quote:
An error occurred while installing Adobe AIR. Installation may not be allowed by your administrator. Please contact your administrator.
Tyler - I've had EXACTLY this same problem with the Creative Suite and until now haven't seen anyone else who had the same situa
tion or any solution. Your solution was spot on. I had to make one little change in the sudo command (no spaces in the .app name).
sudo "./AdobeAIRInstaller.app/Contents/MacOS/Adobe AIR Installer" -uninstall
Thanks. Now I can finally run Tweetdeck and Balsamiq on Mac OS X.
Mitchell
Took a peek at the log file from the install. Interesting:
Jul 9 20:27:24 /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1088]: error during install: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
So I went to the directory Applications and found there was an old text file called "Adobe". I renamed that text file, than ran the Adobe AIR installer and it WORKED!!!
So make sure you take a peek at the log files at:
/private/var/log/system.log
Leslie
Brilliant, Leslie. I signed up for this forum just to add my support for your reply. The silliest thing is that Adobe placed the Adobe file there in the first place. When you look at it closer, it has some notification text about upgrading from a trial version of Photoshop or something. We did that, but this file was not removed and prevented Air installer from upgrading 1.1 to 2.
Thanks for the tip.
Z
I tried uninstalling, and it apparently did so (I had 1.5 or something like that installed). There was an app for Uninstall. But I still cannot get the dog-gone new version to install.
Why did the new version offer to update the older version, and then fail to do so or go to completion? Why should I have to uninstall it manually when there was no dialogue to that effect?
I tried the text in Terminal, but no such folder exists.
So I no longer have Air installed for the applications which require it, and I cannot get a new version to install. I click on the Adobe AIR Installer icon, it apparently starts - it shows up in the Dock. But nothing, nada, beyond that.
Here's some of the error report I get:
Process: Adobe AIR Installer [1350]
Path: /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer
Identifier: com.adobe.air.Installer
Version: 2.0.2 (2.0.2.12610)
Code Type: X86 (Native)
Parent Process: launchd [214]
Date/Time: 2010-08-02 18:01:00.039 -0700
OS Version: Mac OS X 10.6.4 (10F569)
Report Version: 6
Interval Since Last Report: 490293 sec
Crashes Since Last Report: 12
Per-App Interval Since Last Report: 809 sec
Per-App Crashes Since Last Report: 6
Anonymous UUID: 7CD0C31E-4CD1-47C3-925D-490C053D72AE
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x000000000000000c
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
What to do? Why is this such a PITA app?
rnfee,
Can you verify if you still have folders/files present from previous AIR?
-Uninstaller file under /Applications/Utilities folder. If still present can launch uninstall?
-Is there an AIR folder under /Library/Frameworks/ Adobe AIR.framwork folder?
Similar to lizbethkirk reply Jul 10. Make sure you have rights to Adobe folders in the follwoing paths if present and that the file also named "Adobe" is not present:
To test if the locked Adobe folders are causing error for the AIR installation...
Can you rename the "Adobe" folders if present and try your specific installation/uninstallation ?
1) /Applications/Adobe - rename Adobe folder to oldAdobe
2) /Users/"your user name"/Library/ApplicationSupport/Adobe - rename Adobe folder to oldAdobe
Leslie,
You hit the nail on the head! This was exactly my problem. I've been going in circles trying all previous solutions. I'm glad I persisted and found your post.
$ grep "Adobe AIR Installer" /private/var/log/system.log
revealed
Aug 10 21:11:20 bhavana-3 /Applications/Utilities/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1781]: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
So I deleted /Applications/Adobe and that worked perfectly!
Thanks so much.
Andy
If anyone is interested, one of the Adobe engineers posted a temp fix (Apple script) that you can download and run. Use at your own risk of course, but I ran it and it fixed my issues instantly (repairing permissions and removing the excess /Applications/Adobe folder if it exists).
I assume they're working on a more perminent fix (maybe even incorporating something like this into the next AIR installer. who knows), but until then this fix got me back up and running.
http://forums.adobe.com/message/3272498#3272498
-Jeff
None of these solutions worked for me on 10.6.5. What finally worked was deleting the folder Users/Shared/Library/ApplicationSupport/Adobe. No idea why. No idea why Adobe's uninstaller could not do that. No idea why it took so long to figure this out. No idea why adobe let's problems like this fester. I am a developer, trying to create Air applications, and it took me several frustrating hours to try this random act of desperation. What's an average user to do? I have only one clue to Adobe's behavior: When I contacted Adobe about this, they insisted I buy a support contract before they would help me.
Hi Steve,
I'm sorry you ran into installer issues with AIR. Its odd that the applescript didn't help you, as it specifically tries to adjust the properties of Users/Shared/Library/Application Support/Adobe. We definitely don't want these problems to fester, believe me I want them fixed asap. Would you mind posting your AIR log so I can take a look and see if anything pops out at me? I'd like to update the script and more importantly, get another bug in our database to fix the root issue if you were seeing something we aren't aware of.
Chris
I'm on OSX 10.6.5
I just downloaded the lastest AIR installer...
What's funny is that when I try to run the installer, and it asks me for my password, I can't type it in!!!
I even tried typing it in the Finder search textbox and copy / paste, but no dice!!!
What's wrong??
I don't have any previous AIR installed.
HELP!!!
Mike
Hi Mike,
You should be able to just use your user account password that you setup when you first created your Mac account. You can change the password, if needed, in the Accounts panel in System Preferences.
Chris
Molasar wrote:
I'm on OSX 10.6.5
What's wrong??
HELP!!!
Mike
The problem is that when the dialog window pops up (so that the AIR Installer can proceed) asking for my password (my user account is already filled in), my keyboard just drops dead!
The cursor is on the password textbox but whatever I do (type), nothing happens.
So I click on the Finder Spotlight Search box and I can type. I click back on the user/password dialog, and again I can't type. Cursor is there, blinking, but nothing gets "typed". It's just dead.
So I figure, ok, I'll type my password on Finder's Spotlight searchbox, copy it, and paste it on the user/password dialog. Doesn't work.
When I call it a night, and exit the AIR Installer, my Mac seems to be unresponsive. I have no remedy but to press and hold the Power button. Nothing works. Can't shut down using the menu, etc. Finder just seems to drop dead. Dock is also unresponsive. I'm like WTF!!???
There is nothing wrong with my iMac, since I can run chunky apps like Logic Pro 9.1.1, Final Cut Pro, Propellerhead Reason, Cinema 4D, etc. no problem. I have all the latest drivers and updates.
I've scanned all drives using Disk Utility, etc. All is ok.
But when I launch the AIR Installer, all hell breaks loose.
I can't figure it out...
I have a 2008 24" Alum iMac, 2.8GHz Core2Duo, 4Gb RAM, 320Gb + 1Tb HDDs, ATI video, stock keyboard and mouse, TC Konnekt 6 Firewire audio interface, Fatar Studiologic VMK-188Plus Master MIDI controller keyboard via USB. Nothing strange or weird here... Everything works like a charm. Nice and snappy.
I love my Mac.... except when I run AIR Installer! (Quick! Where did I leave the shot-gun??)
Thanks for clarifying. This is one I haven't heard of before. What's strange is that this is a system dialog asking for elevated privledges so I'm wondering if you'll run into this using other third party installers. Let's try working around it by doing the following:
1. Mount the AdobeAIR.dmg file
2. Open the Terminal application
3. Type (or copy/paste) the following:
cd /Volumes/Adobe\ AIR/Adobe\ AIR\ Installer.app/Contents/MacOS/
sudo ./Adobe\ AIR\ Installer
Hi Chris,
I'm having trouble installing Adobe Air on an older macbook pro (2006) running MAC OSX 10.5.8. Initially, all looks great and installation seems to be going smoothly until I click "Finish" on the installation window and then another window pops up that read
"An error occurred while installing Adobe AIR. Installation may not be allowed by your administrator. Please contact your administrator."
This is so frustrating especially since it already showed me a "installation complete" window just seconds before!
In addition, I recently purchased CS5 Creative Suite 5 Design Premium a few months back (Sept. 2010) which was when I first ran into this problem. I haven't had a chance to use any of the Design Premium software as of yet, so I'm not sure if any of them are affected.
Please help!!
- Malaya
None of these solutions worked for me. I checked my log and this is the error that occurs during installation:
Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Error #2038" errorID=2038]
I checked for Error 2038, and it seems like it's a permissions issue, but on what directory I don't know.
Thanks; the
sudo "Adobe AIR Installer.app/Contents/MacOS/Adobe Air Installer" -uninstall
worked perfectly for me after I made my way to the Applications directory. Glad to finally find this after suffering with missing features & help for a couple of years now. (Running MacOS X 10.6.8; never had working help for Photoshop Elements 8 or 9 until now.)
I hope I'm not too late to get some help here.
I am by no means a very technical person, so if you could respond in a simple language to get me through this problem.. I would so greatly appreciate it.
Desired End Result: Download Balsamiq Mockup on my MacBookPro
I tried to follow the instructions for uninstalling the previous Version of Adobe Air on my computer, but I am having so much difficulty following what to enter in the terminal, etc..
Bottom Line:
Can anybody help me with step-by-step instructions to remove a previous version of Adobe Air (that came packaged with Adobe CS4) from my computer? So that I can install Adobe Air Version 3.1?
Thanks in advance!!
