Hi John, Yes same thing on the Flash Player Forum. I was able to post one message, then it started with the logged out/signin routine.
So the only way now, I just copy and paste my message, login again and post again. At least I still have my message if it happens the second time. Maybe I'll just paste all of my messages to notepad and when it's working, post them then:-)
Everything worked fine all weekend.
eidnolb
Same thing with the Premiere and Photoshop fora today, Monday, March 21. However, it is less often for me, than from Friday thru Sunday, but is still happening. Copy, log-in, Paste, log-in, read, log-in, type, Copy, log-in...
Yeah, guess that we complained too much about the fora earlier on, as we will all now wish that we had them back, as they once were. "You don't miss your water, until your well runs dry... "
Hunt
Well, in the imortal words of Roberto Duran, "no mas - no mas!"
Tuesday, March 22, 2011, is a day that will live in infamy on the Adobe forums. Since 6:35AM, PDT, I have logged-in over 35 times, with waits up to 5 mins. (yes, minutes), and encountered dozens of Server errors.
To view the updated threads, I log-in, view, go to Reply, log-in, get dumped to the Main Forum page, log-in, navigate back to the thread, log-in to Reply, type, Post - no wait, another log-in, and back to the main forum page, that is, if the server is found - log-in, Post Reply, oops, gotta' log-in again. Post Reply, all OK, then go to see the threads, but gotta' log-in once more. I have managed 5 posts in a little over four hours. This is getting to be just too much.
Hunt
Hi Bill, You are the first sign of life I've seen. Are you saying we have ignition?
Must be true. Well, at least you were able to login.
Update, lost all of my message except above. Received an "unauthorized" message.
Can we sandbox a Server/Forum/Website? ROFL
I'll head over to the FP Forum, but getting logged off here, doesn't make me hopeful.
See ya again, hopefully,
eidnolb
Hi, Well the FP Forum "seems" to be working, however getting logged off when trying to post the message. So, I'm back to Ctrl+C before trying to post message. Then I try again and use the "D
Update at 3:02PM EDT This is the only part of my reply a few minutes ago to you that was "recovered". I used the "Use Recovered" this time just to see how much was recovered:-)
Here is my Ctrl+C:
Hi, Well the FP Forum "seems" to be working, however getting logged off when trying to post the message. So, I'm back to Ctrl+C before trying to post message. Then I try again and use the "Delete Recovered" and paste my original message.
So far that's working.
I think the time stamps are off though.
At least this thread is working, but I'm still using the Ctrl+C just in case. Update: glad I did.
eidnolb
The forums seem to be even worse the morning of March 22
Hi John, I'm not having much of #1,2. But #3,4 yes. I've sent 3 messages since before 3PM EDT. I am seeing that after I compose my message (using the Ctrl+C first) it never goes thru the first time, always logs me off. Then my problem is having the message saved and then trying to remember which thread it is for
Then when I paste the message after finding the thread, it goes thru.
I haven't been here as long as you and others, but I've never seen anything like this on the Internet at all. And I certainly don't understand what is happening and why it can't be fixed.
Haven't heard from anyone but "us" either.
eidnolb
I tried to post these last two messages from IE8 (in which cookies are disabled) and the delay was about 30 seconds. So it appears that some progress is being made to rectify the problem that has affected us last week.
In FF 3.6.15 I have cookies to remember the login details so it should be faster though can't be sure about it.
Have to try FF4 released to day to see if it makes any difference.
This is a "Saved" message that I tried to post here at 11:45AM EDT after getting a "an unexpected error has occurred". No,
it was not "unexpected" to me, since I saved it beforehand:
Different problems today on the Flash Player Forum, so far anyway. Thread opened, but not correctly. No way possible to type a message as the message are didn't open fully. Only showed the title of the thread and "Post message"
Different problems occur, so when one seems to be working, a new one pops up. Then if that one is "solved", then it starts all over again with something else.
Very frustrating, not only for those of us that help on the Forums, but the users as well. 18 to 20 minutes yesterday to get a message to go thru isn't working very well at all.
Granted I don't know what is causing these major issues, but we certainly see the effects.
eidnolb
Just in case someone is interested: I have just installed Firefox 4 in my Mac, and loading times for all sites have shortened noticeably. In these forums, for example, they have gone down from the "normal" of about 5 seconds to a "blazing" little over 2 secons (all times measured with the second hand of a normal analog watch).
Where do they PUT 6,000 spam posts? Surely you don't have THAT many different forums.
If you're getting spammers making accounts at a rate fast enough that you can't keep up with them, doesn't that say that you need new account opening policies?
Surely there must be a method by which the "normal" behavior of reasonable participants can be monitored and differentiated from that of spammers. It certainly seems possible for a human to tell whether someone's makig a reasonable post or just a trash post to get an account established. I report all of those that I see.
-Noel
Noel Carboni wrote on 11/03/25 06:09:
6000 was just one day, the total of that run was around 17000 in one forum.
Yes.
We have that, but it depends on a correctly working search function.
As a forum user that is pretty much you all you can do. Click "Report
abuse" and stay away because for the larger runs it is quite likely that
a forum will be inaccessible during the cleanup. If you reply to spam
messages or in forums that are the target of an ongoing spam run you
should expect some of your messages to disappear as well.
Tai, you are not the only affected participant:
http://forums.adobe.com/message/3570542#3570542
I am getting it in Firefox/Mac and Explorer/Win.
Also, loading times today seem to be twice as long as "normal".
Instead of changing the account opening policies, the simple solution is to allow only 5 messages within any 10 minutes time interval from a particular IP address. If this is exceeded then that IP should be blocked for 30 minutes before any new messages can be posted.
aioe <http://www.aioe.org/index.php?free-usenet-servers> uses this quite safely and their nntp-newsgroups rarely get more than 2 spams in a day.
Careful, you might catch heat for not noticing the Emperor's new clothes.
In all seriousness, I agree with you. Adobe puts forth a nice professional face with much of their software. This forum does not keep that tradition. It's woefully out of date and many features have simply been hacked off in the name of security or stability.
You will find many comments by well-meaning users urging Adobe to do better. That they do not (nor do they often even answer queries about why) suggests a lack of funding and/or the wrong folks in charge. Adobe does not realize how important this public face is, especially in light of the fact that the phone support people often send people here.
-Noel
-Noel
There have been people peroidically voicing these same thoughts since the first trial of the new version of the forums, more than two years ago. No answers, no changes, except for a few cosmetic ones some months ago that weren't a big improvement. And people looking for help come here not only because the phone support personnel send them here, but mainly because these forums have a reputation for providing very good and very timely solutions for free... Of course, the merit of this is not Adobe's...
Hi, Is anyone else having a problem using the Report Spam Forum? I've had login issues since Sunday & that is fixed. There are about 30 threads of Spam on the Flash Player Forum and I cannot use the Spam Forum, no features except "report abuse".
I'm logged in but it's not working for me.
eidnolb
Thank you for that info. I just came back from the Spam Report and see that any report I made does not even have "report abuse" on any of my messages. Completely blank, nothing to click on.
I've had login account issues twice this month, just have had that resolved again this afternoon.
I find it amusing the Spammers have no problem:-)
eidnolb
eidnolb
Just checking to see if I am following you.
1. Are you saying that there is no Report Abuse button in any of your posts? If so, it's not at all surprising: I would think that no sane person would want to report oneself as an abuser...
2. There have been login problems in these forums since the first trial of their new version, with some participants more lucky than others. I for one was for many months automatically logged out every time I closed my browser, but also after a period of inactivity of about a couple of hours. This happened regardles of platform (Mac or Win), of browser (Firefox, Explorer and Safari), or of the type of connection (cable, DSL, internal modem + telephone line). Luckily, this is gone now.
3. Well, the spammers rule these forums, don't they?
4. Have you tried reporting a spammer following the link I gave? If so, what happened? (To this minute, I don't see any spam report there).
Message was edited by: Claudio González. Reason: adding point 4.
Hi, LOL, I agree on not wanting to report abuse on one's own message. I guess what I was trying to say is that each of my messages/posts that I previously made are totally blank, no reply to or edit or even at the bottom reply to original post.
Your Point2: I can't imagine that kind of trouble. Those 2 weeks in March raised my blood pressure:-)
Your Point#3: It appears so until some procedure is put in place to stop them. I'm surprised that isn't already in place instead of just having to report it and then someone has to remove them. Perhaps only Employees have that authority. It would be helpful for everyone though if trusted Volunteers could, but I would also think if that had been possible it would have already been done. Maybe a legal matter.
I do visit many forums that don't seem to have that problem. Here though it seems the busier the forums, the more the spam which makes sense from their perspective.
Your Point#4: No, but I read the discussion and thot it best to wait to see if the new Spam thread you put up would stay or not.
Admin or someone cleared out the approx 30 threads of various spammers!!
Thanks for the info,
eidnolb
My general observations have been just the opposite. I see little activity in some of the higher-traffic forums, but do see a lot in the lesser-used forums.
I am sure that there are exceptions to that, as I hear of a lot of spam in the Dreamweaver forum, and would assume that it is quite busy.
Over the years, there have been a few "patterns," but those seem to change after a month, or so.
It has also been pointed out, by people better equipped to know, than I, that much of the spam here is not meant for the subscribers to click on, but to be picked up and logged by the 'Bots that crawl each page.
Good luck to us all,
Hunt
