
My website address is www.terranceperdue-architecture.com and the links in question are on the portfolio link.
So more specifically:
http://www.terranceperdue-architecture.com/Design%20Studio%201.html
Any help would be greatly appreciated as I am hoping to use this website to gain an internship for the summer. But if it is not working then that is not an option.
Thanks for any and all insight.
-Terrance
Alright, so first off. Thanks for all the helpful responses!! =) Thankfully I diagnosed the problem myself. If anyone else runs into this problem it is most likely due to all the extra crap written in the code from the widget. I deleted alot of stuff and re-organized the folder layout for all the spry data. Which seemed to do the trick.
However, I have now encountered another problem. Hopefully a much easier one to fix.
When I run the site in firefox everything works as planned. When i open in internet explorer though my spry slideslow is no longer centered as it is supposed to be. I am hoping this is a simple fix as ive seen others run into this problem.
Does anyone know the solution for this problem?
Once again, ANY AND ALL insightt is greatly appreciated. =)
-Terrance
I think i am having the same problem, i get lots of error messages pop up but all the js and css in loaded on to the server. What did you do to fix it.
have a look here dj for charity photos
if you could tell me the code you took out to get it to work and what order you put the files in, as i have no clue where to start on this
thanks
dj4charity
I see where you have posted that you got your slideshow to work, but I do not see any of the reponses on how you did it. I am having the same problem when I test my slideshow locally on dreamweaver it works, but it does not work when I upload it to the internet. It doesn't give me any error, but all it does is show me a black box with a spinning play button like it is trying to load. It doesn't do anything else. I have tried looking at IE, Safari, and Firefox and I get the same thing on all of them.
Christin
sounds like a new problem to me i got error messages and it turned out the Java script file was not right, go to the Js files in a site that is working and get the Js from there, i think i is just one that is not working you should be able to see this in the file, all of the script we be bunched up , hope this helps,
This could also be a conflict with other Java script i am having this problem with my navigation bar and sliding panel i think it an (on load) command one works and one does not but don't quote me on that..
